    MM crashing after some hours
    4 Posts 4 Posters 2.3k Views 4 Watching
      Joern
      Hello,
      Iam running magicmirror@2.5.0 with some modules (IP Cam, Google Maps, Wunderlist), but without restart every 6-8 hours the whole PI totally freezes.
      Iam already running conjob to restart MM or even whole PI, but I want to understand to root cause.
      How can I check for this? Do I run out of RAM or what be be cause? (PI 2 with 1GB).
      e.g. after 2 hours:
      pi@raspberrypi:~/MagicMirror $ free -w
      total used free shared buffers cache available
      Mem: 948964 363668 232508 265580 9940 342848 270028
      Swap: 0 0 0
      How can I start to investigate? I see no clear trend that RAM e.g. goes to zero…
      lavolp3L I 2 Replies Last reply Reply Quote 0
      • lavolp3L Offline
        lavolp3 Module Developer @Joern
        @joern You could install a module like MMM-Tools that shows you the used RAM and CPU Temperature.
        There’s also ways to read out the current temperature or used RAM on the Pi using the console.
        You could look for increasing CPU temperatures ( > 75°C) after some time.
        How to troubleshoot modules
        MMM-soccer v2, MMM-AVStock
        • I Offline
          icephreaq @Joern
          @joern is your Pi running at the stock 900mhz or have you clocked it up to 1000mhz? I was running mine with the built in overclock to 1000mhz and having the same issue. Reverted to 900mhz and it runs for months on end.
          • N Offline
            numb3rs
            I was struggling with a crash. I logged the mem usage with SAR
            sudo apt-get install sysstat
            View Info Here
            Then I output to a log every few minutes so if it did crash I could go back through.
            sar -r 1 > somefile.log
            The exact issue I was having was with an iFrame Module iFrame-Ping:
            MMM-iFramePing
            I run a YouTube Playlist - that will eventually bring up the module by voice command.
            //iFrame Module - Contains Fox News Playlist on YouTube - Autoplay - Modest Branding (no logo) - iv Load Policy = 3 (no annotations) - Controls = 0 (no controls shown)
            		module: 'MMM-iFrame-Ping',
            		position: 'top_right',
            		url: "https://www.youtube.com/embed/?listType=playlist&list=PLlTLHnxSVuIyeEZPBIQF_krewJkY2JSwi&index=-1&autoplay=1&modestbranding=1&iv_load_policy=3&controls=0",
            		autoRefresh: true,
            		updateInterval: 120,
            		width: "560px",
            		height: "340px",
            		scrolling: "no"
            The iFrame video was crashing the PI so I decided to increase the swapfile size. Before I increased the size my PI would make it about 2-4 hours. Now I can literally run it for days without an issue.
            sudo nano /etc/dphys-swapfile
            Change CONF_SWAPSIZE=100
            CONF_SWAPSIZE=1024
            Stop/Start the Service
            sudo /etc/init.d/dphys-swapfile stop
            sudo /etc/init.d/dphys-swapfile start
            You can log with SAR or just do
            free -m
            Some people set the swapfile to 0, but others warn against it. If you want to
            CONF_SWAPSIZE=0
