    MMM-forecast-io -- Localized up to the minute weather
    127 Posts 36 Posters 241.3k Views 38 Watching
    • FlatPepsiF Offline
      FlatPepsi
      I love the simplicity of MMM-Forecast.io, and yet wanted more from the graph. The default graph seems to be aimed at minutely weather for the near future.
      Earlier in this thread there was a graph example from dmcinnes’s mirror:
      https://github.com/jangellx/MagicMirror#important-installation-note
      Sadly, the code from that mirror’s graph is a totally different approach than the main branch of forecast.io. Stealing code was not an option, so I had to write a bunch from scratch.
      For my own use, I’ve rewritten a lot of the graph- and added in a few goodies, like:
      -Graph now shows 36 hours of forecast
      -Day/night shading in graph
      -Temperature line in graph with labels
      -Precip intensity graph is now blue.
      -Graph has freezing blue line, and hot 80 degree line.
      -Wind speed is an option to turn on/off
      -Sunrise/Sunset is an option to turn on/off
      -Included notes for easy color icons, via “Color-icons.md”
      my new weather graph
      Feel free to play with my branch:
      https://github.com/FlatPepsi17/MMM-forecast-io/tree/FlatPepsi17-GraphUpgrade
      Known limitation: non-Fahrenheit units will probably look funny, as the graph scaling & hot/cold lines are not unit aware.
        dmcinnes Module Developer @ooom416354
        @ooom416354 sorry about taking so long to reply! You can shrink the module a bit by using the MagicMirror’s size classes. I normally have mine set as “small”.
          module: 'MMM-forecast-io',
          classes: 'small'
          Hello everyone,
          I’ve recently updated the module fixing/adding a couple things:
          • Fixes an issue that made the top of the curve appear off the graph during a heavy storm.
          • Adds alwaysShowPrecipitationGraph to always show the precipitation graph.
          • Adds details on getting the geolocation working by setting the GOOGLE_API_KEY.
          Use git pull in your module to update.
          Enjoy!
          Doug
            dmcinnes Module Developer @FlatPepsi
            @FlatPepsi Looks awesome! I particularly like the day/night shading in the graph.
            • jinjirosanJ Offline
              jinjirosan
              @dmcinnes @FlatPepsi Love the module and the changes to it so I forked it. Also made a couple of changes to it (revert back to 24h, hot/freeze lines in metric and have a couple more visual changes I’d like to do).
              Anyway, this topic is old so hope you guys still see this now. Could you help me out or point me in the right direction on how the forecast table and bars is build up?
              On my mirror the days and bars seem to have shifted one column to the left and do not line up nicely under de graph
              @FlatPepsi has it like this:
              alt text
              and mine is like so:
              alt text
              Also the sunset/sunrise and line below are “moved” to the left. Now I did a diff between @FlatPepsi and @dmcinnes code and the table build seem to be the same.
              Hope you can help me or point me in the right direction to get it nicely lined out underneath the graph.
              FlatPepsiF M 2 Replies Last reply Reply Quote 0
                FlatPepsi @jinjirosan
                @jinjirosan - The temperature bars auto scale based upon the width of the rest of the module. I suspect some other changes you’ve made have caused the module to get wider, so you’re looking at a side effect and not a cause.
                It might also be a screen resolution – the crypto currency module underneath in your screenshot is wide as well. I’m using a crummy small monitor, and have very narrow margins.
                I love that someone else is picking this up and running with this module. Looks good!
                  jinjirosan
                  Thx for the quick reply! Yes, the crypto currency module also scales based on the width of the “top right” column of the mirror. Still have to fix that but up until now the other modules above and below were of narrower width.
                  Screen resolution could be it, I’m using a 24" monitor at native 1080p. I do remember that the sunrise/sunset, hourly forcast line above the graph and the days forcast below the graph were shifted to the left before I made changes but I’ll check to make sure.
                  Is there a way to “fix” the sunset/sunrise/hourly and the forecast days/bars in place instead of having it auto-scale?
                  -edit- : I freshly pulled @FlatPepsi and the days/bars and the sunrise/sunset/hourly forecast are shifted to the left as shown in my original picture.
                  Also pulled @dmcinnes repo and that seems to outline the way I like to see it. Looking at a diff between the files the table generate section seems the same.
                  The mirror project for me is to work on my coding skills as well (which do need a lottttttt of work :-) ) so pls bear with me when I ask something that might be obvious :-)
                    jinjirosan
                    Got it :-)
                    Playing around with the Chrome inspector and fiddling with additional CSS classes, have it lined up nicely now.
                    Now the hard(er) part, the visualization changes.
