    MMM-forecast-io -- Localized up to the minute weather
    127 Posts 36 Posters 247.1k Views 38 Watching
    • Mykle1M
      Mykle1 Project Sponsor Module Developer @Littlejohn21
      @Littlejohn21 said in MMM-forecast-io -- Localized up to the minute weather:
      Please disregard i’m “special” I never "git clone “hhtp://module” " to have the module in order for it to read i’m new but have it working now thanks!!!
      You won’t make that mistake again. I’m glad you’re up and running.
      L 1 Reply Last reply
      • L
        Littlejohn21 @Mykle1
        @Mykle1
        Thanks! i will try not to haha trying to figure out why I’m having issue with vlc java when trying to launch the alexa avs sample :(
        Mykle1M 1 Reply Last reply
        • Mykle1M
          I’m not familiar with those at all. Create a new topic and hopefully you will get some assistance with that.
          Good luck! :^)
          • L
            @Mykle1 is there a way to scale the entire Module? I’ve tried doing the graph but the forecast is still huge on my screen.
            strawberry 3.141S Mykle1M 2 Replies Last reply
            • strawberry 3.141S
              strawberry 3.141 Project Sponsor Module Developer @Littlejohn21
              @Littlejohn21 you can try
              .MODULENAME {
                transform: scale(0.5, 0.5);
              if you replace modulename with your actual module name, this should give you a height and with of 50% of the actual size
              • Mykle1M
                Follow @strawberry-3-141 instructions. I can’t imagine why your forecast would be huge. I do have a question for you. What position have you assigned to the weatherforecast module in the config?
                • L
                  Littlejohn21
                  @strawberry-3-141 @Mykle1
                  im having trouble getting it to accept the line you provided it gives me the syntax error code when starting the program. am i supposed to have it inside the MMM-forecast-io module or in its own spot? ive tried both, tried without the . infront of the module name tried with a space after scale ect.
                  the position is top left and it takes up alsost 1/2 the top of the screen.
                  • L
                    Littlejohn21
                    @Mykle1 @strawberry-3-141
                    here is a screen shot for reference. 0_1504184130418_2017-08-31-085210_1016x1856_scrot.png
                    yawnsY 1 Reply Last reply
                    • yawnsY
                      yawns Moderator @Littlejohn21
                      @Littlejohn21
                      The lines provided by Mykle and Strawberry need to go into custom.css in your css folder, not into the module file.
                      • L
                        Littlejohn21 @yawns
                        @yawns
                        Literally just found that out and tried it! haha it worked thanks guys!!
                        • L
                          Littlejohn21
                          @Mykle1 @strawberry-3-141 @yawns
                          now im having an issue where it wont sit in the corner if that makes sense?it keeps a buffer only on the MMM-forecast-io all others are right agains the edge i installed
                          body {
                            margin: 0px;
                            height: 100%;
                            width: 100%;
                          and that moved everything else to the edge but forcast-io stayed it even keeps a buffer when i relocate it to the other side of the screen…
                          sorry bout the phrase it was the first thing i figured out how to edit and since i’m making this for the wife well… figured i’d have fun with it :)
                          • Mykle1M
                            LMFAO! That is PERFECT!
                            Ok, so, in honor of your wife’s #@#'s, you can try this entry in your custom.css file. I assume you want to move the module to the right and up, so you only need margin-right: -40px; and margin-top: -40px;. Adjust those numbers accordingly until you get the result you want.
                            .MMM-MODULENAME {
                              margin-left: 0px;
                              margin-top: -40px;
                              margin-bottom: 0px;
                            • pyrosmileyP
                              pyrosmiley
                              Hey quick question: how do I change the color of the precipitation graph? I’ve got a decent amount of custom CSS that’s working (including other things for this module) but for the life of me I cannot seem to change this one element?
                              Here’s what I’ve got going on for this module right now (more icon colors elsewhere, I gotta clean up the file!):
                              .MMM-forecast-io .summary {color: #aaa;}
                              .MMM-forecast-io .forecast-row .weathericon {color: #aaa}
                              .MMM-forecast-io .wi-night-alt-cloudy {color: #1a659e}
                              .MMM-forecast-io .wi-volcano {color: #8c2f39}
                              .MMM-forecast-io .precipitation-graph {color: #1a659e;}
                              .small.MMM-forecast-io .forecast {
                                margin-right: 0px;
                                margin-left: auto;
                              .small.MMM-forecast-io .summary {
                                text-align: right;
                              I’m absolutely positive I’m missing something dumb here
                              D 1 Reply Last reply
                                dmcinnes Module Developer @pyrosmiley
                                @pyrosmiley Hello! The precipitation graph is created using an HTML Canvas so unfortunately the colors cannot be tweaked by CSS apart from the border. The Javascript will need to be modified to support additional colors. Here is where the color is set for the curve and further up it draws the horizontal lines and tick marks. Ideally these colors are configurable. I’ve added an issue to the repo to track it!
                                I’m knee deep in another project, so if someone wants to take a crack at it, please be my guest :)
                                pyrosmileyP 1 Reply Last reply
                                • pyrosmileyP
                                  pyrosmiley @dmcinnes
                                  @dmcinnes Oh, okay — that makes a lot of sense! Glad to know it’s not just me missing something. I’ll take a look at the html and see what I can do, thanks for pointing that out for me.
                                    mongo116 Module Developer @jinjirosan
                                    @jinjirosan Hi, have you made the changes available to download? Would like to give it a go as currently using a combination of the default weather and forecast-io.
                                      Basanth_Kumar
                                      Hello! as i am completely new to this MM…i am unable to where the icons images are placed…if anybody knows that,guide me , so that i want to change the UI for mine…
                                      • pyrosmileyP
                                        pyrosmiley @mongo116
                                        @mongo116 The changes were merged into the main branch of the module, so if you’re up to date, then you should be able to add ‘’’precipitationFillColor’’’ to your config. I added a description and some other info to the readme as well.
                                        • pyrosmileyP
                                          pyrosmiley @Basanth_Kumar
                                          @Basanth_Kumar I’m on my phone so I can’t look up links very effectively, but there are a couple of guides on the forums that are good for learning how to setup your configuration file. The official guide on the github page is also pretty thorough. It definitely took some trial and error for me to get up and running (gotta pay attention to those commas!) but you’ll get it. Just follow those guides, and just change one little thing at a time so you can learn to see how it works — you’ll get the hang of it!
                                            mongo116 Module Developer @pyrosmiley
                                            @pyrosmiley Thanks for that. What about the wind, and sunrise / sunset settings? Or were these never merged? Thanks…
                                            • 4 / 7
