    Can't get MM to start, says it can't find electron, then electron won't start
    49 Posts 5 Posters 38.5k Views 4 Watching
      @jmartin1009 I would see what that 1 high priority issue is.
      At the bottom it says some breaking changes required to fix one issue. Breaking changes mean other code needs to be changed. So I would stay away from that fix
        jmartin1009 @sdetweil
        @sdetweil I ran the audit again and I believe the fix I did fixed it, but it says I still have 11 vulnerabilities, which are:
        pi@raspberrypi:~/MagicMirror $ npm audit
                               === npm audit security report ===
        # Run  npm install --save-dev stylelint@9.10.1  to resolve 8 vulnerabilities
        SEMVER WARNING: Recommended action is a potentially breaking change
        │ Low           │ Regular Expression Denial of Service                         │
        │ Package       │ braces                                                       │
        │ Dependency of │ stylelint [dev]                                              │
        │ Path          │ stylelint > micromatch > braces                              │
        │ More info     │ https://nodesecurity.io/advisories/786                       │
        │ Moderate      │ Prototype Pollution                                          │
        │ Package       │ lodash                                                       │
        │ Path          │ stylelint > lodash                                           │
        │ More info     │ https://nodesecurity.io/advisories/782                       │
        │ Path          │ stylelint > postcss-reporter > lodash                        │
        │ Path          │ stylelint > table > lodash                                   │
        │ Low           │ Prototype Pollution                                          │
        │ More info     │ https://nodesecurity.io/advisories/577                       │
        │ Low           │ Cryptographically Weak PRNG                                  │
        │ Package       │ randomatic                                                   │
        │ Path          │ stylelint > micromatch > braces > expand-range > fill-range  │
        │               │ > randomatic                                                 │
        │ More info     │ https://nodesecurity.io/advisories/157                       │
        # Run  npm update lodash --depth 5  to resolve 1 vulnerability
        │ Dependency of │ spectron [dev]                                               │
        │ Path          │ spectron > webdriverio > gaze > globule > lodash             │
        │                                Manual Review                                 │
        │            Some vulnerabilities require your attention to resolve            │
        │         Visit https://go.npm.me/audit-guide for additional guidance          │
        │ Patched in    │ >=4.17.11                                                    │
        │ Dependency of │ express-ipfilter                                             │
        │ Path          │ express-ipfilter > lodash                                    │
        │ Patched in    │ >=4.17.5                                                     │
        found 11 vulnerabilities (6 low, 5 moderate) in 2427 scanned packages
          run `npm audit fix` to fix 1 of them.
          8 vulnerabilities require semver-major dependency updates.
          2 vulnerabilities require manual review. See the full report for details.
        sorry for it being long, just easiest to copy and paste over from the ssh lol
          As they are low or moderate risk, I would not worry about them.
            @sdetweil okay, so now should I try to run MagicMirror or is there anything else I have to do yet?
              sdetweil @jmartin1009
              @jmartin1009 correct, run MagicMirror
              Copy the sample config to config.js and then fire it up!
                @sdetweil what is that about copying config? how do I do that? the newbie guide im using doesn’t explain how to do that or why lol i’ll take your word on it I just need to know how
                  jmartin1009 @jmartin1009
                  @jmartin1009 also how do I exit MagicMirror once I have it started lol it is telling me to create a config file, but idk how to get out of MagicMirror to do that in the first place
                    @sdetweil I was able to exit MM but how to do I copy the config and what do I do with it?
                      @jmartin1009 from the MagicMirror folder do
                      cd config
                      copy config.js.sample config.js
                      cd ..
                      Then restart mirror
                        @sdetweil sorry for the late reply, but I was in fact able to get it to work :) I’m not trying to get my mic set up, so you know anything about the issues using a PS3 Eye Camera for the mic and how to get it to work properly? I can’t seem to get it to work on my Pi. Thank you for your help btw!
                          meraja3
                          Install electron lower version
                          npm install electron@1.4.15
                            jmartin1009
                            Sorry, didn’t mean to post again in unread, can’t seem to figure out how to mark it as solved
                            • Mykle1M
                              Mykle1 Project Sponsor Module Developer @jmartin1009
                              @jmartin1009 said in Can't get MM to start, says it can't find electron, then electron won't start:
                              The three vertical dots at the far right of the post. Click!
                              • 3 / 3
