    Script error
    11 Posts 4 Posters 3.4k Views 3 Watching
    • E Offline
      Ernst-Jan
      Can some tell what i can do on this error.
      0|mm |
      0|mm | (process:889): Gtk-WARNING **: Locale not supported by C library.
      0|mm | Using the fallback ‘C’ locale.
      0|mm | bash: warning: setlocale: LC_ALL: cannot change locale (nl_NL.UTF-8)
      0|mm |
      0|mm | (process:1708): Gtk-WARNING **: Locale not supported by C library.
      0|mm |
      0|mm | (process:1936): Gtk-WARNING **: Locale not supported by C library.
      0|mm |
      0|mm | (process:21123): Gtk-WARNING **: Locale not supported by C library.
      • E Offline
        Ernst-Jan
        @ganget I Iget this message when I start up my MM.opi@raspberrypi:~ $ pm2 log mm
        [TAILING] Tailing last 15 lines for [mm] process (change the value with --lines option)
        /home/pi/.pm2/logs/mm-out.log last 15 lines:
        0|mm | Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/fa9bjl6tu13dd10b066stoo5do%40group.calendar.google.com/public/basic.ics - Interval: 2000
        0|mm | MMM-GooglePhotos initialized after loading.
        0|mm | MMM-Formula1 received a notification: CONFIG
        0|mm | MMM-Formula1 is fetching the race schedule
        0|mm | Make request: /api/f1/current.json (GET)
        0|mm | MMM-Formula1 is fetching driver standings
        0|mm | Make request: /api/f1/current/driverStandings.json (GET)
        0|mm | https://epic.gsfc.nasa.gov/api/natural
        0|mm | starting network connection testing
        0|mm | [GPHOTO] Scan finished : 13
        0|mm | [RIJKS] 1 cycle finished.
        0|mm |
        0|mm | > magicmirror@2.6.0 start /home/pi/MagicMirror
        0|mm | > sh run-start.sh
        0|mm |
        /home/pi/.pm2/logs/mm-error.log last 15 lines:
        0|mm |
        0|mm | (process:903): Gtk-WARNING **: Locale not supported by C library.
        0|mm | (node:903) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 1): TypeError: Cannot read property ‘refs’ of undefined
        0|mm | (node:903) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
        0|mm | (node:903) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2): TypeError: Cannot read property ‘refs’ of undefined
        0|mm | (node:903) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 3): TypeError: Cannot read property ‘refs’ of undefined
        0|mm | (node:903) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 4): TypeError: Cannot read property ‘refs’ of undefined
        0|mm | (node:903) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 5): TypeError: Cannot read property ‘refs’ of undefined
        0|mm | (node:903) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 6): TypeError: Cannot read property ‘refs’ of undefined
        0|mm | (node:903) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 7): TypeError: Cannot read property ‘refs’ of undefined
        0|mm |
        0|mm | (process:3570): Gtk-WARNING **: Locale not supported by C library.
        0|mm | Starting MagicMirror: v2.6.0
        0|mm | Loading config …
        0|mm | Loading module helpers …
        0|mm | No helper found for module: alert.
        0|mm | No helper found for module: MMM-pages.
        0|mm | Initializing new module helper …
        0|mm | Module helper loaded: updatenotification
        0|mm | No helper found for module: clock.
        0|mm | No helper found for module: MMM-page-indicator.
        0|mm | Module helper loaded: MMM-Remote-Control
        0|mm | No helper found for module: MMM-Console.
        0|mm | Module helper loaded: MMM-Rijks
        0|mm | Module helper loaded: MMM-NetworkConnection
        0|mm | No helper found for module: MMM-Scrobbler.
        0|mm | Module helper loaded: MMM-OnScreenMenu
        0|mm | Module helper loaded: MMM-FlightsAbove
        0|mm | Module helper loaded: MMM-NetworkScanner
        0|mm | Module helper loaded: MMM-SoccerLiveScore
        0|mm | No helper found for module: currentweather.
        0|mm | Module helper loaded: MMM-Tools
        0|mm | No helper found for module: weatherforecast.
        0|mm | Module helper loaded: MMM-NewsFeedTicker
        0|mm | Module helper loaded: MMM-LocalTransport
        0|mm | No helper found for module: MMM-google-route.
        0|mm | Module helper loaded: MMM-DarkSkyForecast
        0|mm | Module helper loaded: MMM-GoogleMapsTraffic
        0|mm | No helper found for module: MMM-SmartWebDisplay.
