    Can't get MM to start, says it can't find electron, then electron won't start
    49 Posts 5 Posters 33.8k Views 4 Watching
      jmartin1009 @bhepler
      @bhepler I am given this error screen
      pi@raspberrypi:~ $ sudo npm install -g electron@2.0.0
      npm WARN registry Unexpected warning for https://registry.npmjs.org/: Miscellaneous Warning ENODATA: Cache input stream was empty
      npm WARN registry Using stale package data from https://registry.npmjs.org/ due to a request error during revalidation.
      npm ERR! code EINTEGRITY
      npm ERR! errno EINTEGRITY
      npm ERR! Invalid response body while trying to fetch https://registry.npmjs.org/electron: Integrity verification failed for sha512-MAYuYPYfeCgTfXMl3ioXQAncWDyol9bCAkDBgeNSFemdEJgyOkTSixehWJJTIC9Pc7Ebrgljxn1t3lwm9ae/Bw== (/root/.npm/_cacache/content-v2/sha512/30/06/2e60f61f7828137d7325de2a174009dc583ca897d6c20240c181e35215e99d1098323a44d28b17a1589253202f4f73b11bae0963c67d6dde5c26f5a7bf07)
      npm ERR!     /root/.npm/_logs/2019-02-20T01_39_41_726Z-debug.log
        sdetweil @jmartin1009
        @jmartin1009 MM is trying to install 4.x by default… try 3.0.10
        what version is npm?
        npm -v
        node -v
        npm install electron@3.0.10
          jmartin1009 @sdetweil
          @sdetweil npm is 6.4.1 and node is 10.15.1. When I try to install electron now it just says that my cache input stream is empty. when I tried to get to node modules like @bhepler said, it said no such file or directory, and when I force cleared it gave me a warning message saying “I sure hope you know what you are doing.”
            sdetweil
            try
            npm init -y
            may have to erase the /home/pi/.npm folder
              @sdetweil got this, now what?
              pi@raspberrypi:~ $ npm init -y
              Wrote to /home/pi/package.json:
                "name": "pi",
                "version": "1.0.0",
                "description": "",
                "main": "index.js",
                "dependencies": {},
                "devDependencies": {},
                "scripts": {
                  "test": "echo \"Error: no test specified\" && exit 1"
                "keywords": [],
                "author": "",
                "license": "ISC"
                sdetweil
                now change to MagicMirror folder and try the install for electron@3.0.10
                J 2 Replies Last reply Reply Quote -1
                  @sdetweil the pi reboots and then I change to magicmirror folder and try to start magic mirror and it still says it can’t find electron for some reason :/
                    @sdetweil it also says that “local package.json exists, but node_modules is missing, did you mean to install?”
                      @jmartin1009 yes
                      npm install
                      and if you still have electron missing, then try to
                        @sdetweil do I do npm install in pi or magic mirror?
                        • 4 / 5
