    Can't start MM as kiosk only server
    13 Posts 4 Posters 5.4k Views 3 Watching
    • W
      Warmyster
      Hi all, I’m new here so please help me out.
      I’m building my first mirror. Got a new Pi 3B+ and installed everything from scratch. sound and usb mic is working. I’ve added MMM-AssistantMk2 & Hotword with basic default settings. The problem is it will only run in serveronly mode and it works when I use my browser.
      But when i use npm start I get the following error:
      pi@raspi:~/MagicMirror $ npm start
      magicmirror@2.6.0 start /home/pi/MagicMirror
      sh run-start.sh
      Starting MagicMirror: v2.6.0
      Loading config …
      Loading module helpers …
      Initializing new module helper …
      WARNING! Could not load config file. Starting with default configuration. Error found: Error: Failed to load gRPC binary module because it was not installed for the current system
      Expected directory: electron-v2.0-linux-arm-glibc
      Found: [electron-v4.0-linux-arm-glibc, node-v67-linux-arm-glibc]
      This problem can often be fixed by running “npm rebuild” on the current system
      Original error: Cannot find module ‘/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/node/extension_binary/electron-v2.0-linux-arm-glibc/grpc_node.node’
      App threw an error during load
      at Object. (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/grpc_extension.js:53:17)
      at Object. (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/grpc_extension.js:63:3)
      at Module._compile (module.js:642:30)
      at Object.Module._extensions…js (module.js:653:10)
      at Module.load (module.js:561:32)
      at tryModuleLoad (module.js:504:12)
      at Function.Module._load (module.js:496:3)
      at Module.require (module.js:586:17)
      at require (internal/module.js:11:18)
      at Object. (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:144:12)
      Whoops! There was an uncaught exception…
      { Error: Failed to load gRPC binary module because it was not installed for the current system
      at Object. (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/client_interceptors.js:144:12) code: ‘MODULE_NOT_FOUND’ }
      Launching application.
      • B
        bhepler Module Developer
        For starters, please use the markdown features when posting code & logs.
        Secondly, did you take the error message’s advice and run npm rebuild in the MMM-AssistantMk2 folder? Did it help?
        • W
          Warmyster
          Hi thanks.
          I’ve done npm rebuild and audit fix same error come up. The application launch but only a black screen and I have to Kill the process.
          • lavolp3L
            lavolp3 Module Developer
            @warmyster said in Can't start MM as kiosk only server:
            It seems that some module inside MMM-AssistantMk2 is compiled against electron v2.0. If above suggestion does not work I would recommend installing the whole module again. Delete the folder, do a git clone, git pull and npm install again.
            How to troubleshoot modules
            MMM-soccer v2, MMM-AVStock
            • lavolp3L
              lavolp3 Module Developer @Warmyster
              @warmyster Or try disabling MMM-AssistantMk2 and run MM again.
              • W
                Warmyster @lavolp3
                @lavolp3 It works when I don’t include the module. Ill try re installing it again
                • W
                  Warmyster @lavolp3
                  @lavolp3
                  I’ve done a reinstall (deleted the directory and did git clone) and this is what I got after install but still getting the same error
                  pi@raspi:~/MagicMirror/modules/MMM-AssistantMk2 $ npm install
                  grpc@1.18.0 install /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc
                  node-pre-gyp install --fallback-to-build --library=static_library
                  node-pre-gyp WARN Using request for node-pre-gyp https download
                  [grpc] Success: “/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/node/extension_binary/node-v67-linux-arm-glibc/grpc_node.node” is installed via remote
                  protobufjs@6.8.8 postinstall /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/protobufjs
                  node scripts/postinstall
                  npm notice created a lockfile as package-lock.json. You should commit this file.
                  added 273 packages from 186 contributors and audited 635 packages in 64.238s
                  found 0 vulnerabilities
                  • lavolp3L
                    well… looks good doesn’t it? Should work now.
                    • W
                      Warmyster @lavolp3
                      @lavolp3
                      NO its giving the same error
                      • lavolp3L
                        @warmyster if it is still about this module, maybe @Sean can help since it’s his module
                        • W
                          Warmyster @lavolp3
                          @lavolp3
                          Thanks I got hold of @Sean and he helped me sort if out. Turns out I didnt rebuild the packages correctly :(
                          • B
                            Great. I’m glad you got your module working. Can you post the steps you took here?
                            • A
                              aub @Warmyster
                              @warmyster Can you expand or link the conversation with Sean… Have been strugling with this for hours now.
