    Can't get MM to start, says it can't find electron, then electron won't start
    49 Posts 5 Posters 37.9k Views 4 Watching
      Sorry, I do not know. Mine never reboots.
      How big is your memory card?
        jmartin1009 @sdetweil
        @sdetweil 32 gb
          @sdetweil I believe u figured out why it was restarting, a common cause of it is lack of power, and some person had problems with their keyboard drawing too much power so I unplugged it and it went all the way through without rebooting, but I still got some issues, im left with
          Installing dependencies ...
          npm WARN deprecated time-grunt@2.0.0: Deprecated because Grunt is practically unmaintained. Move on to something better. This package will continue to work with Grunt v1, but it will not receive any updates.
          npm WARN deprecated nomnom@1.8.1: Package no longer supported. Contact support@npmjs.com for more info.
          npm WARN tarball cached data for async@~1.5.2 (sha1-7GphrlZIDAw8skHJVhjiCJL5Zyo=) seems to be corrupted. Refreshing cache.
          npm WARN grunt-stylelint@0.10.1 requires a peer of stylelint@^9.0.0 but none is installed. You must install peer dependencies yourself.
          npm WARN acorn-jsx@5.0.1 requires a peer of acorn@^6.0.0 but none is installed. You must install peer dependencies yourself.
          npm ERR! path /home/pi/MagicMirror/node_modules/coffeescript/bin/coffee
          npm ERR! code ENOENT
          npm ERR! errno -2
          npm ERR! syscall chmod
          npm ERR! enoent ENOENT: no such file or directory, chmod '/home/pi/MagicMirror/node_modules/coffeescript/bin/coffee'
          npm ERR! enoent This is related to npm not being able to find a file.
          npm ERR! enoent
          npm ERR!     /home/pi/.npm/_logs/2019-02-20T04_31_21_244Z-debug.log
          Unable to install dependencies!
            sdetweil @jmartin1009
            @jmartin1009 I think u need to restart the install
            Erase the node_modules folder, and do it again
              @sdetweil I erased node_modules and reinstalled magicmirror and got this
              Cloning MagicMirror Done!
              npm WARN registry Unexpected warning for https://registry.npmjs.org/: Miscellaneous Warning ENODATA: Cache input stream was empty
              npm WARN registry Using stale package data from https://registry.npmjs.org/ due to a request error during revalidation.
              npm ERR! code EINTEGRITY
              npm ERR! errno EINTEGRITY
              npm ERR! Invalid response body while trying to fetch https://registry.npmjs.org/feedme: Integrity verification failed for sha512-neorTWnU+xIGoFGw5xKt8oa6Zrp4OIAdLKdTJkmTvESrU1kHYWBEQbxKaFtPAPPX7OiREkBnp0E0/gPN4QnmQg== (/home/pi/.npm/_cacache/content-v2/sha512/9d/ea/2b4d69d4fb1206a051b0e712adf286ba66ba7838801d2ca753264993bc44ab53590761604441bc4a685b4f00f3d7ece891124067a74134fe03cde109e642)
              npm ERR!     /home/pi/.npm/_logs/2019-02-20T17_49_38_341Z-debug.log
              What do I do now?
                from the /hom/pi folder do
                rm -rf .npm
                cd MagicMirror
                rm -rf node_modules
                npm install
                  @sdetweil I am now given this, what do I do next?
                  MagicMirror installation successful!
                  > magicmirror@2.6.0 install-fonts /home/pi/MagicMirror
                  > cd fonts && npm install
                  added 1 package from 1 contributor and audited 1 package in 5.243s
                  found 0 vulnerabilities
                  added 930 packages from 1367 contributors and audited 2433 packages in 160.197s
                  found 23 vulnerabilities (8 low, 14 moderate, 1 high)
                    run `npm audit fix` to fix them, or `npm audit` for details
                    @jmartin1009 if your mirror is not accessible from the internet I would not worry about these vulnerabilities.
                      @sdetweil does that mean I can’t use any modules that use the internet? im using ssh to do these codes and I plan to use alexa and stuff with it so it will require internet use, so what did you mean by that?
                        @jmartin1009 good point. I would run npm audit to get a list of the issues. These generally end up being challenging to solve completely.
                          @sdetweil I ran the audit and then I ran the audit fix and I got this:
                          found 23 vulnerabilities (8 low, 14 moderate, 1 high) in 2433 scanned packages
                            run `npm audit fix` to fix 13 of them.
