    MMM-dropbox - new module to show Dropbox photos on your mirror!
    16 Posts 6 Posters 7.6k Views 6 Watching
    • michael5rM Offline
      michael5r Module Developer
      Just wanted to share a new module I published recently - it’s called mmm-dropbox and allows you to grab images from a Dropbox folder, have them automatically scaled down and displayed in 1 or more rows on your mirror.
      As I also point out in the Read Me this is a module with a pretty specific focus - it does exactly what I describe above (and does it well), but it doesn’t support stuff like videos, setting a Dropbox image as the background of your mirror, displaying information about the image, etc. I built this for my wife & this is what she wanted - but, hey, there’s no reason you can’t use it on your mirror as well!
      Here’s the repo:
      https://github.com/michael5r/mmm-dropbox
      And here’s a screenshot of what it looks like on the mirror with the default configuration:
      Enjoy!
      • StoffbeuteluweS Offline
        Stoffbeuteluwe Project Sponsor
        Hi the module show only loading since a couple off days
          sdetweil @Stoffbeuteluwe
          @Stoffbeuteluwe open the developers window, ctrl-shift-i, select the tab labeled console in that new window,
          and scroll up to find any errors
            Stoffbeuteluwe Project Sponsor @sdetweil
            @sdetweil Hi, no errors ,the strange thing is …sometime it works sometimes not
              @Stoffbeuteluwe so, its an api usage problem…
                swampy242001
                Hi, got the app on my mirror all ok. The problem is it tells me the dropbox folder does not exist.
                Here is the code, please see if I have gone wrong, left folder blank due to wanting all photos.
                module: ‘mmm-dropbox’,
                position: ‘top_bar’, // pick whichever position you want
                token: ‘<kxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxMJG_o0xxgC>’,
                folder: ‘<DROPBOX_FOLDER_NAME>’,
                // … and whatever else configuration options you want to use
                Would really like to get this working.
                Thank you for looking
                  sdetweil @swampy242001
                  @swampy242001 try ‘/’ as the folder
                  KamiSchamiK 1 Reply Last reply Reply Quote 0
                  • KamiSchamiK Offline
                    KamiSchami @sdetweil
                    @sdetweil said in MMM-dropbox - new module to show Dropbox photos on your mirror!:
                    Hi, auch das funktioniert nicht bei mir. Was kann es noch sein? VG
                    Real programmers never work 9 to 5. If they are around at 9 AM, it's because they were up all night.
                      sdetweil @KamiSchami
                      @KamiSchami did u fill in the token field?
                      I don’t know anything about this module, but my code that reads images from Dropbox continues to work, do the API is still good
                        Yes, i have the Token.
                          @KamiSchami open the developers window ctrl-shift-i then select the console tab and scroll up to see any errors, usually red text.
                          also look at the terminal window log, pm2 --lines=100
                          or the messages in the terminal window where u did npm start
                            Blakwatch
                            I realize this is an old thread, but I tried installing this module and all I get is “Loading…” on the Magic Mirror. Have tried 2 API tokens and several different folders including Dropbox root. No luck. Help?
                              sdetweil @Blakwatch
                              @blakwatch see the post just before yours for debugging
                                Blakwatch @sdetweil
                                @sdetweil No errors in developer mode. I have the following in pm2 log:
                                0|MagicMir | [07.02.2022 14:51.19.466] [ERROR] Whoops! There was an uncaught exception...
                                0|MagicMir | [07.02.2022 14:51.19.472] [ERROR] TypeError: Cannot read properties of undefined (reading 'length')
                                0|MagicMir |     at Class.getData (/home/pi/MagicMirror/modules/mmm-dropbox/node_helper.js:54:43)
                                0|MagicMir |     at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/mmm-dropbox/node_helper.js:363:18)
                                0|MagicMir |     at Socket.<anonymous> (/home/pi/MagicMirror/js/node_helper.js:109:11)
                                0|MagicMir |     at Socket.emit (node:events:394:28)
                                0|MagicMir |     at Socket.emitUntyped (/home/pi/MagicMirror/node_modules/socket.io/dist/typed-events.js:69:22)
                                0|MagicMir |     at /home/pi/MagicMirror/node_modules/socket.io/dist/socket.js:466:39
                                0|MagicMir |     at processTicksAndRejections (node:internal/process/task_queues:78:11)
                                  sdetweil @Blakwatch
                                  @blakwatch module had trouble getting data don’t know why. open an issue on the module GitHub page…
                                    Hi guys - there’s a new version of the module out that should fix the Dropbox API issue. Please try it out and see if it works for you.
