    MMM-forecast-io -- Localized up to the minute weather
    127 Posts 36 Posters 244.7k Views 38 Watching
    • FlatPepsiF
      FlatPepsi @jinjirosan
      @jinjirosan - The temperature bars auto scale based upon the width of the rest of the module. I suspect some other changes you’ve made have caused the module to get wider, so you’re looking at a side effect and not a cause.
      It might also be a screen resolution – the crypto currency module underneath in your screenshot is wide as well. I’m using a crummy small monitor, and have very narrow margins.
      I love that someone else is picking this up and running with this module. Looks good!
      • jinjirosanJ
        jinjirosan
        Thx for the quick reply! Yes, the crypto currency module also scales based on the width of the “top right” column of the mirror. Still have to fix that but up until now the other modules above and below were of narrower width.
        Screen resolution could be it, I’m using a 24" monitor at native 1080p. I do remember that the sunrise/sunset, hourly forcast line above the graph and the days forcast below the graph were shifted to the left before I made changes but I’ll check to make sure.
        Is there a way to “fix” the sunset/sunrise/hourly and the forecast days/bars in place instead of having it auto-scale?
        -edit- : I freshly pulled @FlatPepsi and the days/bars and the sunrise/sunset/hourly forecast are shifted to the left as shown in my original picture.
        Also pulled @dmcinnes repo and that seems to outline the way I like to see it. Looking at a diff between the files the table generate section seems the same.
        The mirror project for me is to work on my coding skills as well (which do need a lottttttt of work :-) ) so pls bear with me when I ask something that might be obvious :-)
        • jinjirosanJ
          jinjirosan
          Got it :-)
          Playing around with the Chrome inspector and fiddling with additional CSS classes, have it lined up nicely now.
          Now the hard(er) part, the visualization changes.
          • L
            Littlejohn21
            I cannot for the life of me get this to work it keeps saying that there is an error in the config file. I will have it Exactly as others have it with only my darkskyspi key being diffrent and still get the error .
            magicmirror@2.1.2 start /home/pi/MagicMirror
            sh run-start.sh
            Starting MagicMirror: v2.1.2
            Loading config …
            WARNING! Could not validate config file. Please correct syntax errors. Starting with default configuration.
            Loading module helpers …
            No helper found for module: helloworld.
            All module helpers loaded.
            Starting server on port 8080 …
            Server started …
            Sockets connected & modules started …
            Launching application.
            • Mykle1M
              Mykle1 Project Sponsor Module Developer @Littlejohn21
              @Littlejohn21 said in MMM-forecast-io -- Localized up to the minute weather:
              It could be something as simple as a comma, or quote being out of place, or missing.
              Post your config here for help, but please follow this guide on how to post code on the forum correctly.
              https://forum.magicmirror.builders/topic/4247/how-to-post-code-on-the-forum-for-absolute-beginners
              L 2 Replies Last reply Reply Quote 0
              • L
                Littlejohn21 @Mykle1
                @Mykle1
                			module: "alert",
                			module: "updatenotification",
                			position: "top_bar"
                			module: "clock",
                			position: "top_left"
                			header: "US Holidays",
                						symbol: "calendar-check-o ",
                			module: "compliments",
                			position: "lower_third"
                			module: 'MMM-forecast-io',
                    			position: 'top_right',  // This can be any of the regions.
                     		        apiKey: '6xxxxxxxxxxxxxxxxxxxxxxxxxxxx3', // Dark Sky API key.
                      			// Only required if geolocation doesn't work:
                       			latitude:   29.853357,
                      			longitude: -81.389680
                			module: "newsfeed",
                			position: "bottom_bar",
                				feeds: [
                						title: "New York Times",
                				showSourceTitle: true,
                				showPublishDate: true
                I have tried several ways and have even ran the npm run config:check it says thet expected to see { but sees something else.
