    MM Modules except MMM-RTSP don't show after several days of use.
    10 Posts 4 Posters 3.3k Views 4 Watching
    • swvalentiS Offline
      swvalenti Project Sponsor
      Like the title says I am using a RPi 3b+ 16gb class 10 card with Raspbian Stretch (latest desktop version). I use modules, doomsday, eyecandy, news, noaa3, remote control, rtsp stream and sonos. All is fine for several days then when I go to my bar to see mirror just the rtsp stream is running on mirror and no other modules. I have to use remote control to restart MM to bring all modules back to running than days later it happens again. Any ideas on what issue could be or where to look for issues and post for help?
      • BKeyportB Offline
        BKeyport Module Developer
        Honestly, I would bet that it’s (through no fault of the author’s) the video feed just blowing everything up. Are you using RTSP with OMXPlayer?
        I ended up going back to the legacy driver for video, using MMFPEG, and restarting MM every 2 hours to get it stable.
        swvalentiS 1 Reply Last reply Reply Quote 0
          swvalenti Project Sponsor @BKeyport
          @bkeyport Yes I am using RTSP OMX. Do you mind telling me how I can schedule MM to restart on X hours?
            dazza120 @swvalenti
            @swvalenti cron job on the raspberry pi
            0 2 * * * pm2 restart mm
            That will make the mirror restart from scratch as if you just stated the mirror
              swvalenti Project Sponsor @dazza120
              @dazza120 said in MM Modules except MMM-RTSP don't show after several days of use.:
              thank you sir
              • BKeyportB Offline
                Actually:
                0 */2 * * * pm2 restart mm
                https://crontab.guru/every-2-hours
                  dazza120 @BKeyport
                  @bkeyport yes correct mine is every time at 2in the morning oops 😬
                    Weird thing is when I have my monitor on all is fine, but what I turn my monitor off is when the modules die out. I don’t always keep the monitor on as it’s in my bar…what could cause this to crash when monitor is off?
                      Its not the screen from going to sleep as I added the lines to disable that…any ideas?
                      • V Offline
                        vonarstonehelm
                        Out of curiosity what did you do to get the MMM- RTSP to work? I ended up giving up on this project due to it not working for me.
                        Thank you
