    London Bus status
    27 Posts 4 Posters 21.4k Views 3 Watching
      soqueen
      HI there! Thanks so much for tackling this. I seem to be a mess and can’t get it to load. There must be some mistake in my config file as I get the error upon loading. I have checked off all the boxes in the troubleshooting - as in I have an app_id, app_key and I know the atcocode - I have verified all against the live api docs and it runs without error. I will try to load my config entry and see if you guys can help me spot what I entered wrong. Thanks in advance!!0_1491816537498_config-file.jpg
      nwoottonN strawberry 3.141S 2 Replies Last reply
      • nwoottonN
        nwootton Module Developer @soqueen
        @soqueen I’d normally copy and paste the code into either my config or into jsonlint.com to check it’s validity. But, as you’ve posted a picture not a snippet, I can’t do that, so if I type it, it will not be the same as yours!
        However, first glance you’ve got a ‘//’ on your header row (far left), nothing else stands out as being wrong.
        Try pasting the entire config.js into jsonlint.com. That will tell you if the file is properly formed and highlight any errors.
        If that comes back ok, try removing everything except the bus stop module and see if it still fails. If it does paste the reduced config and we’ll see what we can do next.
        • strawberry 3.141S
          strawberry 3.141 Project Sponsor Module Developer @soqueen
          @soqueen there is a comma missing after limit: 5
          nwoottonN 1 Reply Last reply
            soqueen
            That certainly helped! The code loads now and now it’s stuck on Loading bus info… time to recheck my api codes?
            • nwoottonN
              nwootton Module Developer @strawberry 3.141
              @strawberry-3.141 good catch!
                soqueen
                Thank you both! I have gotten it up and running! Looks GREAT!
                  soqueen
                  @nmootton Hi there! Thank you for being so responsive! I had another question. I actually want to load 3 of these. I tried loading the module three separate times, but it just loads 3 of the initial entry, even though the atcocodes are different for each one. Any suggestions?
                  • nwoottonN
                    @soqueen I have to say I’ve never considered it. Both this and the rail version were something I built more as an experiment than anything else. I’m not even sure I’d know how to handle multiple instances of a module.
                    I’ll have to have a think/read and see how it could be done. Perhaps other more experienced devs may be able to chip in here?
                    I will say that running three of these could get expensive in terms of api calls per day… if you use the next bus capability that would be 30 points per call or a max of 33 calls per day (~ every 45 minutes), which might not be enough to make the module really useful. You could get three distinct API keys I guess, but I’m not sure how TransportAPI would view that!
                    I did consider some form of time range, but again it wasn’t something I needed for the experiment. Perhaps I need to find some time to reconsider that as an option!
                    • strawberry 3.141S
                      your module has a node_helper
                      if there are 3 instances in the config of this module, all 3 share the same node_helper and therefore get the same socketnotifications
                      workaround that some users have done is copy the module folder and named it modulename2 also changed the modulename.js to modulename2.js and in the js file the string from modulename to modulename2. this will create a node_helper for modulename and one for modulename2
                      what a dev could do is the following, have the updateinterval in the module which is sending the requesturl to the nodehelper, so every instance sends it and gets executed and then you send the result back to the module and also for which station this request was performed, then you check in the module if the result is based on the station of this instance then process the data otherwise ignore that socketnotification.
                      • nwoottonN
                        @strawberry-3.141 If I get the chance I’ll look at passing an identity to the helper so it knows where to route the response back to.
                          soqueen
                          Hm. I tried that. I copied the module and contents to modulename2, changed the .js to 2.js - edited the 2.js to (module.register) to modulename2 .
                          Then I changed my config file - copied the first module to another instance and changed its name to modulename2. (then i changed the atcocode for a new bus stop). --It’s stuck on loading bus info…
                          • nwoottonN
                            @soqueen I’ve just pushed a new version that hopefully allows you to have multiple instances of the module running. It’s been working happily this afternoon running three different bus stops around the area with no complaints.
                            You’ll need to do a git pull to update, then run the
                            cd MMM-UKLiveBusStopInfo
                            npm install
                            to install the new dependencies.
                            Give it a try and let me know. If it goes pear-shaped I can always roll the old version back and look again later.
                              soqueen
                              It works! Thank you SO VERY much! I really appreciate it! Thank you!
                                soqueen
                                HI there! One of the newest updates took off the heading for my multiple instances. It only puts a header on the first one. I tried adding a header in the config.js file but it ignors it. Help please?
                                • nwoottonN
                                  @soqueen mmm weird, didn’t do that for me in testing. I’ll have a look later when I get home.
                                    soqueen
                                    updated and now even the first one is missing. :)
                                    nwoottonN 2 Replies Last reply
                                    • nwoottonN
                                      @soqueen I’ve just hacked a fix together. Give it a try and let me know.
                                      • nwoottonN
                                        @soqueen I’ve just noticed some weird behaviour this end while trying to fix this. Did you update your Mirror to 2.1.1? If so did you then do a new npm install afterwards?
                                        I ask because on one box the departures now shows no header at all, while the other now shows both departures AND the bus stop name…
                                          soqueen
                                          I re-ran the npm install just in case I hadn’t done it before, and then pulled your update. Now the headers are back! Thanks!
                                          • nwoottonN
                                            @soqueen TBH I rolled the master branch back to an earlier version that worked and branched the version with the bus stop name as the header.
                                            Once I get the last couple of issues in that branch version sorted I’ll role it back into the master. If you want to try it and give me feedback, the branch is called HeadersIssue.
