    Refresh Hello World module
    3 Posts 2 Posters 5.6k Views 3 Watching
      A Former User
      I am using the Hello World module to display an iFrame on my Magic Mirror. Now I need to refresh the frame every minute, but its not working and my js skills are not really good. It only needs to refresh this:
      Thanks for every help!
      Module.register(“helloworld”,{
          // Default module config.
          defaults: {
                  text: "Hello World!"
          // Override dom generator.
          getDom: function() {
                  wrapper.innerHTML = this.config.text;
                  return wrapper;
      • Y
        yawns Moderator
        simplest way is to create a new module. So you don’t run into update problems in the future if someone changes the original hello world module.
        Copy the whole helloworld folder from modules/default/ to modules/ and rename it to something different, lets say “mmm-iframe”.
        1. Rename the folder itself to mmm-iframe
        2. Rename the helloworld.js file to mmm-iframe.js
        Then overwrite the content of mmm-iframe.js with this:
        /* global Module */
        /* Magic Mirror
         * Module: mmm-iframe
         * MIT Licensed.
        Module.register("mmm-iframe",{
        	defaults: {
        		text: "Hello World!",
        		animationSpeed: 1000,
        	start: function() {
        		Log.info('Starting module: ' + this.name);
        		var self = this;
        		setInterval(function() {
        			self.updateDom();
        		}, this.config.animationSpeed);
        		return wrapper;
        1. Now update your config file and replace the helloworld entry to load the mmm-iframe module instead.
        I did not test this, I don’t have a magicmirror available currently, but this should get you going.
          A Former User @yawns
          Thanks for your answer,
          I think there is a problem with the MMM-ModuleScheduler. When the frame is hidden your version is refreshing good, but when it is visible, it is stopping. Maybe it will not work together…
