    London Bus status
    27 Posts 4 Posters 21.5k Views 3 Watching
    • strawberry 3.141S
      your module has a node_helper
      if there are 3 instances in the config of this module, all 3 share the same node_helper and therefore get the same socketnotifications
      workaround that some users have done is copy the module folder and named it modulename2 also changed the modulename.js to modulename2.js and in the js file the string from modulename to modulename2. this will create a node_helper for modulename and one for modulename2
      what a dev could do is the following, have the updateinterval in the module which is sending the requesturl to the nodehelper, so every instance sends it and gets executed and then you send the result back to the module and also for which station this request was performed, then you check in the module if the result is based on the station of this instance then process the data otherwise ignore that socketnotification.
      nwoottonN 1 Reply Last reply
      • nwoottonN
        nwootton Module Developer @strawberry 3.141
        @strawberry-3.141 If I get the chance I’ll look at passing an identity to the helper so it knows where to route the response back to.
          soqueen
          Hm. I tried that. I copied the module and contents to modulename2, changed the .js to 2.js - edited the 2.js to (module.register) to modulename2 .
          Then I changed my config file - copied the first module to another instance and changed its name to modulename2. (then i changed the atcocode for a new bus stop). --It’s stuck on loading bus info…
          • nwoottonN
            nwootton Module Developer @soqueen
            @soqueen I’ve just pushed a new version that hopefully allows you to have multiple instances of the module running. It’s been working happily this afternoon running three different bus stops around the area with no complaints.
            You’ll need to do a git pull to update, then run the
            cd MMM-UKLiveBusStopInfo
            npm install
            to install the new dependencies.
            Give it a try and let me know. If it goes pear-shaped I can always roll the old version back and look again later.
              soqueen
              It works! Thank you SO VERY much! I really appreciate it! Thank you!
                soqueen
                HI there! One of the newest updates took off the heading for my multiple instances. It only puts a header on the first one. I tried adding a header in the config.js file but it ignors it. Help please?
                • nwoottonN
                  @soqueen mmm weird, didn’t do that for me in testing. I’ll have a look later when I get home.
                    soqueen
                    updated and now even the first one is missing. :)
                    nwoottonN 2 Replies Last reply
                    • nwoottonN
                      @soqueen I’ve just hacked a fix together. Give it a try and let me know.
                      • nwoottonN
                        @soqueen I’ve just noticed some weird behaviour this end while trying to fix this. Did you update your Mirror to 2.1.1? If so did you then do a new npm install afterwards?
                        I ask because on one box the departures now shows no header at all, while the other now shows both departures AND the bus stop name…
                          soqueen
                          I re-ran the npm install just in case I hadn’t done it before, and then pulled your update. Now the headers are back! Thanks!
                          • nwoottonN
                            @soqueen TBH I rolled the master branch back to an earlier version that worked and branched the version with the bus stop name as the header.
                            Once I get the last couple of issues in that branch version sorted I’ll role it back into the master. If you want to try it and give me feedback, the branch is called HeadersIssue.
