    MMM-forecast-io -- Localized up to the minute weather
    127 Posts 36 Posters 246.8k Views 38 Watching
    • jinjirosanJ
      jinjirosan
      Thx for the quick reply! Yes, the crypto currency module also scales based on the width of the “top right” column of the mirror. Still have to fix that but up until now the other modules above and below were of narrower width.
      Screen resolution could be it, I’m using a 24" monitor at native 1080p. I do remember that the sunrise/sunset, hourly forcast line above the graph and the days forcast below the graph were shifted to the left before I made changes but I’ll check to make sure.
      Is there a way to “fix” the sunset/sunrise/hourly and the forecast days/bars in place instead of having it auto-scale?
      -edit- : I freshly pulled @FlatPepsi and the days/bars and the sunrise/sunset/hourly forecast are shifted to the left as shown in my original picture.
      Also pulled @dmcinnes repo and that seems to outline the way I like to see it. Looking at a diff between the files the table generate section seems the same.
      The mirror project for me is to work on my coding skills as well (which do need a lottttttt of work :-) ) so pls bear with me when I ask something that might be obvious :-)
      • jinjirosanJ
        jinjirosan
        Got it :-)
        Playing around with the Chrome inspector and fiddling with additional CSS classes, have it lined up nicely now.
        Now the hard(er) part, the visualization changes.
        • L
          Littlejohn21
          I cannot for the life of me get this to work it keeps saying that there is an error in the config file. I will have it Exactly as others have it with only my darkskyspi key being diffrent and still get the error .
          magicmirror@2.1.2 start /home/pi/MagicMirror
          sh run-start.sh
          Starting MagicMirror: v2.1.2
          Loading config …
          WARNING! Could not validate config file. Please correct syntax errors. Starting with default configuration.
          Loading module helpers …
          No helper found for module: helloworld.
          All module helpers loaded.
          Starting server on port 8080 …
          Server started …
          Sockets connected & modules started …
          Launching application.
          Mykle1M 1 Reply Last reply
          • Mykle1M
            Mykle1 Project Sponsor Module Developer @Littlejohn21
            @Littlejohn21 said in MMM-forecast-io -- Localized up to the minute weather:
            It could be something as simple as a comma, or quote being out of place, or missing.
            Post your config here for help, but please follow this guide on how to post code on the forum correctly.
            https://forum.magicmirror.builders/topic/4247/how-to-post-code-on-the-forum-for-absolute-beginners
            L 2 Replies Last reply
            • L
              Littlejohn21 @Mykle1
              @Mykle1
              			module: "alert",
              			module: "updatenotification",
              			position: "top_bar"
              			module: "clock",
              			position: "top_left"
              			header: "US Holidays",
              						symbol: "calendar-check-o ",
              			module: "compliments",
              			position: "lower_third"
              			module: 'MMM-forecast-io',
                  			position: 'top_right',  // This can be any of the regions.
                   		        apiKey: '6xxxxxxxxxxxxxxxxxxxxxxxxxxxx3', // Dark Sky API key.
                    			// Only required if geolocation doesn't work:
                     			latitude:   29.853357,
                    			longitude: -81.389680
              			module: "newsfeed",
              			position: "bottom_bar",
              				feeds: [
              						title: "New York Times",
              				showSourceTitle: true,
              				showPublishDate: true
              I have tried several ways and have even ran the npm run config:check it says thet expected to see { but sees something else.
              • L
                @Mykle1
                			module: "alert",
                			position: "top_bar"
                			module: "clock",
                			module: "MMM-Todoist",
                			header: "Todoist",
                				accessToken: '33xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx' ,
                				maximumentries: 10,
                				interval: 60,
                				lists: [21xxxxxxxx7],
                				fade: false,
                			position: "top_left",	// This can be any of the regions. Best results in left or right regions.
                			module: "currentweather",
                				locationID: "4170894",  //ID from http://www.openweathermap.org/help/city_list.txt
                				appid: "axxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxd4"
                     		        apiKey: '2xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx5', // Dark Sky API key.
                			module: "newsfeed",
                				feeds: [
                						title: "News4JAX",
                						url: "https://www.news4jax.com/feeds/rssFeed/feedServlet?obfType=GMG_RSS_DETAIL&siteId=800004&categoryId=80041&nbRows=20&FeedFetchDays=10&includeFeeds=True"
                I got this one to work, atleast load with no syntax error but the weather module doesnt show up? is there anything i need to do in the actual files?
