Adafruit IO Module
Looking for an Adafruit IO module. I’d like to post information from my feeds directly on my Magic Mirror. I have multiple sensors that feed into my account that I would love to see on the mirror. Anyone have information on this or could provide some direction?
Thanks!
Seconded.
Have tried with MMM-MQTT and MMM-mqtt modules, but can’t connect to my adafruitIO feeds. -
Update: managed to achieve this with MMM-mqtt (lower case) module.
I think that MMM-MQTT connects with mqtt://io.adafruit.com… even if you specify 8883 port (when using SSL). With the MMM-mqtt module you can set the URL it connects with, and specify mqtts://io.adafruit.com… -
Any chance you could post your config.js file minus private stuff? Or just the mqtt portion? I tried to do but went different path. Tried using iframe and that didn’t work at all.
Absolutely:
module: "MMM-mqtt", position: "bottom_right", header: "Garage rear door", config: { mqttServer: "mqtts://username:key@io.adafruit.com:8883", topic: "username/feeds/feed-name", loadingText: "waiting for event...", interval: 60000, }Obviously replacing username, key and feed-name.
I am having an issue currently with the mirror showing “MQTT server is offline” after a short time and mirror is not picking up any new messages published :(Hope that helps.
