    Depreciation Warning
    5 Posts 3 Posters 2.4k Views 2 Watching
    • J
      jhwwhite
      I’ve very new to this, and I’m a little stuck. As far as I can tell I’ve followed all the instructions I could find, but I don’t know what to do from here. Any advice would be appreciated.
      (node:27999) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpdir() instead.
      npm WARN package.json current-week-number@1.0.7 license should be a valid SPDX license expression
      npm WARN package.json rrule-alt@2.2.8 No license field.
      npm WARN package.json valid-url@1.0.9 No license field.
      npm ERR! Error: Method Not Allowed
      npm ERR!     at errorResponse (/usr/share/npm/lib/cache/add-named.js:260:10)
      npm ERR!     at /usr/share/npm/lib/cache/add-named.js:203:12
      npm ERR!     at saved (/usr/share/npm/node_modules/npm-registry-client/lib/get.js:167:7)
      npm ERR!     at FSReqWrap.oncomplete (fs.js:135:15)
      npm ERR! If you need help, you may report this *entire* log,
      npm ERR! including the npm and node versions, at:
      npm ERR!     <http://github.com/npm/npm/issues>
      npm ERR! System Linux 4.14.79-v7+
      npm ERR! command "/usr/bin/node" "/usr/bin/npm" "install"
      npm ERR! cwd /home/pi/MagicMirror
      npm ERR! node -v v8.11.1
      npm ERR! npm -v 1.4.21
      npm ERR! code E405
      npm ERR!
      npm ERR! not ok code 0
      • B
        bhepler Module Developer
        The good news is that the deprecation warning is just that: a warning. It’s more of a notice to the developers that they should move to a different package when building their systems.
        The bad news is that is definitely a bug somewhere. At first blush, it looks like one of the parameters isn’t being passed to the npm registry correctly. Is this during your initial MM install?
        • J
          jhwwhite
          Yes. I’m going to try tor reinstall again. (Although, that didn’t work last time.) Any advice is appreciated.
            A Former User
            I have the same problem.
              A Former User
              I solved this link!
              https://forum.magicmirror.builders/topic/9258/unable-to-install-dependencies/
