    London Bus status
    27 Posts 4 Posters 20.0k Views 3 Watching
      soqueen
      HI there! One of the newest updates took off the heading for my multiple instances. It only puts a header on the first one. I tried adding a header in the config.js file but it ignors it. Help please?
      nwoottonN 1 Reply Last reply Reply Quote 0
      • nwoottonN Offline
        nwootton Module Developer @soqueen
        @soqueen mmm weird, didn’t do that for me in testing. I’ll have a look later when I get home.
          soqueen
          updated and now even the first one is missing. :)
          nwoottonN 2 Replies Last reply Reply Quote 0
          • nwoottonN Offline
            @soqueen I’ve just hacked a fix together. Give it a try and let me know.
            • nwoottonN Offline
              @soqueen I’ve just noticed some weird behaviour this end while trying to fix this. Did you update your Mirror to 2.1.1? If so did you then do a new npm install afterwards?
              I ask because on one box the departures now shows no header at all, while the other now shows both departures AND the bus stop name…
                soqueen
                I re-ran the npm install just in case I hadn’t done it before, and then pulled your update. Now the headers are back! Thanks!
                • nwoottonN Offline
                  @soqueen TBH I rolled the master branch back to an earlier version that worked and branched the version with the bus stop name as the header.
                  Once I get the last couple of issues in that branch version sorted I’ll role it back into the master. If you want to try it and give me feedback, the branch is called HeadersIssue.