                • L
                  Littlejohn21
                  Please disregard i’m “special” I never "git clone “hhtp://module” " to have the module in order for it to read i’m new but have it working now thanks!!!
                  • Mykle1M
                    You won’t make that mistake again. I’m glad you’re up and running.
                    L 1 Reply Last reply
                    • L
                      @Mykle1
                      Thanks! i will try not to haha trying to figure out why I’m having issue with vlc java when trying to launch the alexa avs sample :(
                      • Mykle1M
                        I’m not familiar with those at all. Create a new topic and hopefully you will get some assistance with that.
                        Good luck! :^)
                        • L
                          @Mykle1 is there a way to scale the entire Module? I’ve tried doing the graph but the forecast is still huge on my screen.
                          strawberry 3.141S Mykle1M 2 Replies Last reply
                          • strawberry 3.141S
                            strawberry 3.141 Project Sponsor Module Developer @Littlejohn21
                            @Littlejohn21 you can try
                            .MODULENAME {
                              transform: scale(0.5, 0.5);
                            if you replace modulename with your actual module name, this should give you a height and with of 50% of the actual size
                            • Mykle1M
                              Follow @strawberry-3-141 instructions. I can’t imagine why your forecast would be huge. I do have a question for you. What position have you assigned to the weatherforecast module in the config?
                              • L
                                Littlejohn21
                                @strawberry-3-141 @Mykle1
                                im having trouble getting it to accept the line you provided it gives me the syntax error code when starting the program. am i supposed to have it inside the MMM-forecast-io module or in its own spot? ive tried both, tried without the . infront of the module name tried with a space after scale ect.
                                the position is top left and it takes up alsost 1/2 the top of the screen.
                                • L
                                  Littlejohn21
                                  @Mykle1 @strawberry-3-141
                                  here is a screen shot for reference. 0_1504184130418_2017-08-31-085210_1016x1856_scrot.png
                                  yawnsY 1 Reply Last reply
                                  • yawnsY
                                    yawns Moderator @Littlejohn21
                                    @Littlejohn21
                                    The lines provided by Mykle and Strawberry need to go into custom.css in your css folder, not into the module file.
                                    • L
                                      Littlejohn21 @yawns
                                      @yawns
                                      Literally just found that out and tried it! haha it worked thanks guys!!
                                      • L
                                        Littlejohn21
                                        @Mykle1 @strawberry-3-141 @yawns
                                        now im having an issue where it wont sit in the corner if that makes sense?it keeps a buffer only on the MMM-forecast-io all others are right agains the edge i installed
                                        body {
                                          margin: 0px;
                                          height: 100%;
                                          width: 100%;
                                        and that moved everything else to the edge but forcast-io stayed it even keeps a buffer when i relocate it to the other side of the screen…
                                        sorry bout the phrase it was the first thing i figured out how to edit and since i’m making this for the wife well… figured i’d have fun with it :)
                                        • Mykle1M
                                          LMFAO! That is PERFECT!
                                          Ok, so, in honor of your wife’s #@#'s, you can try this entry in your custom.css file. I assume you want to move the module to the right and up, so you only need margin-right: -40px; and margin-top: -40px;. Adjust those numbers accordingly until you get the result you want.
                                          .MMM-MODULENAME {
                                            margin-left: 0px;
                                            margin-top: -40px;
                                            margin-bottom: 0px;
                                          • pyrosmileyP
                                            pyrosmiley
                                            Hey quick question: how do I change the color of the precipitation graph? I’ve got a decent amount of custom CSS that’s working (including other things for this module) but for the life of me I cannot seem to change this one element?
                                            Here’s what I’ve got going on for this module right now (more icon colors elsewhere, I gotta clean up the file!):
                                            .MMM-forecast-io .summary {color: #aaa;}
                                            .MMM-forecast-io .forecast-row .weathericon {color: #aaa}
                                            .MMM-forecast-io .wi-night-alt-cloudy {color: #1a659e}
                                            .MMM-forecast-io .wi-volcano {color: #8c2f39}
                                            .MMM-forecast-io .precipitation-graph {color: #1a659e;}
                                            .small.MMM-forecast-io .forecast {
                                              margin-right: 0px;
                                              margin-left: auto;
                                            .small.MMM-forecast-io .summary {
                                              text-align: right;
                                            I’m absolutely positive I’m missing something dumb here
                                            D 1 Reply Last reply
                                            • 4 / 7
