    Magic mirror not starting on boot
    2 Posts 2 Posters 848 Views 2 Watching
      seedhe
      I installed MM from the bash command on the magic mirror 2 homepage a few weeks ago. It was working great for a few days, a restart would bring MM back up once it loaded. I finally got around to building the actual enclosure and mirror last night. Plugged everything in and started up the Pi and nothing, Raspbian loads up but no MM. Instead of troubleshooting I did a fresh install of OS and MM. Starts after install but after a reboot nothing. I’ve tried again multiple times with different sd cards and different Pi’s but the same result everytime. Sometimes I can manually load up MM from command prompt but sometimes it doesn’t work at all. Any idea what I’m doing wrong here? Speed Test Scrabble Word Finder Solitaire
        dazza120 @seedhe
        @seedhe you need to do a pm2 install script I’ll see if I can find it, seee link https://www.magicmirrorcentral.com/complete-raspberry-pi-magic-mirror-tutorial/