        0|mm | Module helper loaded: calendar
        0|mm | Module helper loaded: MMM-GooglePhotos
        0|mm | Module helper loaded: MMM-Formula1
        0|mm | Module helper loaded: MMM-MARS
        0|mm | Module helper loaded: MMM-EARTH
        0|mm | All module helpers loaded.
        0|mm | Starting server on port 8080 …
        0|mm | You’re using a full whitelist configuration to allow for all IPs
        0|mm | Server started …
        0|mm | Connecting socket for: updatenotification
        0|mm | Connecting socket for: MMM-Remote-Control
        0|mm | Starting node helper for: MMM-Remote-Control
        0|mm | Connecting socket for: MMM-Rijks
        0|mm | Connecting socket for: MMM-NetworkConnection
        0|mm | MMM-NetworkConnection helper started …
        0|mm | Connecting socket for: MMM-OnScreenMenu
        0|mm | Connecting socket for: MMM-FlightsAbove
        0|mm | MMM-FlightsAbove started
        0|mm | Connecting socket for: MMM-NetworkScanner
        0|mm | Starting module: MMM-NetworkScanner
        0|mm | Connecting socket for: MMM-SoccerLiveScore
        0|mm | MMM-SoccerLiveScore helper started…
        0|mm | Connecting socket for: MMM-Tools
        0|mm | Connecting socket for: MMM-NewsFeedTicker
        0|mm | Starting module: MMM-NewsFeedTicker
        0|mm | Connecting socket for: MMM-LocalTransport
        0|mm | MMM-LocalTransport helper started …
        0|mm | Connecting socket for: MMM-DarkSkyForecast
        0|mm | ====================== Starting node_helper for module [MMM-DarkSkyForecast]
        0|mm | Connecting socket for: MMM-GoogleMapsTraffic
        0|mm | Starting node_helper for module: MMM-GoogleMapsTraffic
        0|mm | Connecting socket for: calendar
        0|mm | Starting node helper for: calendar
        0|mm | Connecting socket for: MMM-GooglePhotos
        0|mm | MMM-GooglePhotos started
        0|mm | Connecting socket for: MMM-Formula1
        0|mm | Starting module: MMM-Formula1
        0|mm | Connecting socket for: MMM-MARS
        0|mm | Starting node_helper for: MMM-MARS
        0|mm | Connecting socket for: MMM-EARTH
        0|mm | Starting module: MMM-EARTH
        0|mm | Sockets connected & modules started …
        0|mm | Launching application.
        0|mm | (node:3570) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 1): TypeError: Cannot read property ‘refs’ of undefined
        0|mm | (node:3570) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
        0|mm | (node:3570) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2): TypeError: Cannot read property ‘refs’ of undefined
        0|mm | (node:3570) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 3): TypeError: Cannot read property ‘refs’ of undefined
        0|mm | (node:3570) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 4): TypeError: Cannot read property ‘refs’ of undefined
        0|mm | (node:3570) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 5): TypeError: Cannot read property ‘refs’ of undefined
        0|mm | (node:3570) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 6): TypeError: Cannot read property ‘refs’ of undefined
        0|mm | (node:3570) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 7): TypeError: Cannot read property ‘refs’ of undefined
        0|mm | (node:3570) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 8): TypeError: Cannot read property ‘refs’ of undefined
        0|mm | (node:3570) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 9): TypeError: Cannot read property ‘refs’ of undefined
        0|mm | (node:3570) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 10): TypeError: Cannot read property ‘refs’ of undefined
        0|mm | (node:3570) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 11): TypeError: Cannot read property ‘refs’ of undefined
        0|mm | (node:3570) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 12): TypeError: Cannot read property ‘refs’ of undefined
        0|mm | MMM-NetworkScanner received CONFIG
        0|mm | Create new news fetcher for url: https://www.ad.nl/nieuws/rss.xml - Interval: 3600000
        0|mm | Working notification system. Notification: MMM-GOOGLE_MAPS_TRAFFIC-GET payload: { style: ‘standard’ }
        0|mm | Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/ernstjan.kromhout%40gmail.com/private-bf338f45b4e760a080dff16bb5a46b31/basic.ics - Interval: 2000
          sdetweil
          please show us your config.js
          • bheplerB Offline
            bhepler Module Developer
            Please use the markdown features of the forum when posting code & log messages.
            And yes, please post your config.js with the API keys redacted.
