MMM-dropbox - new module to show Dropbox photos on your mirror!
@Stoffbeuteluwe so, its an api usage problem…
Hi, got the app on my mirror all ok. The problem is it tells me the dropbox folder does not exist.
Here is the code, please see if I have gone wrong, left folder blank due to wanting all photos.
module: ‘mmm-dropbox’,
position: ‘top_bar’, // pick whichever position you want
token: ‘<kxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxMJG_o0xxgC>’,
folder: ‘<DROPBOX_FOLDER_NAME>’,
// … and whatever else configuration options you want to use
},Would really like to get this working.
Thank you for looking
@swampy242001 try ‘/’ as the folder
@sdetweil said in MMM-dropbox - new module to show Dropbox photos on your mirror!:
Hi, auch das funktioniert nicht bei mir. Was kann es noch sein? VG
@KamiSchami did u fill in the token field?
I don’t know anything about this module, but my code that reads images from Dropbox continues to work, do the API is still good
Yes, i have the Token.
@KamiSchami open the developers window ctrl-shift-i then select the console tab and scroll up to see any errors, usually red text.
also look at the terminal window log, pm2 --lines=100
or the messages in the terminal window where u did npm start
I realize this is an old thread, but I tried installing this module and all I get is “Loading…” on the Magic Mirror. Have tried 2 API tokens and several different folders including Dropbox root. No luck. Help?
@blakwatch see the post just before yours for debugging
@sdetweil No errors in developer mode. I have the following in pm2 log:
0|MagicMir | [07.02.2022 14:51.19.466] [ERROR] Whoops! There was an uncaught exception... 0|MagicMir | [07.02.2022 14:51.19.472] [ERROR] TypeError: Cannot read properties of undefined (reading 'length') 0|MagicMir | at Class.getData (/home/pi/MagicMirror/modules/mmm-dropbox/node_helper.js:54:43) 0|MagicMir | at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/mmm-dropbox/node_helper.js:363:18) 0|MagicMir | at Socket.<anonymous> (/home/pi/MagicMirror/js/node_helper.js:109:11) 0|MagicMir | at Socket.emit (node:events:394:28) 0|MagicMir | at Socket.emitUntyped (/home/pi/MagicMirror/node_modules/socket.io/dist/typed-events.js:69:22) 0|MagicMir | at /home/pi/MagicMirror/node_modules/socket.io/dist/socket.js:466:39 0|MagicMir | at processTicksAndRejections (node:internal/process/task_queues:78:11) -
@blakwatch module had trouble getting data don’t know why. open an issue on the module GitHub page…
Hi guys - there’s a new version of the module out that should fix the Dropbox API issue. Please try it out and see if it works for you.