                            8 vulnerabilities require semver-major dependency updates.
                            2 vulnerabilities require manual review. See the full report for details.
                          pi@raspberrypi:~/MagicMirror $ npm audit fix
                          -bash: pm: command not found
                          + jshint@2.10.1
                          added 4 packages from 4 contributors, removed 7 packages and updated 13 packages in 39.446s
                          fixed 13 of 23 vulnerabilities in 2433 scanned packages
                            2 vulnerabilities required manual review and could not be updated
                            1 package update for 8 vulns involved breaking changes
                            (use `npm audit fix --force` to install breaking changes; or refer to `npm audit` for steps to fix these manually)
                             │       New minor version of npm available! 6.4.1 → 6.8.0       │
                             │   Changelog: https://github.com/npm/cli/releases/tag/v6.8.0   │
                             │               Run npm install -g npm to update!               │
                          what should I do now?
                            @jmartin1009 I would see what that 1 high priority issue is.
                            At the bottom it says some breaking changes required to fix one issue. Breaking changes mean other code needs to be changed. So I would stay away from that fix
                              @sdetweil I ran the audit again and I believe the fix I did fixed it, but it says I still have 11 vulnerabilities, which are:
                                                     === npm audit security report ===
                              # Run  npm install --save-dev stylelint@9.10.1  to resolve 8 vulnerabilities
                              SEMVER WARNING: Recommended action is a potentially breaking change
                              │ Low           │ Regular Expression Denial of Service                         │
                              │ Package       │ braces                                                       │
                              │ Dependency of │ stylelint [dev]                                              │
                              │ Path          │ stylelint > micromatch > braces                              │
                              │ More info     │ https://nodesecurity.io/advisories/786                       │
                              │ Moderate      │ Prototype Pollution                                          │
                              │ Package       │ lodash                                                       │
                              │ Path          │ stylelint > lodash                                           │
                              │ More info     │ https://nodesecurity.io/advisories/782                       │
                              │ Path          │ stylelint > postcss-reporter > lodash                        │
                              │ Path          │ stylelint > table > lodash                                   │
                              │ Low           │ Prototype Pollution                                          │
                              │ More info     │ https://nodesecurity.io/advisories/577                       │
                              │ Low           │ Cryptographically Weak PRNG                                  │
                              │ Package       │ randomatic                                                   │
                              │ Path          │ stylelint > micromatch > braces > expand-range > fill-range  │
                              │               │ > randomatic                                                 │
                              │ More info     │ https://nodesecurity.io/advisories/157                       │
                              # Run  npm update lodash --depth 5  to resolve 1 vulnerability
                              │ Dependency of │ spectron [dev]                                               │
                              │ Path          │ spectron > webdriverio > gaze > globule > lodash             │
                              │                                Manual Review                                 │
                              │            Some vulnerabilities require your attention to resolve            │
                              │         Visit https://go.npm.me/audit-guide for additional guidance          │
                              │ Patched in    │ >=4.17.11                                                    │
                              │ Dependency of │ express-ipfilter                                             │
                              │ Path          │ express-ipfilter > lodash                                    │
                              │ Patched in    │ >=4.17.5                                                     │
                              found 11 vulnerabilities (6 low, 5 moderate) in 2427 scanned packages
                                run `npm audit fix` to fix 1 of them.
                              sorry for it being long, just easiest to copy and paste over from the ssh lol
                                As they are low or moderate risk, I would not worry about them.
                                  @sdetweil okay, so now should I try to run MagicMirror or is there anything else I have to do yet?
                                    @jmartin1009 correct, run MagicMirror
                                    Copy the sample config to config.js and then fire it up!
                                      @sdetweil what is that about copying config? how do I do that? the newbie guide im using doesn’t explain how to do that or why lol i’ll take your word on it I just need to know how
                                        jmartin1009 @jmartin1009
                                        @jmartin1009 also how do I exit MagicMirror once I have it started lol it is telling me to create a config file, but idk how to get out of MagicMirror to do that in the first place
                                          @sdetweil I was able to exit MM but how to do I copy the config and what do I do with it?
                                            @jmartin1009 from the MagicMirror folder do
                                            cd config
                                            copy config.js.sample config.js
                                            cd ..
                                            Then restart mirror
                                            • 2 / 3