            • E Offline
              Ernst-Jan
              *************** AUTO GENERATED BY REMOTE CONTROL MODULE ***************/
              var config =
              address: “192.168.178.246”,
              electronOptions: {
              ipWhitelist: [
              		module: "alert",
              		module: "MMM-pages",
              					"updatenotification",
              					"MMM-Tools",
              					"MMM-chromecast",
              					"MMM-Remote-Control",
              					"MMM-iFrameReload",
              					"MMM-Console",
              					"MMM-MyCommute",
              					"weatherforecast",
              					"MMM-Scrobbler",
              					"MMM-GooglePhotos"
              					"MMM-MARS",
              					"MMM-Rijks"
              					"MMM-google-route"
              					"MMM-FlightsAbove",
              					"MMM-NetworkConnection",
              					"calendar",
              					"MMM-MyCommute",
              					"MMM-DailyBibleVerse",
              					"MMM-LocalTransport",
              					"MMM-TelegramBot"
              					"MMM-NetworkScanner",
              					"compliments",
              					"MMM-DarkSkyForecast",
              					"MMM-OnScreenMenu",
              					"MMM-SoccerLiveScore"
              					"MMM-Formula1",
              					"MMM-EARTH",
              					"MMM-SmartWebDisplay"
              			excludes: [
              				"clock",
              				"currentweather",
              				"MMM-NewsFeedTicker",
              				"MMM-page-indicator"
              			rotationTime: 15000
              		module: "updatenotification",
              		position: "top_bar",
              		module: "clock",
              		module: "MMM-page-indicator",
              		position: "bottom_bar",
              			pages: 6
              		module: "MMM-Remote-Control",
              		position: "bottom_left",
              			customCommand: {},  // Optional, See "Using Custom Commands" below
              			customMenu: "custom_menu.json", // Optional, See "Custom Menu Items" below
              			showModuleApiMenu: true, // Optional, Enable the Module Controls menu
              			pm2ProcessName: "mm",  // Optional, if you don't use the default PM2 process, provide the name here.
              			apiKey: "",         // Optional, See API/README.md for details
                  	module: "MMM-Console",
                  	header: "Console Output",
                  	position: "bottom_right",
                  		lines: 15,
              		module: "MMM-Rijks",
              		position: "fullscreen_below",
              			descriptionLanguage: "nl",
              			account: {
              				userId: "******",
              				apiKey: "******",
              				setId: "magicmirror"
              		module: "MMM-NetworkConnection",
              		position: "top_center",
              			updateInterval: 600000
              		module: "MMM-Scrobbler",
              			username: "E-JKromhout",
              			apikey: "********"
              		module: "MMM-OnScreenMenu",
              			menuItems: {
              				monitorOff: {
              					title: "Turn Off Monitor",
              					icon: "television",
              					source: "SERVER"
              				restart: {
              					title: "Restart MagicMirror",
              					icon: "recycle",
              					source: "ALL"
              				refresh: {
              					title: "Refresh MagicMirror",
              					icon: "refresh",
              					source: "LOCAL"
              				reboot: {
              					title: "Reboot",
              					icon: "spinner",
              					source: "ALL"
              				shutdown: {
              					title: "Shutdown",
              					icon: "power-off",
              					source: "ALL"
              			keyBindings: {
              				Up: "ArrowUp",
              				Down: "ArrowDown",
              				Select: "Enter",
              				Close: "Return",
              				Menu: "Menu"
              		module: "MMM-FlightsAbove",
              		header: "Flights Above",
              			compassHeading: true,
              			maxItems: 10,
              			radarBBox: [
              				53.47343,
              				4.92684,
              				52.39545,
              				6.71538
              			watchList: [
              				1276,
              				5000,
              				5400,
              				5600,
              				6000,
              				6100,
              				6400
              		module: "MMM-NetworkScanner",
              			devices: [
              					macAddress: "********",
              					icon: "male"
              					icon: "female"
              					icon: "male"
              					icon: "male"
              					macAddress: "*********",
              					name: "Synology DS416play",
              					icon: "server"
              					name: "Synology Backup 210",
              					icon: "server"
              			showUnknown: false,
              			keepAlive: 300,
              			updateInterval: 5,
              			residents: [
              		module: "MMM-SoccerLiveScore",
              		header: "Live-Scores",
              			leagues: [
              				37
              			displayTime: 60000
              		module: "currentweather",
              			locationID: "2756644",
              			appid: "**************",
