    V2.6.0
    Scheduled Pinned Locked Moved MagicMirror
    1 Posts 1 Posters 6.4k Views 2 Watching
    • MichMichM Offline
      MichMich
      MagicMirror² version 2.6.0 was just released:
      https://github.com/MichMich/MagicMirror/releases/tag/v2.6.0
      A huge, huge, huge thanks to user @fewieden for all his hard work on the new experimental weather module!
      [2.6.0] - 2019-01-01
      ℹ️ Note: This update uses new dependencies. Please update using the following command: git pull && npm install. If you are having issues updating, make sure you are running the latest version of Node.
      ✨ Experimental ✨
      • New default module weather. This module will eventually replace the current currentweather and weatherforecast modules. The new module is still pretty experimental, but it’s included so you can give it a try and help us improve this module. Please give us you feedback using this forum post.
      A huge, huge, huge thanks to user @fewieden for all his hard work on the new weather module!
      Added
      • Possibility to add classes to the cell of symbol, title and time of the events of calendar.
      • Font-awesome 5, still has 4 for backwards compatibility.
      • Missing showEnd in calendar documentation
      • Screenshot for the new feed module
      • Screenshot for the compliments module
      • Screenshot for the clock module
      • Screenshot for the current weather
      • Screenshot for the weather forecast module
      • Portuguese translation for “Feels”
      • Croatian translation
      • Fading for dateheaders timeFormat in Calendar #1464
      • Documentation for the existing scale option in the Weather Forecast module.
      Fixed
      • Allow to parse recurring calendar events where the start date is before 1900
      • Fixed Polish translation for Single Update Info
      • Ignore entries with unparseable details in the calendar module
      • Bug showing FullDayEvents one day too long in calendar fixed
      • Bug in newsfeed when removeStartTags is used on the description #1478
      Updated
      • The default calendar setting showEnd is changed to false.
      Changed
      • The Weather Forecast module by default displays the ° symbol after every numeric value to be consistent with the Current Weather module.
      1 Reply Last reply Reply Quote 11
