    Depreciation Warning
    5 Posts 3 Posters 2.3k Views 2 Watching
      jhwwhite
      I’ve very new to this, and I’m a little stuck. As far as I can tell I’ve followed all the instructions I could find, but I don’t know what to do from here. Any advice would be appreciated.
      (node:27999) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpdir() instead.
      npm WARN package.json current-week-number@1.0.7 license should be a valid SPDX license expression
      npm WARN package.json rrule-alt@2.2.8 No license field.
      npm WARN package.json valid-url@1.0.9 No license field.
      npm WARN deprecated time-grunt@2.0.0: Deprecated because Grunt is practically unmaintained. Move on to something better. This package will continue to work with Grunt v1, but it will not receive any updates.
      npm ERR! Error: Method Not Allowed
      npm ERR!     at errorResponse (/usr/share/npm/lib/cache/add-named.js:260:10)
      npm ERR!     at /usr/share/npm/lib/cache/add-named.js:203:12
      npm ERR!     at saved (/usr/share/npm/node_modules/npm-registry-client/lib/get.js:167:7)
      npm ERR!     at FSReqWrap.oncomplete (fs.js:135:15)
      npm ERR! If you need help, you may report this *entire* log,
      npm ERR! including the npm and node versions, at:
      npm ERR!     <http://github.com/npm/npm/issues>
      npm ERR! System Linux 4.14.79-v7+
      npm ERR! command "/usr/bin/node" "/usr/bin/npm" "install"
      npm ERR! cwd /home/pi/MagicMirror
      npm ERR! node -v v8.11.1
      npm ERR! npm -v 1.4.21
      npm ERR! code E405
      npm ERR!
      npm ERR! Additional logging details can be found in:
      npm ERR!     /home/pi/MagicMirror/npm-debug.log
      npm ERR! not ok code 0
      • bheplerB Offline
        bhepler Module Developer
        The good news is that the deprecation warning is just that: a warning. It’s more of a notice to the developers that they should move to a different package when building their systems.
        The bad news is that is definitely a bug somewhere. At first blush, it looks like one of the parameters isn’t being passed to the npm registry correctly. Is this during your initial MM install?
          jhwwhite
          Yes. I’m going to try tor reinstall again. (Although, that didn’t work last time.) Any advice is appreciated.
            A Former User
            I have the same problem.
              A Former User
              I solved this link!
              https://forum.magicmirror.builders/topic/9258/unable-to-install-dependencies/
