    Can't get MM to start, says it can't find electron, then electron won't start
    49 Posts 5 Posters 39.2k Views 4 Watching
      jmartin1009 @sdetweil
      @sdetweil I erased node_modules and reinstalled magicmirror and got this
      Cloning MagicMirror Done!
      Installing dependencies ...
      npm WARN registry Unexpected warning for https://registry.npmjs.org/: Miscellaneous Warning ENODATA: Cache input stream was empty
      npm WARN registry Using stale package data from https://registry.npmjs.org/ due to a request error during revalidation.
      npm ERR! code EINTEGRITY
      npm ERR! errno EINTEGRITY
      npm ERR! Invalid response body while trying to fetch https://registry.npmjs.org/feedme: Integrity verification failed for sha512-neorTWnU+xIGoFGw5xKt8oa6Zrp4OIAdLKdTJkmTvESrU1kHYWBEQbxKaFtPAPPX7OiREkBnp0E0/gPN4QnmQg== (/home/pi/.npm/_cacache/content-v2/sha512/9d/ea/2b4d69d4fb1206a051b0e712adf286ba66ba7838801d2ca753264993bc44ab53590761604441bc4a685b4f00f3d7ece891124067a74134fe03cde109e642)
      npm ERR!     /home/pi/.npm/_logs/2019-02-20T17_49_38_341Z-debug.log
      Unable to install dependencies!
      What do I do now?
        from the /hom/pi folder do
        rm -rf .npm
        cd MagicMirror
        rm -rf node_modules
        npm install
        J 1 Reply Last reply
          @sdetweil I am now given this, what do I do next?
          MagicMirror installation successful!
          > magicmirror@2.6.0 install-fonts /home/pi/MagicMirror
          > cd fonts && npm install
          added 1 package from 1 contributor and audited 1 package in 5.243s
          found 0 vulnerabilities
          npm WARN grunt-stylelint@0.10.1 requires a peer of stylelint@^9.0.0 but none is installed. You must install peer dependencies yourself.
          npm WARN acorn-jsx@5.0.1 requires a peer of acorn@^6.0.0 but none is installed. You must install peer dependencies yourself.
          added 930 packages from 1367 contributors and audited 2433 packages in 160.197s
          found 23 vulnerabilities (8 low, 14 moderate, 1 high)
            run `npm audit fix` to fix them, or `npm audit` for details
            sdetweil @jmartin1009
            @jmartin1009 if your mirror is not accessible from the internet I would not worry about these vulnerabilities.
              @sdetweil does that mean I can’t use any modules that use the internet? im using ssh to do these codes and I plan to use alexa and stuff with it so it will require internet use, so what did you mean by that?
                @jmartin1009 good point. I would run npm audit to get a list of the issues. These generally end up being challenging to solve completely.
                  @sdetweil I ran the audit and then I ran the audit fix and I got this:
                  found 23 vulnerabilities (8 low, 14 moderate, 1 high) in 2433 scanned packages
                    run `npm audit fix` to fix 13 of them.
                    8 vulnerabilities require semver-major dependency updates.
                    2 vulnerabilities require manual review. See the full report for details.
                  pi@raspberrypi:~/MagicMirror $ npm audit fix
                  -bash: pm: command not found
                  + jshint@2.10.1
                  added 4 packages from 4 contributors, removed 7 packages and updated 13 packages in 39.446s
                  fixed 13 of 23 vulnerabilities in 2433 scanned packages
                    2 vulnerabilities required manual review and could not be updated
                    1 package update for 8 vulns involved breaking changes
                    (use `npm audit fix --force` to install breaking changes; or refer to `npm audit` for steps to fix these manually)
                     │       New minor version of npm available! 6.4.1 → 6.8.0       │
                     │   Changelog: https://github.com/npm/cli/releases/tag/v6.8.0   │
                     │               Run npm install -g npm to update!               │
                  what should I do now?
                    @jmartin1009 I would see what that 1 high priority issue is.
