    MMM-dropbox - new module to show Dropbox photos on your mirror!
    16 Posts 6 Posters 7.2k Views 6 Watching
      sdetweil @KamiSchami
      @KamiSchami open the developers window ctrl-shift-i then select the console tab and scroll up to see any errors, usually red text.
      also look at the terminal window log, pm2 --lines=100
      or the messages in the terminal window where u did npm start
        Blakwatch
        I realize this is an old thread, but I tried installing this module and all I get is “Loading…” on the Magic Mirror. Have tried 2 API tokens and several different folders including Dropbox root. No luck. Help?
          sdetweil @Blakwatch
          @blakwatch see the post just before yours for debugging
            Blakwatch @sdetweil
            @sdetweil No errors in developer mode. I have the following in pm2 log:
            0|MagicMir | [07.02.2022 14:51.19.466] [ERROR] Whoops! There was an uncaught exception...
            0|MagicMir | [07.02.2022 14:51.19.472] [ERROR] TypeError: Cannot read properties of undefined (reading 'length')
            0|MagicMir |     at Class.getData (/home/pi/MagicMirror/modules/mmm-dropbox/node_helper.js:54:43)
            0|MagicMir |     at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/mmm-dropbox/node_helper.js:363:18)
            0|MagicMir |     at Socket.<anonymous> (/home/pi/MagicMirror/js/node_helper.js:109:11)
            0|MagicMir |     at Socket.emit (node:events:394:28)
            0|MagicMir |     at Socket.emitUntyped (/home/pi/MagicMirror/node_modules/socket.io/dist/typed-events.js:69:22)
            0|MagicMir |     at /home/pi/MagicMirror/node_modules/socket.io/dist/socket.js:466:39
            0|MagicMir |     at processTicksAndRejections (node:internal/process/task_queues:78:11)
              sdetweil @Blakwatch
              @blakwatch module had trouble getting data don’t know why. open an issue on the module GitHub page…
              • michael5rM Offline
                michael5r Module Developer
                Hi guys - there’s a new version of the module out that should fix the Dropbox API issue. Please try it out and see if it works for you.