              			iconTable: {
              				"01d": "wi-day-sunny",
              				"02d": "wi-day-cloudy",
              				"03d": "wi-cloudy",
              				"04d": "wi-cloudy-windy",
              				"09d": "wi-showers",
              				"10d": "wi-rain",
              				"11d": "wi-thunderstorm",
              				"13d": "wi-snow",
              				"50d": "wi-fog",
              				"01n": "wi-night-clear",
              				"02n": "wi-night-cloudy",
              				"03n": "wi-night-cloudy",
              				"04n": "wi-night-cloudy",
              				"09n": "wi-night-showers",
              				"10n": "wi-night-rain",
              				"11n": "wi-night-thunderstorm",
              				"13n": "wi-night-snow",
              				"50n": "wi-night-alt-cloudy-windy"
              		module: "MMM-Tools",
              			warning: {
              				CPU_TEMPERATURE: 65,
              				GPU_TEMPERATURE: 65,
              		CPU_USAGE: 75,
              				STORAGE_USED_PERCENT: 80,
              				MEMORY_USED_PERCENT: 80
              			warning_text: {
              				CPU_TEMPERATURE: "The temperature of CPU is over %VAL%",
              				GPU_TEMPERATURE: "The temperature of GPU is over %VAL%",
              				CPU_USAGE: "The usage of CPU is over %VAL%",
              				STORAGE_USED_PERCENT: "The storage is used over %VAL% percent",
              				MEMORY_USED_PERCENT: "The memory is used over %VAL% percent"
              		module: "weatherforecast",
              		header: "Weather Forecast",
              			appid: "**********",
              			iconTable: {
              				"03d": "wi-cloudy",
              				"10d": "wi-rain",
              				"13d": "wi-snow",
              				"50d": "wi-fog",
              		disabled: false,
              		module: "MMM-NewsFeedTicker",
              			feeds: [
              					title: "AD Nieuws",
              					url: "https://www.ad.nl/nieuws/rss.xml",
              					encoding: "UTF-8",
              					className: "myClass",
              					defaultLogo: ""
              			startTags: [
              			endTags: [
              			prohibitedWords: [
              		module: "MMM-LocalTransport",
              		header: "Naar Groning Vondelpad",
              		position: "center",
              			api_key: "*********",
              			origin: "Ureterp Centrum, Ureterp, The Netherlands",
              			destination: "Groningen Hoofdstation, Groningen, The Netherlands",
              			maximumEntries: 4,
              			maxWalkTime: 15,
              			displayWalkType: "full",
              			maxModuleWidth: 400
              		module: "MMM-google-route",
              		position: "center",
              			key: "***********",
              			directionsRequest: {
              				origin: "Ureterp, The Netherlands",
              				destination: "Grootegast, The Netherlands"
              			mapOptions: {
              			listen: [
              		module: "MMM-MyCommute",
              		header: "Reis informatie",
              			apikey: "************",
              			orgin: "Reiddomp 8, ureterp, 9247 GP, The Netherlands",
              			hideDays: [
              			destinations: [
              					destination: "Weibuorren 108, Ureterp, 9247 AW, The Netherlands",
              					label: "Bushalte Ureterp Centrum",
              					mode: "walking",
              					color: "#82E5AA",
              					time: null
              					destination: "De Drift 38, Drachten, 9203 GH, The Netherlands",
              					label: "School Wessel",
              					mode: "bicycling",
              					time: null
              					destination: "De Brauwweg 82, Schiedam, 3125 AE, The Netherlands",
              					label: "Werk Ernst-Jan",
              					mode: "driving",
              					time: null
              					destination: "De Schalck 8, Grootegast, 9861 BD, The Netherlands",
              					label: "Werk Jantine",
              					mode: "driving",
              					color: "#FF00FF",
              					time: null
              			origin: "Reiddomp 8, Ureterp, 9247 GP, The Netherlands"
              		module: "MMM-DarkSkyForecast",
              		header: "Weather",
              		position: "center",
              		classes: "default everyone",
              		disabled: false,
              			apikey: "**************",
              			latitude: "53.098752",
              			longitude: "6.176201",
              			iconset: "4c",
              			concise: false,
              			forecastLayout: "table",
              			label_days: [
              				"Sun",
              				"Mon",
              				"Tue",
              				"Wed",
              				"Thur",
              				"Fri",
              				"Sat"
              			label_ordinals: [
              				"N",
              				"NNE",
              				"NE",
              				"ENE",
              				"E",
              				"ESE",
              				"SE",
              				"SSE",
              				"S",
              				"SSW",
              				"SW",
              				"WSW",
              				"W",
              				"WNW",
              				"NW",
              				"NNW"
              		module: "MMM-GoogleMapsTraffic",
              		position: "center",
              			key: "******************",
              			lat: 53.098853,
              			lng: 6.176025,
