    How to start
    15 Posts 5 Posters 8.1k Views 5 Watching
    • lavolp3L Offline
      lavolp3 Module Developer @Dodo88
      @Dodo88 This is confusing me now.
      if you are
      • EITHER on the machine on which magicmirror is running on, you type:
        http://localhost:8080
      • OR on another machine, then you type:
        http://192.168.178.33:8080 or http://magicmirror:8080
      And you need to do what @sdetweil said.
      How to troubleshoot modules
      MMM-soccer v2, MMM-AVStock
        sdetweil @lavolp3
        @lavolp3 said in How to start:
        http://magicmirror
        what is that? none of my machines know where ‘magicmirror’ is located… (I have 6 different instances running, all installed from the same script)
        • lavolp3L Offline
          lavolp3 Module Developer @sdetweil
          @sdetweil Guess you’re right. Thanks for highlighting. I may have changed the hostname manually at my main mirror
            sdetweil @lavolp3
            @lavolp3 but thank you… this got me thinking about my network… and sure enough the linux boxes added their names to the name server in the router… SO, I can use names instead of numbers…
            My google wifi router does this better than my old TPLink router did…
              Dodo88
              hey, after i cleared the whitelist and reboot the rpi, it works :) Thx you all =)
              The “Admin Tool” i ment was the module “MMM-Admin-Interface”
              now booth works :)
              Thanks a lot!! =)