                • L
                  @Mykle1
                  			module: "alert",
                  			position: "top_bar"
                  			module: "clock",
                  			module: "MMM-Todoist",
                  			header: "Todoist",
                  				accessToken: '33xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx' ,
                  				maximumentries: 10,
                  				interval: 60,
                  				lists: [21xxxxxxxx7],
                  				fade: false,
                  			position: "top_left",	// This can be any of the regions. Best results in left or right regions.
                  			module: "currentweather",
                  				locationID: "4170894",  //ID from http://www.openweathermap.org/help/city_list.txt
                  				appid: "axxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxd4"
                       		        apiKey: '2xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx5', // Dark Sky API key.
                  			module: "newsfeed",
                  				feeds: [
                  						title: "News4JAX",
                  						url: "https://www.news4jax.com/feeds/rssFeed/feedServlet?obfType=GMG_RSS_DETAIL&siteId=800004&categoryId=80041&nbRows=20&FeedFetchDays=10&includeFeeds=True"
                  I got this one to work, atleast load with no syntax error but the weather module doesnt show up? is there anything i need to do in the actual files?
                  • L
                    Littlejohn21
                    Please disregard i’m “special” I never "git clone “hhtp://module” " to have the module in order for it to read i’m new but have it working now thanks!!!
                    • Mykle1M
                      You won’t make that mistake again. I’m glad you’re up and running.
                      • L
                        @Mykle1
                        Thanks! i will try not to haha trying to figure out why I’m having issue with vlc java when trying to launch the alexa avs sample :(
                        • Mykle1M
                          I’m not familiar with those at all. Create a new topic and hopefully you will get some assistance with that.
                          Good luck! :^)
                          • L
                            @Mykle1 is there a way to scale the entire Module? I’ve tried doing the graph but the forecast is still huge on my screen.
                            strawberry 3.141S Mykle1M 2 Replies Last reply Reply Quote 0
                            • strawberry 3.141S
                              strawberry 3.141 Project Sponsor Module Developer @Littlejohn21
                              @Littlejohn21 you can try
                              .MODULENAME {
                                transform: scale(0.5, 0.5);
                              if you replace modulename with your actual module name, this should give you a height and with of 50% of the actual size
                              • Mykle1M
                                Follow @strawberry-3-141 instructions. I can’t imagine why your forecast would be huge. I do have a question for you. What position have you assigned to the weatherforecast module in the config?
                                • L
                                  Littlejohn21
                                  @strawberry-3-141 @Mykle1
                                  im having trouble getting it to accept the line you provided it gives me the syntax error code when starting the program. am i supposed to have it inside the MMM-forecast-io module or in its own spot? ive tried both, tried without the . infront of the module name tried with a space after scale ect.
                                  the position is top left and it takes up alsost 1/2 the top of the screen.
                                  • L
                                    Littlejohn21
                                    @Mykle1 @strawberry-3-141
                                    here is a screen shot for reference. 0_1504184130418_2017-08-31-085210_1016x1856_scrot.png
                                    • Y
                                      yawns Moderator @Littlejohn21
                                      @Littlejohn21
                                      The lines provided by Mykle and Strawberry need to go into custom.css in your css folder, not into the module file.
                                      • L
                                        Littlejohn21 @yawns
                                        @yawns
                                        Literally just found that out and tried it! haha it worked thanks guys!!
                                        • L
                                          Littlejohn21
                                          @Mykle1 @strawberry-3-141 @yawns
                                          now im having an issue where it wont sit in the corner if that makes sense?it keeps a buffer only on the MMM-forecast-io all others are right agains the edge i installed
                                          body {
                                            margin: 0px;
                                            height: 100%;
                                            width: 100%;
                                          and that moved everything else to the edge but forcast-io stayed it even keeps a buffer when i relocate it to the other side of the screen…
                                          sorry bout the phrase it was the first thing i figured out how to edit and since i’m making this for the wife well… figured i’d have fun with it :)
                                          • Mykle1M
                                            LMFAO! That is PERFECT!
                                            Ok, so, in honor of your wife’s #@#'s, you can try this entry in your custom.css file. I assume you want to move the module to the right and up, so you only need margin-right: -40px; and margin-top: -40px;. Adjust those numbers accordingly until you get the result you want.
                                            .MMM-MODULENAME {
                                              margin-left: 0px;
                                              margin-top: -40px;
                                              margin-bottom: 0px;
                                            • 4 / 7
