    London Bus status
    27 Posts 4 Posters 21.0k Views 3 Watching
      soqueen
      Like the London Tube status, it would be great to see the status of the London bus (optional configuration of bus lines /and/or configuration of bus stop timings)
      TFL has great api’s out there if anyone is willing to tackle this. For now I am pulling a webpage into helloworld to view it, but am having refresh issues.
        Porkiddo
        I’m attacking that one with my brother, we already have the code running in html perfect but I had to stop to learn how to create a module now. I never did anything like it so its taking some time.
          soqueen @Porkiddo
          @Porkiddo Perfect! Thanks for tackling it! I would love to use it when you are finished! Thanks!
          • nwoottonN Offline
            nwootton Module Developer
            Try this - it’s based on a specific bus stop ATCOCode
            https://github.com/nwootton/MMM-UKLiveBusStopInfo
              Porkiddo
              It look good but it doens’t load. Any idea?
              • nwoottonN Offline
                @Porkiddo
                Do you have an account set up at Transportapi.com?
                Do you have an app_id and app_key set up?
                Do you know the ATCOCode for the bus stop?
                If you use the live api documentation here and put in the info you want to use does it respond without an error?
                Is the info in your config the same as that you’ve used successfully in the live api docs?
                Nick
                • nwoottonN Offline
                  @Porkiddo
                  Just Had a look at the Bus stop module again. When it’s used with certain other modules, it appears to error when trying to render the DOM.
                  I managed to get it to fall over when used in conjunction with the commute module. I can see the data is coming in, I can see the params are correct, but an ‘appendChild’ error is being thrown when it tries to draw it on screen.
                  I’ll investigate more tomorrow and see if I can figure it out.
                  Nope I’m an idiot… the issue was a wrong location in my config “bottom_middle” instead of “bottom_center”
                  N
                    soqueen
                    HI there! Thanks so much for tackling this. I seem to be a mess and can’t get it to load. There must be some mistake in my config file as I get the error upon loading. I have checked off all the boxes in the troubleshooting - as in I have an app_id, app_key and I know the atcocode - I have verified all against the live api docs and it runs without error. I will try to load my config entry and see if you guys can help me spot what I entered wrong. Thanks in advance!!0_1491816537498_config-file.jpg
                    nwoottonN strawberry 3.141S 2 Replies Last reply Reply Quote 0
                    • nwoottonN Offline
                      nwootton Module Developer @soqueen
                      @soqueen I’d normally copy and paste the code into either my config or into jsonlint.com to check it’s validity. But, as you’ve posted a picture not a snippet, I can’t do that, so if I type it, it will not be the same as yours!
                      However, first glance you’ve got a ‘//’ on your header row (far left), nothing else stands out as being wrong.
                      Try pasting the entire config.js into jsonlint.com. That will tell you if the file is properly formed and highlight any errors.
                      If that comes back ok, try removing everything except the bus stop module and see if it still fails. If it does paste the reduced config and we’ll see what we can do next.
                      • strawberry 3.141S Offline
                        strawberry 3.141 Project Sponsor Module Developer @soqueen
                        @soqueen there is a comma missing after limit: 5
                        nwoottonN 1 Reply Last reply Reply Quote 1
                          soqueen
                          That certainly helped! The code loads now and now it’s stuck on Loading bus info… time to recheck my api codes?
                          • nwoottonN Offline
                            nwootton Module Developer @strawberry 3.141
                            @strawberry-3.141 good catch!
                              soqueen
                              Thank you both! I have gotten it up and running! Looks GREAT!
                                soqueen
                                @nmootton Hi there! Thank you for being so responsive! I had another question. I actually want to load 3 of these. I tried loading the module three separate times, but it just loads 3 of the initial entry, even though the atcocodes are different for each one. Any suggestions?
                                nwoottonN 1 Reply Last reply Reply Quote 0
                                • nwoottonN Offline
                                  @soqueen I have to say I’ve never considered it. Both this and the rail version were something I built more as an experiment than anything else. I’m not even sure I’d know how to handle multiple instances of a module.
                                  I’ll have to have a think/read and see how it could be done. Perhaps other more experienced devs may be able to chip in here?
                                  I will say that running three of these could get expensive in terms of api calls per day… if you use the next bus capability that would be 30 points per call or a max of 33 calls per day (~ every 45 minutes), which might not be enough to make the module really useful. You could get three distinct API keys I guess, but I’m not sure how TransportAPI would view that!
                                  I did consider some form of time range, but again it wasn’t something I needed for the experiment. Perhaps I need to find some time to reconsider that as an option!
                                    your module has a node_helper
                                    if there are 3 instances in the config of this module, all 3 share the same node_helper and therefore get the same socketnotifications
                                    workaround that some users have done is copy the module folder and named it modulename2 also changed the modulename.js to modulename2.js and in the js file the string from modulename to modulename2. this will create a node_helper for modulename and one for modulename2
                                    what a dev could do is the following, have the updateinterval in the module which is sending the requesturl to the nodehelper, so every instance sends it and gets executed and then you send the result back to the module and also for which station this request was performed, then you check in the module if the result is based on the station of this instance then process the data otherwise ignore that socketnotification.
                                    • nwoottonN Offline
                                      @strawberry-3.141 If I get the chance I’ll look at passing an identity to the helper so it knows where to route the response back to.
                                        soqueen
                                        Hm. I tried that. I copied the module and contents to modulename2, changed the .js to 2.js - edited the 2.js to (module.register) to modulename2 .
                                        Then I changed my config file - copied the first module to another instance and changed its name to modulename2. (then i changed the atcocode for a new bus stop). --It’s stuck on loading bus info…
                                        • nwoottonN Offline
                                          @soqueen I’ve just pushed a new version that hopefully allows you to have multiple instances of the module running. It’s been working happily this afternoon running three different bus stops around the area with no complaints.
                                          You’ll need to do a git pull to update, then run the
                                          cd MMM-UKLiveBusStopInfo
                                          npm install
                                          to install the new dependencies.
                                          Give it a try and let me know. If it goes pear-shaped I can always roll the old version back and look again later.
                                            soqueen
                                            It works! Thank you SO VERY much! I really appreciate it! Thank you!