                    At the bottom it says some breaking changes required to fix one issue. Breaking changes mean other code needs to be changed. So I would stay away from that fix
                      @sdetweil I ran the audit again and I believe the fix I did fixed it, but it says I still have 11 vulnerabilities, which are:
                                             === npm audit security report ===
                      # Run  npm install --save-dev stylelint@9.10.1  to resolve 8 vulnerabilities
                      SEMVER WARNING: Recommended action is a potentially breaking change
                      │ Low           │ Regular Expression Denial of Service                         │
                      │ Package       │ braces                                                       │
                      │ Dependency of │ stylelint [dev]                                              │
                      │ Path          │ stylelint > micromatch > braces                              │
                      │ More info     │ https://nodesecurity.io/advisories/786                       │
                      │ Moderate      │ Prototype Pollution                                          │
                      │ Package       │ lodash                                                       │
                      │ Path          │ stylelint > lodash                                           │
                      │ More info     │ https://nodesecurity.io/advisories/782                       │
                      │ Path          │ stylelint > postcss-reporter > lodash                        │
                      │ Path          │ stylelint > table > lodash                                   │
                      │ Low           │ Prototype Pollution                                          │
                      │ More info     │ https://nodesecurity.io/advisories/577                       │
                      │ Low           │ Cryptographically Weak PRNG                                  │
                      │ Package       │ randomatic                                                   │
                      │ Path          │ stylelint > micromatch > braces > expand-range > fill-range  │
                      │               │ > randomatic                                                 │
                      │ More info     │ https://nodesecurity.io/advisories/157                       │
                      # Run  npm update lodash --depth 5  to resolve 1 vulnerability
                      │ Dependency of │ spectron [dev]                                               │
                      │ Path          │ spectron > webdriverio > gaze > globule > lodash             │
                      │                                Manual Review                                 │
                      │            Some vulnerabilities require your attention to resolve            │
                      │         Visit https://go.npm.me/audit-guide for additional guidance          │
                      │ Patched in    │ >=4.17.11                                                    │
                      │ Dependency of │ express-ipfilter                                             │
                      │ Path          │ express-ipfilter > lodash                                    │
                      │ Patched in    │ >=4.17.5                                                     │
                      found 11 vulnerabilities (6 low, 5 moderate) in 2427 scanned packages
                        run `npm audit fix` to fix 1 of them.
                      sorry for it being long, just easiest to copy and paste over from the ssh lol
                        As they are low or moderate risk, I would not worry about them.
                          @sdetweil okay, so now should I try to run MagicMirror or is there anything else I have to do yet?
                            @jmartin1009 correct, run MagicMirror
                            Copy the sample config to config.js and then fire it up!
                            J 2 Replies Last reply
                              @sdetweil what is that about copying config? how do I do that? the newbie guide im using doesn’t explain how to do that or why lol i’ll take your word on it I just need to know how
                                jmartin1009 @jmartin1009
                                @jmartin1009 also how do I exit MagicMirror once I have it started lol it is telling me to create a config file, but idk how to get out of MagicMirror to do that in the first place
                                  @sdetweil I was able to exit MM but how to do I copy the config and what do I do with it?
                                    @jmartin1009 from the MagicMirror folder do
                                    cd config
                                    copy config.js.sample config.js
                                    cd ..
                                    Then restart mirror
                                      @sdetweil sorry for the late reply, but I was in fact able to get it to work :) I’m not trying to get my mic set up, so you know anything about the issues using a PS3 Eye Camera for the mic and how to get it to work properly? I can’t seem to get it to work on my Pi. Thank you for your help btw!
                                        meraja3
                                        Install electron lower version
                                        npm install electron@1.4.15
                                          jmartin1009
                                          Sorry, didn’t mean to post again in unread, can’t seem to figure out how to mark it as solved
                                          Mykle1M 1 Reply Last reply
                                          • Mykle1M
                                            Mykle1 Project Sponsor Module Developer @jmartin1009
                                            @jmartin1009 said in Can't get MM to start, says it can't find electron, then electron won't start:
                                            The three vertical dots at the far right of the post. Click!
                                            • 2 / 3
