    Updating 6db61b4..de57daa
    26 Posts 9 Posters 12.2k Views 9 Watching
      MWel1977 @idoodler
      I have the same problem as @costascontis and will try to delete that file.
      But I also would like to know what the latest version of Node.js is.
      At https://github.com/nodesource/distributions#debinstall I can see a version 11.x.
      my version on the pi 3B+ is v9.11.2
      Is that the latest version or must I update to v11.x via:
      sudo su
      curl -sL https://deb.nodesource.com/setup_11.x | bash -
      apt-get install -y nodejs
        MWel1977 @MWel1977
        Just moved the package-lock.js to a new folder “Old files” and run “sudo git pull && npm install” again and it worked for me.
        I do get some warnings from “time-grunt@2.0.0” and 2 from npm skipping optional dependency’s but below that it reads: MagicMirror installation succesfull! NICE!.. well…that last word isn’t part of the update! Hahaha
        And below that it found 9 vulnerabilities. Is that a problem?
        D idoodlerI 2 Replies Last reply Reply Quote 0
          dazza120 @MWel1977
          @mwel1977 even the calendar as mine is up the swannie
            MWel1977 @dazza120
            @dazza120 I’m not using the standard calendar.
            But after the update my MM2 works like before. Only the modules I’m working on are still not showing correctly…becouse I’m working on them to get them to work properly. :smiling_face_with_open_mouth_cold_sweat: :smiling_face_with_open_mouth_cold_sweat:
            But what do you mean with: “…is up the swannie”?
            you mean it doesn’t work?
              sdetweil
              @mwel1977 said in Updating 6db61b4..de57daa:
              the swannie
              swannie river
              up the river…
              http://www.musicanet.org/robokopp/usa/waydownu.htm
                dazza120 @MWel1977
                @mwel1977 yep UK local slang, anyway I’ve sorted it now I downloaded the Magic Mirror from github on the Pi, unzipped it and then copied the whole folder to the module default location and over wrote everything, it was missing a lot of files for some reason. Anyway enough said it’s working like it should now 👌🏾
                • idoodlerI Offline
                  idoodler Module Developer @MWel1977
                  @mwel1977 The vulnerabilities needs to be fixed by the module developer. Thats not your responsibility, you can just ignore them.
                  Because of the Node.js version: You don’t have to update to a newer version of Node.js. Latest isn’t always the greatest, there are some known compatibility issues with v11.
                    rosenm
                    this one helped me:
                    https://forum.magicmirror.builders/topic/4418/update/3
                    • ScrewyoudriverS Offline
                      Screwyoudriver
                      I renamed the old folder and did a fresh installation. Half an hour of work if you use the old config and css.
                      • I Offline
                        icephreaq
                        I do have an active internet connection. I typically admin my mirror through SSH from a separate Linux machine and I’m able to connect to the mirror and update other items without issue. git status gives the following.
                        On branch master
                        Your branch is behind 'origin/master' by 124 commits, and can be fast-forwarded.
                          (use "git pull" to update your local branch)
                        Changes not staged for commit:
                          (use "git add <file>..." to update what will be committed)
                          (use "git checkout -- <file>..." to discard changes in working directory)
                        	modified:   fonts/package-lock.json
                        	modified:   package-lock.json
                        	modified:   package.json
                        	modified:   vendor/package-lock.json
                        Untracked files:
                          (use "git add <file>..." to include in what will be committed)
                        	core
                        	nohup.out
                        no changes added to commit (use "git add" and/or "git commit -a")
                        • 2 / 3
