    Can't start MM as kiosk only server
    13 Posts 4 Posters 4.6k Views 3 Watching
    • bheplerB Offline
      bhepler Module Developer
      For starters, please use the markdown features when posting code & logs.
      Secondly, did you take the error message’s advice and run npm rebuild in the MMM-AssistantMk2 folder? Did it help?
      • W Offline
        Warmyster
        Hi thanks.
        I’ve done npm rebuild and audit fix same error come up. The application launch but only a black screen and I have to Kill the process.
        • lavolp3L Offline
          lavolp3 Module Developer
          @warmyster said in Can't start MM as kiosk only server:
          App threw an error during load
          Error: Failed to load gRPC binary module because it was not installed for the current system
          Expected directory: electron-v2.0-linux-arm-glibc
          Found: [electron-v4.0-linux-arm-glibc, node-v67-linux-arm-glibc]
          It seems that some module inside MMM-AssistantMk2 is compiled against electron v2.0. If above suggestion does not work I would recommend installing the whole module again. Delete the folder, do a git clone, git pull and npm install again.
          How to troubleshoot modules
          MMM-soccer v2, MMM-AVStock
          • lavolp3L Offline
            lavolp3 Module Developer @Warmyster
            @warmyster Or try disabling MMM-AssistantMk2 and run MM again.
            • W Offline
              Warmyster @lavolp3
              @lavolp3 It works when I don’t include the module. Ill try re installing it again
              • W Offline
                Warmyster @lavolp3
                @lavolp3
                I’ve done a reinstall (deleted the directory and did git clone) and this is what I got after install but still getting the same error
                pi@raspi:~/MagicMirror/modules/MMM-AssistantMk2 $ npm install
                grpc@1.18.0 install /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc
                node-pre-gyp install --fallback-to-build --library=static_library
                node-pre-gyp WARN Using request for node-pre-gyp https download
                [grpc] Success: “/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/node/extension_binary/node-v67-linux-arm-glibc/grpc_node.node” is installed via remote
                protobufjs@6.8.8 postinstall /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/protobufjs
                node scripts/postinstall
                npm notice created a lockfile as package-lock.json. You should commit this file.
                added 273 packages from 186 contributors and audited 635 packages in 64.238s
                found 0 vulnerabilities
                • lavolp3L Offline
                  well… looks good doesn’t it? Should work now.
                  • W Offline
                    Warmyster @lavolp3
                    @lavolp3
                    NO its giving the same error
                    • lavolp3L Offline
                      @warmyster if it is still about this module, maybe @Sean can help since it’s his module
                      • W Offline
                        Warmyster @lavolp3
                        @lavolp3
                        Thanks I got hold of @Sean and he helped me sort if out. Turns out I didnt rebuild the packages correctly :(