              			height: "600px",
              			width: "600px",
              			zoom: 12,
              			updateInterval: 300000
              		module: "MMM-SmartWebDisplay",
              		position: "bottom_center",
              			url: [
              				"http://magicmirror.builders/",
              				"https://www.youtube.com/embed/Qwc2Eq6YXTQ?autoplay=1"
              		header: "Familie Kromhout",
              					symbol: "calendar",
              					url: "https://calendar.google.com/calendar/ical/ernstjan.kromhout%40gmail.com/private-*******/basic.ics",
              					maximumEntries: 3
              					symbol: 'flag-checkered',
              					url: 'https://calendar.google.com/calendar/ical/f********%40group.calendar.google.com/public/basic.ics',
              					maximumEntries: 3
              			titleReplace: {
              				"De verjaardag van ": "",
              				"'s birthday": ""
              			excludedEvents: [
              		module: "MMM-GooglePhotos",
              			albumId: [
              			scanInterval: 600000,
              			mode: "hybrid"
              		module: "MMM-Formula1",
              		header: "F1 Standings",
              			calendar: true,
              		module: "MMM-MARS",
              			useHeader: false
              		module: "MMM-EARTH",
              		position: "right_bottom",
              			rotateInterval: 15000,
              			MonthsArray: {
              				Jan: "01",
              				Feb: "02",
              				Mar: "03",
              				Apr: "04",
              				May: "05",
              				Jun: "06",
              				Jul: "07",
              				Aug: "08",
              				Sep: "09",
              				Oct: "10",
              				Nov: "11",
              				Dec: "12"
              paths: {
              	modules: "modules",
              	vendor: "vendor"
                sdetweil @Ernst-Jan
                @ernst-jan need to wrap the whole config.js text in the three backtics… left of the number 1 on the keyboard
                what language do you have set? here is mine.
                var config = {
                  address: "0.0.0.0", // Address to listen on, can be:
                  port: 8086,
                  ipWhitelist: [], // Set [] to allow all IP addresses
                  language:  "en",
                  timeFormat: 12,
                  units: "imperial",
                • E Offline
                  Ernst-Jan
                  /*************** AUTO GENERATED BY REMOTE CONTROL MODULE ***************/
                  var config =
                  electronOptions: {
                  ipWhitelist: [
                  		module: "alert",
                  					"MMM-Tools",
                  					"MMM-chromecast",
                  					"MMM-iFrameReload",
                  					"MMM-Console",
                  					"MMM-MyCommute",
                  					"weatherforecast",
                  					"MMM-Scrobbler",
                  					"MMM-GooglePhotos"
                  					"MMM-MARS",
                  					"MMM-Rijks"
                  					"MMM-google-route"
                  					"MMM-FlightsAbove",
                  					"calendar",
                  					"MMM-MyCommute",
                  					"MMM-TelegramBot"
                  					"compliments",
                  					"MMM-OnScreenMenu",
                  					"MMM-Formula1",
                  					"MMM-EARTH",
                  			excludes: [
                  				"clock",
                  				"currentweather",
                  			rotationTime: 15000
                  		module: "clock",
                  			pages: 6
                      		lines: 15,
                  			account: {
                  				userId: "2343212",
                  				apiKey: "*********",
                  			apikey: "***********"
                  			menuItems: {
                  				monitorOff: {
                  					icon: "television",
                  					source: "SERVER"
                  				restart: {
                  					icon: "recycle",
                  					source: "ALL"
                  				refresh: {
                  					icon: "refresh",
                  					source: "LOCAL"
                  				reboot: {
                  					title: "Reboot",
                  					icon: "spinner",
                  					source: "ALL"
                  				shutdown: {
                  					title: "Shutdown",
                  					icon: "power-off",
                  					source: "ALL"
                  			keyBindings: {
                  				Up: "ArrowUp",
                  				Down: "ArrowDown",
                  				Select: "Enter",
                  				Close: "Return",
                  				Menu: "Menu"
                  			maxItems: 10,
                  			radarBBox: [
                  				53.47343,
                  				4.92684,
                  				52.39545,
                  				6.71538
                  			watchList: [
                  				1276,
                  				5000,
                  				5400,
                  				5600,
                  				6000,
                  				6100,
                  				6400
                  			devices: [
                  					macAddress: "80:B0:3D:37:8B:53",
                  					icon: "male"
                  					macAddress: "B4:18:D1:1F:B0:4D",
                  					icon: "female"
