    MMM-forecast-io -- Localized up to the minute weather
    127 Posts 36 Posters 247.1k Views 38 Watching
    • ooom416354O
      ooom416354
      Great module!! One question, is there anyway to make the length of the temperature bars a bit smaller? I suppose because the NY weather is so erratic right now it is making the bars wider but was just curious if I can shrink them a bit to save some space. thanks!
      D 1 Reply Last reply
      • ooom416354O
        ooom416354
        also it could just be me but I keep seeing the rain icon next to the temperature even though there’s no rain in the forecast for today (the small icon by the days of the week shows nothing but sun). Anything I can do to check that icon to see if it is an issue?
          bminer1
          Im getting the below when i try to install:
          pi@raspberrypi:~/MagicMirror/modules $ git pull https://github.com/dmcinnes/MMM-forecast-io.git
          From https://github.com/dmcinnes/MMM-forecast-io
           * branch            HEAD       -> FETCH_HEAD
          *** Please tell me who you are.
          Run
            git config --global user.email "you@example.com"
            git config --global user.name "Your Name"
          to set your account's default identity.
          Omit --global to set the identity only in this repository.
          fatal: empty ident name (for <pi@raspberrypi.(none)>) not allowed
          How do i fix this in order to install?
          morozgrafixM 1 Reply Last reply
          • morozgrafixM
            morozgrafix Moderator @bminer1
            @bminer1 it seems that you are trying to pull instead of clone (and git is not globally configured on your system and doesn’t recognize you)
            try running this command instead: git clone https://github.com/dmcinnes/MMM-forecast-io.git
              bminer1
              noob mistake. Installed now. Thanks!!
              I feel like an idiot. This machine will not beat me!!
                bminer1
                I’m not getting any graph for precipitation. Will it only be there if there is rain/snow in the next x amount of hours?
                • morozgrafixM
                  @bminer1 I believe that default setting is not to show precipitation graph, unless there is a prediction for rain or snow in next hour. I think it takes data from minutely weather forecast supplied by DarkSky.
                  • FlatPepsiF
                    FlatPepsi
                    I love the simplicity of MMM-Forecast.io, and yet wanted more from the graph. The default graph seems to be aimed at minutely weather for the near future.
                    Earlier in this thread there was a graph example from dmcinnes’s mirror:
                    https://github.com/jangellx/MagicMirror#important-installation-note
                    Sadly, the code from that mirror’s graph is a totally different approach than the main branch of forecast.io. Stealing code was not an option, so I had to write a bunch from scratch.
                    For my own use, I’ve rewritten a lot of the graph- and added in a few goodies, like:
                    -Graph now shows 36 hours of forecast
                    -Day/night shading in graph
                    -Temperature line in graph with labels
                    -Precip intensity graph is now blue.
                    -Graph has freezing blue line, and hot 80 degree line.
                    -Wind speed is an option to turn on/off
                    -Sunrise/Sunset is an option to turn on/off
                    -Included notes for easy color icons, via “Color-icons.md”
                    my new weather graph
                    Feel free to play with my branch:
                    https://github.com/FlatPepsi17/MMM-forecast-io/tree/FlatPepsi17-GraphUpgrade
                    Known limitation: non-Fahrenheit units will probably look funny, as the graph scaling & hot/cold lines are not unit aware.
                      dmcinnes Module Developer @ooom416354
                      @ooom416354 sorry about taking so long to reply! You can shrink the module a bit by using the MagicMirror’s size classes. I normally have mine set as “small”.
                        module: 'MMM-forecast-io',
                        classes: 'small'
                        Hello everyone,
                        I’ve recently updated the module fixing/adding a couple things:
                        • Fixes an issue that made the top of the curve appear off the graph during a heavy storm.
                        • Adds alwaysShowPrecipitationGraph to always show the precipitation graph.
                        • Adds details on getting the geolocation working by setting the GOOGLE_API_KEY.
                        Use git pull in your module to update.
                        Enjoy!
                        Doug
                          dmcinnes Module Developer @FlatPepsi
                          @FlatPepsi Looks awesome! I particularly like the day/night shading in the graph.
                          • jinjirosanJ
                            jinjirosan
                            @dmcinnes @FlatPepsi Love the module and the changes to it so I forked it. Also made a couple of changes to it (revert back to 24h, hot/freeze lines in metric and have a couple more visual changes I’d like to do).
                            Anyway, this topic is old so hope you guys still see this now. Could you help me out or point me in the right direction on how the forecast table and bars is build up?
                            On my mirror the days and bars seem to have shifted one column to the left and do not line up nicely under de graph
                            @FlatPepsi has it like this:
                            alt text
                            and mine is like so:
                            alt text
                            Also the sunset/sunrise and line below are “moved” to the left. Now I did a diff between @FlatPepsi and @dmcinnes code and the table build seem to be the same.
                            Hope you can help me or point me in the right direction to get it nicely lined out underneath the graph.
                            FlatPepsiF M 2 Replies Last reply
                            • FlatPepsiF
                              FlatPepsi @jinjirosan
                              @jinjirosan - The temperature bars auto scale based upon the width of the rest of the module. I suspect some other changes you’ve made have caused the module to get wider, so you’re looking at a side effect and not a cause.
