    Hide modules when display goes off through PIR (power saving)
    22 Posts 7 Posters 10.2k Views 6 Watching
    • T Offline
      thedk
      Maybe i understand the modules like pir-hide-all, energy-saver, ect. wrong, but there is no modul that hides all modules when the display goes off through the PIR just for energy saving?
      Is it possible to make a modul that hides all modules that i have installed?
        sdetweil
        Well, there is a module… it needs one little script written for PIR.
        My MMM-SleepWake. It takes triggers from some external to MM.
        And supports the Pi, xdms, and blanking the screen for energystar devices.
        So, that suggests I need to provide that script… Thanks
        • T Offline
          thedk
          Saw this too, but forgot it.
          If somebody would write the script for the PIR it would be great.
          • ejay-ibmE Offline
            ejay-ibm Project Sponsor Module Developer
            Hi @thedk ,
            I think my post is related to that too.
            https://forum.magicmirror.builders/topic/9792/blank-screen-issue-another-one-again-after-one-hour-or-so/7
            It look like you figured out faster than me the lack of communication of the PIR modules to the other .
            You will see in the post that I have open a git to the PIR dev to ask for some help .
            Hopefully we will find a way to make it .
            I’m not a dev at all but I understand coding .
            I confident that playing with some code for a week or 2 will bring me to what I want.
            If we don’t get consistent answer in the meantime I’ll ( If i’m able to make it) definitly share with the community my findings.
            Cheers
            • T Offline
              thedk
              Thanks for the link.
              Then let’s see what will happen :)
              ejay-ibmE 1 Reply Last reply Reply Quote 0
              • ejay-ibmE Offline
                ejay-ibm Project Sponsor Module Developer @thedk
                @thedk Hi ,
                I finally manage to find a solution that works quite good.
                I do not deserve the credit for the solutions, only for the implementation as it merges multiple sources.
                First : PIR need a first trigger to work .
                Workaround : Make the HDMI OFF when the mirror start ( so your screen doesn’t stay ON always until someone pass in front of the miror )
                For this Edit :
                in the MMM-PIR-SENSOR folder
                node_helper.js
                around line 139
                this.started = true;
                    self.deactivateMonitor();  // add this to turn off monitor at startup .
                Then to deactivate the idle / sleep mode of the modules due to MMM-Assistant
                Still in the node_helper.js modify line 34 like :
                exec(“/usr/bin/vcgencmd display_power 1 && xdotool key ctrl+r”, null); // add here xdotool key ctrl+r
                You need to install xdotool for this. That will allow to simulate the ctrl+r from keybaord that refresh the module therefore bring them back on screen .
                I set in the config.js file the pir module to put the screen off after 15 mins
                “powerSavingDelay”: “900”,
                I applied the same setting in MMM-AssistantMk2.js
                onIdle: {
                timer: 10006015, // if you don’t want to use this feature, just set timer as 0 or command as “”
                command: “HIDEMODULES”
                Summary When I start my mirror the screen is off. The PIR detect my presence and turn it ON .
                After 15 mins the screen goes off and the modules goes in sleep .
                As soon as the user presence is detected again , the screen goes on and modules are refreshed and come back .
                Hope this helps .
                EJ
                • brobergB Offline
                  broberg Project Sponsor
                  Maybe I don’t understand your question… but
                  Hiding modules only with css (i.e hiding them on screen) does nothing for the power saving.
                  You need the monitor to go in to sleep for any power to be saved.
                  The Pi still runs when you hide the modules, not much power to save there, And I don’t really think the modules reload when hiding/showing them. But I can be wrong haven’t looked in to the code on the Hide/show part.
                    sdetweil
                    modules do not reload… their content is not shown when hidden
                    • T Offline
                      thedk
                      But it would save CPU Power if the Modules would be hide or not?
                        sdetweil @thedk
                        @thedk unlikely… or so small as to be unmeasurable
                        • ejay-ibmE Offline
                          ejay-ibm Project Sponsor Module Developer @broberg
                          @broberg
                          Indeed you don’t save power but when placing the module “on sleep” you stop them for making them network request with API calls .
                            sdetweil @ejay-ibm
                            @ejay-ibm yes, a well written module will suspend operations while hidden or suspended.
                            cowboysdudeC Mykle1M 2 Replies Last reply Reply Quote 2
                            • cowboysdudeC Offline
                              cowboysdude Module Developer @sdetweil
                              @sdetweil I’d be willing to bet the majority don’t … I don’t have any provisions in mine to stop polling but since you brought it up it is something I will most certainly want to do!! It’s a VERY good idea!
                                @sdetweil said in Hide modules when display goes off through PIR (power saving):
                                That leaves me out. :-)
                                  sdetweil @cowboysdude
                                  @cowboysdude @Mykle1 just add routines for suspend and resume. Set a variable on suspend, and don’t do anything til the variable is cleared on resume
                                    j.e.f.f Project Sponsor Module Developer @sdetweil
                                    Also, if the modules keep running while the display is off, they will all be up to date when you trigger the presence sensor to bring it out of sleep.
                                    I’d recommend not hiding the modules during power save.
                                      sdetweil @j.e.f.f
                                      @j-e-f-f I have a mopdule that tracks water usage and tank levels, once every 5 minutes… calls an api, gets all the values, and draws the graphs…
                                      my SleepWake module puts the mirror to sleep when no one is around… but when it wakes up, it updates…
                                      in like 5-10 seconds…
                                      no point pulling all that data overnight, or when I am gone for the day…
                                      • T Offline
                                        thedk
                                        Nice discussion :)
                                        My thought just was to reduce the temperature of the CPU when the display switches of.
                                        But the point with the network requests is also good!
                                          cowboysdude Module Developer @thedk
                                          @thedk Well if it’s not pulling it may cool it down by the virtue of not having to work to get the data. The other way to cool it down is put a fan on or near it…
                                            j.e.f.f Project Sponsor Module Developer @cowboysdude
                                            @cowboysdude a fan adds noise. If you’re really concerned about heat, then suspending the modules when it goes to sleep is a good approach if you’re ok with waiting 5-10 seconds for your modules to update after your mirror wakes up.