                  					macAddress: "48:43:7C:E9:96:D7",
                  					icon: "male"
                  					macAddress: "38:CA:DA:C1:08:F8",
                  					icon: "male"
                  					macAddress: "00:11:32:32:BB:FD",
                  					icon: "server"
                  					macAddress: "00:11:32:06:4B:6D",
                  					icon: "server"
                  			showUnknown: false,
                  			keepAlive: 300,
                  			updateInterval: 5,
                  			residents: [
                  			leagues: [
                  				37
                  			displayTime: 60000
                  			iconTable: {
                  				"03d": "wi-cloudy",
                  				"10d": "wi-rain",
                  				"13d": "wi-snow",
                  				"50d": "wi-fog",
                  			warning: {
                  				CPU_USAGE: 75,
                  			warning_text: {
                  			iconTable: {
                  				"03d": "wi-cloudy",
                  				"10d": "wi-rain",
                  				"13d": "wi-snow",
                  				"50d": "wi-fog",
                  		disabled: false,
                  			feeds: [
                  					title: "AD Nieuws",
                  					encoding: "UTF-8",
                  					defaultLogo: ""
                  			startTags: [
                  			endTags: [
                  			prohibitedWords: [
                  		position: "center",
                  			api_key: "AIzaSyDNu23Dqqt7eEGJvtJDs02rjRxmNT5Fr9c",
                  			maximumEntries: 4,
                  			maxWalkTime: 15,
                  			maxModuleWidth: 400
                  		position: "center",
                  			key: "********",
                  			mapOptions: {
                  			listen: [
                  			apikey: "********",
                  			hideDays: [
                  			destinations: [
                  					mode: "walking",
                  					color: "#82E5AA",
                  					time: null
                  					mode: "bicycling",
                  					time: null
                  					mode: "driving",
                  					time: null
                  					mode: "driving",
                  					color: "#FF00FF",
                  					time: null
                  		header: "Weather",
                  		position: "center",
                  		disabled: false,
                  			apikey: "********",
                  			iconset: "4c",
                  			concise: false,
                  			label_days: [
                  				"Sun",
                  				"Mon",
                  				"Tue",
                  				"Wed",
                  				"Thur",
                  				"Fri",
                  				"Sat"
                  			label_ordinals: [
                  				"N",
                  				"NNE",
                  				"NE",
                  				"ENE",
                  				"E",
                  				"ESE",
                  				"SE",
                  				"SSE",
                  				"S",
                  				"SSW",
                  				"SW",
                  				"WSW",
                  				"W",
                  				"WNW",
                  				"NW",
                  				"NNW"
                  		position: "center",
                  			key: "*********",
                  			lat: 53.098853,
                  			lng: 6.176025,
                  			height: "600px",
                  			width: "600px",
                  			zoom: 12,
                  			url: [
                  					symbol: "calendar",
                  					url: "https://calendar.google.com/calendar/ical/ernstjan.kromhout%40gmail.com/private-********/basic.ics",
                  					maximumEntries: 3
                  					url: 'https://calendar.google.com/calendar/ical/**********%40group.calendar.google.com/public/basic.ics',
                  					maximumEntries: 3
                  			titleReplace: {
                  				"'s birthday": ""
                  			excludedEvents: [
                  			albumId: [
                  			mode: "hybrid"
                  			calendar: true,
                  		module: "MMM-MARS",
                  			useHeader: false
                  			MonthsArray: {
                  				Jan: "01",
                  				Feb: "02",
                  				Mar: "03",
                  				Apr: "04",
                  				May: "05",
                  				Jun: "06",
                  				Jul: "07",
                  				Aug: "08",
                  				Sep: "09",
                  				Oct: "10",
                  				Nov: "11",
                  				Dec: "12"
                  paths: {
                  	modules: "modules",
                  	vendor: "vendor"
                  if (typeof module !== ‘undefined’) {module.exports = config;}
                    sdetweil @Ernst-Jan
                    @ernst-jan still somehow getting cut off…
                    don’t include the comment lines at the top…
                    • E Offline
                      Ernst-Jan
                      can i sent it to you by mail?.
                        sdetweil @Ernst-Jan
                        @ernst-jan i don’t think I can help much, there is a LOT of stuff going on there…
                        they key thing I wanted to see is what language u have set…
                        the error is complaining about locale…