                              It might also be a screen resolution – the crypto currency module underneath in your screenshot is wide as well. I’m using a crummy small monitor, and have very narrow margins.
                              I love that someone else is picking this up and running with this module. Looks good!
                              • jinjirosanJ
                                jinjirosan
                                Thx for the quick reply! Yes, the crypto currency module also scales based on the width of the “top right” column of the mirror. Still have to fix that but up until now the other modules above and below were of narrower width.
                                Screen resolution could be it, I’m using a 24" monitor at native 1080p. I do remember that the sunrise/sunset, hourly forcast line above the graph and the days forcast below the graph were shifted to the left before I made changes but I’ll check to make sure.
                                Is there a way to “fix” the sunset/sunrise/hourly and the forecast days/bars in place instead of having it auto-scale?
                                -edit- : I freshly pulled @FlatPepsi and the days/bars and the sunrise/sunset/hourly forecast are shifted to the left as shown in my original picture.
                                Also pulled @dmcinnes repo and that seems to outline the way I like to see it. Looking at a diff between the files the table generate section seems the same.
                                The mirror project for me is to work on my coding skills as well (which do need a lottttttt of work :-) ) so pls bear with me when I ask something that might be obvious :-)
                                • jinjirosanJ
                                  jinjirosan
                                  Got it :-)
                                  Playing around with the Chrome inspector and fiddling with additional CSS classes, have it lined up nicely now.
                                  Now the hard(er) part, the visualization changes.
                                  • L
                                    Littlejohn21
                                    I cannot for the life of me get this to work it keeps saying that there is an error in the config file. I will have it Exactly as others have it with only my darkskyspi key being diffrent and still get the error .
                                    magicmirror@2.1.2 start /home/pi/MagicMirror
                                    sh run-start.sh
                                    Starting MagicMirror: v2.1.2
                                    Loading config …
                                    WARNING! Could not validate config file. Please correct syntax errors. Starting with default configuration.
                                    Loading module helpers …
                                    No helper found for module: helloworld.
                                    All module helpers loaded.
                                    Starting server on port 8080 …
                                    Server started …
                                    Sockets connected & modules started …
                                    Launching application.
                                    Mykle1M 1 Reply Last reply
                                    • Mykle1M
                                      Mykle1 Project Sponsor Module Developer @Littlejohn21
                                      @Littlejohn21 said in MMM-forecast-io -- Localized up to the minute weather:
                                      It could be something as simple as a comma, or quote being out of place, or missing.
                                      Post your config here for help, but please follow this guide on how to post code on the forum correctly.
                                      https://forum.magicmirror.builders/topic/4247/how-to-post-code-on-the-forum-for-absolute-beginners
                                      L 2 Replies Last reply
                                      • L
                                        Littlejohn21 @Mykle1
                                        @Mykle1
                                        			module: "alert",
                                        			module: "updatenotification",
                                        			position: "top_bar"
                                        			module: "clock",
                                        			position: "top_left"
                                        			header: "US Holidays",
                                        						symbol: "calendar-check-o ",
                                        			module: "compliments",
                                        			position: "lower_third"
                                            			position: 'top_right',  // This can be any of the regions.
                                             		        apiKey: '6xxxxxxxxxxxxxxxxxxxxxxxxxxxx3', // Dark Sky API key.
                                              			// Only required if geolocation doesn't work:
                                               			latitude:   29.853357,
                                              			longitude: -81.389680
                                        			module: "newsfeed",
                                        			position: "bottom_bar",
                                        				feeds: [
                                        						title: "New York Times",
                                        				showSourceTitle: true,
                                        				showPublishDate: true
                                        I have tried several ways and have even ran the npm run config:check it says thet expected to see { but sees something else.
                                        • L
                                          @Mykle1
                                          			module: "alert",
                                          			position: "top_bar"
                                          			module: "clock",
                                          			module: "MMM-Todoist",
                                          			header: "Todoist",
                                          				accessToken: '33xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx' ,
                                          				maximumentries: 10,
                                          				interval: 60,
                                          				lists: [21xxxxxxxx7],
                                          				fade: false,
                                          			position: "top_left",	// This can be any of the regions. Best results in left or right regions.
                                          			module: "currentweather",
                                          				locationID: "4170894",  //ID from http://www.openweathermap.org/help/city_list.txt
                                          				appid: "axxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxd4"
                                               		        apiKey: '2xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx5', // Dark Sky API key.
                                          			module: "newsfeed",
                                          				feeds: [
                                          						title: "News4JAX",
                                          						url: "https://www.news4jax.com/feeds/rssFeed/feedServlet?obfType=GMG_RSS_DETAIL&siteId=800004&categoryId=80041&nbRows=20&FeedFetchDays=10&includeFeeds=True"
                                          I got this one to work, atleast load with no syntax error but the weather module doesnt show up? is there anything i need to do in the actual files?
                                          • L
                                            Littlejohn21
                                            Please disregard i’m “special” I never "git clone “hhtp://module” " to have the module in order for it to read i’m new but have it working now thanks!!!
                                            • 3 / 7