                    • L Offline
                      Littlejohn21
                      I cannot for the life of me get this to work it keeps saying that there is an error in the config file. I will have it Exactly as others have it with only my darkskyspi key being diffrent and still get the error .
                      magicmirror@2.1.2 start /home/pi/MagicMirror
                      sh run-start.sh
                      Starting MagicMirror: v2.1.2
                      Loading config …
                      WARNING! Could not validate config file. Please correct syntax errors. Starting with default configuration.
                      Loading module helpers …
                      No helper found for module: helloworld.
                      All module helpers loaded.
                      Starting server on port 8080 …
                      Server started …
                      Sockets connected & modules started …
                      Launching application.
                        Mykle1 Project Sponsor Module Developer @Littlejohn21
                        @Littlejohn21 said in MMM-forecast-io -- Localized up to the minute weather:
                        It could be something as simple as a comma, or quote being out of place, or missing.
                        Post your config here for help, but please follow this guide on how to post code on the forum correctly.
                        https://forum.magicmirror.builders/topic/4247/how-to-post-code-on-the-forum-for-absolute-beginners
                        L 2 Replies Last reply Reply Quote 0
                        • L Offline
                          Littlejohn21 @Mykle1
                          @Mykle1
                          			module: "alert",
                          			module: "updatenotification",
                          			position: "top_bar"
                          			module: "clock",
                          			position: "top_left"
                          			header: "US Holidays",
                          						symbol: "calendar-check-o ",
                          			module: "compliments",
                          			position: "lower_third"
                              			position: 'top_right',  // This can be any of the regions.
                               		        apiKey: '6xxxxxxxxxxxxxxxxxxxxxxxxxxxx3', // Dark Sky API key.
                                			// Only required if geolocation doesn't work:
                                 			latitude:   29.853357,
                                			longitude: -81.389680
                          			module: "newsfeed",
                          			position: "bottom_bar",
                          				feeds: [
                          						title: "New York Times",
                          				showSourceTitle: true,
                          				showPublishDate: true
                          I have tried several ways and have even ran the npm run config:check it says thet expected to see { but sees something else.
                          • L Offline
                            @Mykle1
                            			module: "alert",
                            			position: "top_bar"
                            			module: "clock",
                            			module: "MMM-Todoist",
                            			header: "Todoist",
                            				accessToken: '33xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx' ,
                            				maximumentries: 10,
                            				interval: 60,
                            				lists: [21xxxxxxxx7],
                            				fade: false,
                            			position: "top_left",	// This can be any of the regions. Best results in left or right regions.
                            			module: "currentweather",
                            				locationID: "4170894",  //ID from http://www.openweathermap.org/help/city_list.txt
                            				appid: "axxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxd4"
                                 		        apiKey: '2xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx5', // Dark Sky API key.
                            			module: "newsfeed",
                            				feeds: [
                            						title: "News4JAX",
                            						url: "https://www.news4jax.com/feeds/rssFeed/feedServlet?obfType=GMG_RSS_DETAIL&siteId=800004&categoryId=80041&nbRows=20&FeedFetchDays=10&includeFeeds=True"
                            I got this one to work, atleast load with no syntax error but the weather module doesnt show up? is there anything i need to do in the actual files?
                            • L Offline
                              Littlejohn21
                              Please disregard i’m “special” I never "git clone “hhtp://module” " to have the module in order for it to read i’m new but have it working now thanks!!!
                                You won’t make that mistake again. I’m glad you’re up and running.
                                • L Offline
                                  @Mykle1
                                  Thanks! i will try not to haha trying to figure out why I’m having issue with vlc java when trying to launch the alexa avs sample :(
                                    I’m not familiar with those at all. Create a new topic and hopefully you will get some assistance with that.
                                    Good luck! :^)
                                    • L Offline
                                      @Mykle1 is there a way to scale the entire Module? I’ve tried doing the graph but the forecast is still huge on my screen.
                                      strawberry 3.141S Mykle1M 2 Replies Last reply Reply Quote 0
                                      • strawberry 3.141S Offline
                                        strawberry 3.141 Project Sponsor Module Developer @Littlejohn21
                                        @Littlejohn21 you can try
                                        .MODULENAME {
                                          transform: scale(0.5, 0.5);
                                        if you replace modulename with your actual module name, this should give you a height and with of 50% of the actual size
                                          Follow @strawberry-3-141 instructions. I can’t imagine why your forecast would be huge. I do have a question for you. What position have you assigned to the weatherforecast module in the config?
                                          • L Offline
                                            Littlejohn21
                                            @strawberry-3-141 @Mykle1
                                            im having trouble getting it to accept the line you provided it gives me the syntax error code when starting the program. am i supposed to have it inside the MMM-forecast-io module or in its own spot? ive tried both, tried without the . infront of the module name tried with a space after scale ect.
                                            the position is top left and it takes up alsost 1/2 the top of the screen.
                                            • 3 / 7
