Module MMM-Traffic is not displayed
5 Posts 2 Posters 1.9k Views 2 Watching
  • K Offline
    Klinge
    Hello,
    I have some problems wird the module MMM-Traffic.
    I installed it and in my config.js file I inserted the following example config from the git hub site https://github.com/SamLewis0602/MMM-Traffic
    	module: 'MMM-Traffic',
    	position: 'top_left',
    	classes: 'dimmed medium', //optional, default is 'bright medium', only applies to commute info not route_name
    		api_key: 'your_apikey_here',
    		mode: 'driving',
    		origin: '4 Pennsylvania Plaza, New York, NY 10001',
    		destination: '1 MetLife Stadium Dr, East Rutherford, NJ 07073',
    		mon_destination: '116th St & Broadway, New York, NY 10027',
    		fri_destination: '1 E 161st St, Bronx, NY 10451',
    		arrival_time: '0800', //optional, but needs to be in 24 hour time if used.
    		route_name: 'Home to Work',
    		changeColor: true,
    		showGreen: false,
    		limitYellow: 5, //Greater than 5% of journey time due to traffic
    		limitRed: 20, //Greater than 20% of journey time due to traffic
    		traffic_model: 'pessimistic',
    		interval: 120000 //2 minutes
    I added my API-Key from Google Maps Directions API. I use the “Directions API” from the Google Cloud Platform.
    So, when I start my MM, there are no Informations from this module.
    I have installed the MMM-GoogleMapsTraffic too. In this module I am using the “Maps JavaScript API”. And this module work fine. But this API doesn´t work with the module MMM-Traffic.
    I am not sure, if I use the correct API. Maybe there is another problem.
    Unfortunately, I do not remember what else I can do.
    It would be great if anyone of you could help me.
    Thank you in advance.
    Lars
      sdetweil
      in case the module is having some trouble, try this
      start the MM like this
      npm start dev
      then in the developers window, select the console tab…
      check for any errors (red text) and fix those…
      let us know
      • K Offline
        Klinge
        Thank you for your help.
        I started it like your recommendation and I got an error message. I saved the log-Files. But maybe a screenshot could help you.
        If you need the log Files please let me know.
        Thank you in advance again
        Lars
        S 1 Reply Last reply Feb 3, 2019, 6:42 PM Reply Quote 0
          sdetweil @Klinge
          @klinge look at you folder names
          • K Offline
            Klinge
            Oh my god. What a stupid error. I installed the module in den /MagicMirror folder.
            Again a Layer 8 problem.
            Excuse me for wasting your time.
            But I’m so thankful to you. :-)
