    Default Calendar module // request to show events only if start date > today + 2 days
    10 Posts 3 Posters 3.3k Views 4 Watching
      bolish
      Is there a way to make the calendar events show only when they are after after a certain number of days?
      Let’s say, do not show an event if date is < today + 2 days.
      I tried to use the ExcludedEvents + FilterBy “until” but didn’t worked.
      Also looked at modifying the calendar or fetcher.js but sounds like a bad idea…
      Regards
      Regards
      • G Offline
        ganget
        you can try to use this
        				fetchInterval: 60000,
        				maximumEntries: 15, // you can also change this to 2 to have the first 2 entries only
        				maximumNumberOfDays: 365, //change this to 2 it should limit the max number of days in the future to 2
        				animationSpeed: 0,
        				fadePoint: 3,
        				timeFormat: 'absolute',
        				dateformat: 'dddd Do MMM',
        				urgency: 3,
        				calendars:
        Let me know if it works out
          bolish
          hi @ganget
          Thanks for prompt reply.
          Maybe there is a misunderstanding as I can’t figure out what is forcing the calendar to start in 2 days only in your calendar.
          Your code will allow me to block max entries to 15 or to a certain number of days (365 or 2 or whatever) but not allow me to hide event from today + the day after.
          Let me try to rephrase my need : I need the calendar to hide (to not show) the 2 first days of event.
          Or maybe I missed something in your code.
          • G Offline
            ganget
            No you did not miss anything in my code i just misinterpreted your question. Sorry for that here is another idea that could work. Maybe the continue statement will help you to skip the 2 first entries of the calendar. You will need to change the module code for that to work.
              bolish
              @ganget
              no problem. thanks for the idea.
              I was thinking about modifying the module code to change “today’s” date into “today’s date +2” but can’t yet figure out how too.
                sdetweil @bolish
                @bolish
                the existing code is.
                	if (event.startDate >= new Date()) {
                and ideas on how to add days to today or whatever
                https://stackoverflow.com/questions/3818193/how-to-add-number-of-days-to-todays-date
                  bolish
                  Thanks, I will give it a try this evening and keep you guys posted.
                    bolish
                    Hi again, I just tried by modifying the createEventList “today” and “now” variable, but it didn’t work…
                    createEventList: function () {
                    		var events = [];
                    		var someDate = new Date();
                    		var numberOfDaysToAdd = 6;
                    		someDate.setDate(someDate.getDate() + numberOfDaysToAdd);
                    		var today = moment(someDate).startOf("day");
                    		var now = someDate;
                    		for (var c in this.calendarData) {
                      sdetweil @bolish
                      @bolish close…
                      the existing loop takes ALL events, just checking to see if each event is TODAY (sets a flag)
                      to eliminate them you need one more test (in addition to the rest of your code above)
                      	//var today = moment().startOf("day");
                      			var calendar = this.calendarData[c];
                      			for (var e in calendar) {
                      				var event = calendar[e];
                                                       // if event happens further away than x number of days (6 in this sample)
                      				if(event.startDate>= today) {    < ------
                      					if(this.config.hidePrivate) {
                      						if(event.class === "PRIVATE") {
                      							  // do not add the current event, skip it
                      							  continue;
                      					event.url = c;
                      					event.today = event.startDate >= today && event.startDate < (today + 24 * 60 * 60 * 1000);
                      					events.push(event);
                        bolish
                        Works like a charm.
                        Thank you very much, I’ve learnt something thanks to you and appreciated your support for debug.
                        See you around.
