    Can't get MM to start, says it can't find electron, then electron won't start
    49 Posts 5 Posters 39.2k Views 4 Watching
      from the /hom/pi folder do
      rm -rf .npm
      cd MagicMirror
      rm -rf node_modules
      npm install
      J 1 Reply Last reply
        jmartin1009 @sdetweil
        @sdetweil I am now given this, what do I do next?
        MagicMirror installation successful!
        > magicmirror@2.6.0 install-fonts /home/pi/MagicMirror
        > cd fonts && npm install
        added 1 package from 1 contributor and audited 1 package in 5.243s
        found 0 vulnerabilities
        npm WARN grunt-stylelint@0.10.1 requires a peer of stylelint@^9.0.0 but none is installed. You must install peer dependencies yourself.
        npm WARN acorn-jsx@5.0.1 requires a peer of acorn@^6.0.0 but none is installed. You must install peer dependencies yourself.
        added 930 packages from 1367 contributors and audited 2433 packages in 160.197s
        found 23 vulnerabilities (8 low, 14 moderate, 1 high)
          run `npm audit fix` to fix them, or `npm audit` for details
          sdetweil @jmartin1009
          @jmartin1009 if your mirror is not accessible from the internet I would not worry about these vulnerabilities.
            @sdetweil does that mean I can’t use any modules that use the internet? im using ssh to do these codes and I plan to use alexa and stuff with it so it will require internet use, so what did you mean by that?
              @jmartin1009 good point. I would run npm audit to get a list of the issues. These generally end up being challenging to solve completely.
                @sdetweil I ran the audit and then I ran the audit fix and I got this:
                found 23 vulnerabilities (8 low, 14 moderate, 1 high) in 2433 scanned packages
                  run `npm audit fix` to fix 13 of them.
                  8 vulnerabilities require semver-major dependency updates.
                  2 vulnerabilities require manual review. See the full report for details.
                pi@raspberrypi:~/MagicMirror $ npm audit fix
                -bash: pm: command not found
                + jshint@2.10.1
                added 4 packages from 4 contributors, removed 7 packages and updated 13 packages in 39.446s
                fixed 13 of 23 vulnerabilities in 2433 scanned packages
                  2 vulnerabilities required manual review and could not be updated
                  1 package update for 8 vulns involved breaking changes
                  (use `npm audit fix --force` to install breaking changes; or refer to `npm audit` for steps to fix these manually)
                   │       New minor version of npm available! 6.4.1 → 6.8.0       │
                   │   Changelog: https://github.com/npm/cli/releases/tag/v6.8.0   │
                   │               Run npm install -g npm to update!               │
                what should I do now?
                  @jmartin1009 I would see what that 1 high priority issue is.
                  At the bottom it says some breaking changes required to fix one issue. Breaking changes mean other code needs to be changed. So I would stay away from that fix
                    @sdetweil I ran the audit again and I believe the fix I did fixed it, but it says I still have 11 vulnerabilities, which are:
                                           === npm audit security report ===
                    # Run  npm install --save-dev stylelint@9.10.1  to resolve 8 vulnerabilities
                    SEMVER WARNING: Recommended action is a potentially breaking change
                    │ Low           │ Regular Expression Denial of Service                         │
                    │ Package       │ braces                                                       │
                    │ Dependency of │ stylelint [dev]                                              │
                    │ Path          │ stylelint > micromatch > braces                              │
                    │ More info     │ https://nodesecurity.io/advisories/786                       │
                    │ Moderate      │ Prototype Pollution                                          │
                    │ Package       │ lodash                                                       │
                    │ Path          │ stylelint > lodash                                           │
                    │ More info     │ https://nodesecurity.io/advisories/782                       │
                    │ Path          │ stylelint > postcss-reporter > lodash                        │
                    │ Path          │ stylelint > table > lodash                                   │
                    │ Low           │ Prototype Pollution                                          │
                    │ More info     │ https://nodesecurity.io/advisories/577                       │
                    │ Low           │ Cryptographically Weak PRNG                                  │
                    │ Package       │ randomatic                                                   │
                    │ Path          │ stylelint > micromatch > braces > expand-range > fill-range  │
                    │               │ > randomatic                                                 │
                    │ More info     │ https://nodesecurity.io/advisories/157                       │
                    # Run  npm update lodash --depth 5  to resolve 1 vulnerability
                    │ Dependency of │ spectron [dev]                                               │
                    │ Path          │ spectron > webdriverio > gaze > globule > lodash             │
                    │                                Manual Review                                 │
                    │            Some vulnerabilities require your attention to resolve            │
                    │         Visit https://go.npm.me/audit-guide for additional guidance          │
                    │ Patched in    │ >=4.17.11                                                    │
                    │ Dependency of │ express-ipfilter                                             │
                    │ Path          │ express-ipfilter > lodash                                    │
                    │ Patched in    │ >=4.17.5                                                     │
                    found 11 vulnerabilities (6 low, 5 moderate) in 2427 scanned packages
                      run `npm audit fix` to fix 1 of them.
                    sorry for it being long, just easiest to copy and paste over from the ssh lol
                      As they are low or moderate risk, I would not worry about them.
                        @sdetweil okay, so now should I try to run MagicMirror or is there anything else I have to do yet?
                          @jmartin1009 correct, run MagicMirror
                          Copy the sample config to config.js and then fire it up!
                          J 2 Replies Last reply
                            @sdetweil what is that about copying config? how do I do that? the newbie guide im using doesn’t explain how to do that or why lol i’ll take your word on it I just need to know how
                              jmartin1009 @jmartin1009
                              @jmartin1009 also how do I exit MagicMirror once I have it started lol it is telling me to create a config file, but idk how to get out of MagicMirror to do that in the first place
                                @sdetweil I was able to exit MM but how to do I copy the config and what do I do with it?
                                  @jmartin1009 from the MagicMirror folder do
                                  cd config
                                  copy config.js.sample config.js
                                  cd ..
                                  Then restart mirror
                                    @sdetweil sorry for the late reply, but I was in fact able to get it to work :) I’m not trying to get my mic set up, so you know anything about the issues using a PS3 Eye Camera for the mic and how to get it to work properly? I can’t seem to get it to work on my Pi. Thank you for your help btw!
                                      meraja3
                                      Install electron lower version
                                      npm install electron@1.4.15
                                        jmartin1009
                                        Sorry, didn’t mean to post again in unread, can’t seem to figure out how to mark it as solved
                                        Mykle1M 1 Reply Last reply
                                        • Mykle1M
                                          Mykle1 Project Sponsor Module Developer @jmartin1009
                                          @jmartin1009 said in Can't get MM to start, says it can't find electron, then electron won't start:
                                          The three vertical dots at the far right of the post. Click!
                                          • 2 / 3
