    MMM-dropbox - new module to show Dropbox photos on your mirror!
    16 Posts 6 Posters 7.2k Views 6 Watching
    • StoffbeuteluweS Offline
      Stoffbeuteluwe Project Sponsor
      Hi the module show only loading since a couple off days
        sdetweil @Stoffbeuteluwe
        @Stoffbeuteluwe open the developers window, ctrl-shift-i, select the tab labeled console in that new window,
        and scroll up to find any errors
          Stoffbeuteluwe Project Sponsor @sdetweil
          @sdetweil Hi, no errors ,the strange thing is …sometime it works sometimes not
            @Stoffbeuteluwe so, its an api usage problem…
              swampy242001
              Hi, got the app on my mirror all ok. The problem is it tells me the dropbox folder does not exist.
              Here is the code, please see if I have gone wrong, left folder blank due to wanting all photos.
              module: ‘mmm-dropbox’,
              position: ‘top_bar’, // pick whichever position you want
              token: ‘<kxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxMJG_o0xxgC>’,
              folder: ‘<DROPBOX_FOLDER_NAME>’,
              // … and whatever else configuration options you want to use
              Would really like to get this working.
              Thank you for looking
                sdetweil @swampy242001
                @swampy242001 try ‘/’ as the folder
                KamiSchamiK 1 Reply Last reply Reply Quote 0
                • KamiSchamiK Offline
                  KamiSchami @sdetweil
                  @sdetweil said in MMM-dropbox - new module to show Dropbox photos on your mirror!:
                  Hi, auch das funktioniert nicht bei mir. Was kann es noch sein? VG
                  Real programmers never work 9 to 5. If they are around at 9 AM, it's because they were up all night.
                    sdetweil @KamiSchami
                    @KamiSchami did u fill in the token field?
                    I don’t know anything about this module, but my code that reads images from Dropbox continues to work, do the API is still good
                      Yes, i have the Token.
                        @KamiSchami open the developers window ctrl-shift-i then select the console tab and scroll up to see any errors, usually red text.
                        also look at the terminal window log, pm2 --lines=100
                        or the messages in the terminal window where u did npm start
