    auto-booting but no modules (no warning with config file)
    24 Posts 2 Posters 9.8k Views 2 Watching
    • W Offline
      will23110
      So I turned off my mirror last night as per usual and turned it back on this morning to find that the modules aren’t loading, I don’t have a notification saying that I had an error with the config.js folder, the thing autoboots then shows absolutely nothing, I am running the latest version, I ran npm audit which showed 7 low, 1 medium, 1 high, so I ran npm audit fix, now I only have 5 low… but it still isn’t working… Any suggestions where to look or what to potentially do that doesn’t involve starting again??
        sdetweil @will23110
        @will23110 from the console of your pi, or over ssh, run
        npm start dev
        from the MagicMirror folder
        open the console tab, and look for errors, red text
        usually when a module crashes, the mirror will go black
        • W Offline
          will23110
          so I’ve run that and in the top right corner it says 3 errors and 2 warnings, I just don’t understand why it would do this overnight, it was working perfectly last night
            sdetweil @will23110
            @will23110 select the console tab to scroll the list
            no idea, something changed
            • W Offline
              will23110
              yeah, shame though I’d only just perfected it ahah, so the three errors are
              • Uncaught SyntaxError: Invalid or unexpected token (translator.js:1)
              • Uncaught SyntaxError: Invalid or unexpected token (loader.js:1
              • Uncaught ReferenceError: Translator is not defined (misn.js:452)
                at Object.init (main.js:425)
                at main.js:580
                and then a couple of security warning that I can probably (hopefully) fix.
                sdetweil @will23110
                @will23110 said in auto-booting but no modules (no warning with config file):
                so, I would use some editor to look at these two files in
                MagicMirror/js
                line 1 of each is a comment (/* */)
                maybe there was an error on the memory card when u rebooted…
                this error is because of the prior error on the translator.js file
                • W Offline
                  will23110
                  so I’ve got translator.js open, it says at the top
                  /* global config, vendor, MM, Module */
                  /* MagicMirror
                   * Module and file loaders.
                   * Etc...
                  should it be
                   /* MagicMirror*/
                   /* Module and file loaders.*/
                   /* Etc...
                  • W Offline
                    will23110
                    but in the repository for MagicMirror on github its the same, how do I quickly check for differences instead of having to go through the entire thing and comparing to another file
                      sdetweil @will23110
                      @will23110 no, 1st is ok
                        sdetweil @will23110
                        @will23110 compare, i do not know
                        • W Offline
                          will23110
                          Okay, I’ll check through it and correct anything that may be wrong
                          • W Offline
                            will23110
                            so I had an idea to check through it fast, I copied the loader.js info off of github and paste it into the find (ctrl+f) window, the whole document is highlighted, meaning there are no errors… could it be something else??
                              sdetweil @will23110
                              this one bothers me, I can’t find that file anywhere (misn.js), unless that is acut/paste/typo
                              based on the fact that files look ok, I would suggest doing an fsck (file system check) against the memory card
                              you will probably have to move it to another system to do that… windows cannot do it
                              • W Offline
                                will23110
                                how would I go about doing that on a pi?
                                  sdetweil @will23110
                                  @will23110 a google search says
                                  https://www.raspberrypi.org/forums/viewtopic.php?f=63&t=179361
                                  • W Offline
                                    will23110
                                    what do you mean by misn.js, I will have a look at that site, thanks
                                      sdetweil @will23110
                                      the error u posted says
                                      i see a use of Translator in main.js
                                      but cannot find a misn.js
                                      • W Offline
                                        will23110
                                        oh, typo haha, it’s supposed to say main.js, there are no errors in that one either, sorry about that
                                          sdetweil @will23110
                                          @will23110 ok
                                          • W Offline
                                            will23110
                                            wait so from the site you gave me, if I run
                                            sudo touch /forcefsck; sudo reboot
                                            will that break it?
