    Mobile app (bachelor thesis)
    116 Posts 31 Posters 176.7k Views 31 Watching
    • yawnsY Offline
      yawns Moderator @strawberry 3.141
      @strawberry-3-141
      This one?
      Hey Mate,
      thank you for filling out my survey, I really appreciate that.
      Now it’s time for the first prototype.
      Features:
      • Pairing: To pair your phone with your mirror, you have to scan the qr-code which will appear for a minute on the mirror.
      • Pull-to-Refresh: Once you paired your phone it’s time to get data in modules(available, installed) and region(this will override all changes you have done and not synced to the mirror yet).
      • Edit Modules: You can remove, reorder and edit modules. After you’re done it’s time to sync your changes to the mirror.
      • Sync: This will override your config.js file on the mirror. You have to restart your mirror manually.
      Explanation of types:
      • Object: {}
      • Array: []
      • Integer: Numbers like 1, 3, 17, etc.
      • Float: Numbers like 1.25, 3.45, etc.
      • String: “This is just a text.”
      • Boolean: true, false
      Installation:
      • First you have to install the module from here:
        https://github.com/fewieden/MMM-Mobile
      • Then install the app on your phone.
      • Finally restart your mirror.
      If you get in trouble or found a bug please submit an issue on github(don’t forget to name your phone os), so everyone can benefit from it. But it’s also possible to send me an email in english or german.
      Kind Regards,
      Felix
      strawberry 3.141S 1 Reply Last reply Reply Quote 1
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @yawns
        Thanks @yawns I believe this was the first out of 3 emails I sent.
        • yawnsY Offline
          yawns Moderator
          You are right. The other two mails contain change logs
            achillealb
            Where can i find the Android App?
              sdetweil @achillealb
              @achillealb u have to send the author your email address in a private message. see back a few posts.
              android only
                achillealb @strawberry 3.141
                @strawberry-3-141 said in Mobile app (bachelor thesis):
                I sent the app to all that have sent me their emails in a private message. Here are also two screenshots that I extracted from my thesis.
                Android app is still available?
                • 8
                • 9
                • 10
                • 11
                • 12
                • 12 / 12
