    Can't get MM to start, says it can't find electron, then electron won't start
    49 Posts 5 Posters 36.5k Views 4 Watching
      jmartin1009 @sdetweil
      @sdetweil the pi reboots and then I change to magicmirror folder and try to start magic mirror and it still says it can’t find electron for some reason :/
        @sdetweil it also says that “local package.json exists, but node_modules is missing, did you mean to install?”
          sdetweil @jmartin1009
          @jmartin1009 yes
          npm install
          and if you still have electron missing, then try to
          npm install electron@3.0.10
            @sdetweil do I do npm install in pi or magic mirror?
              @jmartin1009 magigcmirror… u are installing the dependencies for that app
                @sdetweil still says
                electron: not found
                Could this be because it says that node_modules is missing? I did both npm install and npm install electron@3.0.10 in MagicMirror.
                  @jmartin1009 npm install from inside the magicmirror folder should have created node_modules (thats its (npm) job)
                  erase MagicMirror folder,
                  download again
                  and then cd MagicMirror and then npm install
                    @sdetweil another error, it says
                    npm ERR! file /home/pi/MagicMirror/package.json
                    npm ERR! code EJSONPARSE
                    npm ERR! JSON.parse Failed to parse json
                    npm ERR! JSON.parse Unexpected end of JSON input while parsing near ' '
                    npm ERR! JSON.parse Failed to parse package. json data.
                    npm ERR! JSON.parse package.json must be actual JSON, not just JavaScript.
                      @jmartin1009 did u download the MagicMirror folder over again?
                        @sdetweil yes I deleted the contents of the old folder and changed the name and redownloaded MagicMirror
                          @jmartin1009 ok, from the /home/pi folder lets start again
                          cd ~
                          rm -rf whatever_the_old_folder_name_is
                          rm -rf MagicMirror
                          git clone https://github.com/MichMich/MagicMirror.git
                          cd MagicMirror
                          npm install
                            @sdetweil okay I did all of that and it said it cloned and everthing, and then it rebooted during the install, now what? lol
                              @jmartin1009 should not reboot
                                @sdetweil oh it reboots everytime I install magicmirror, how do I prevent this? because it always reboots like 1/3 of the way through the progress bar and it always did it so I thought it was normal lol can I stop this? I have a pi 3+ btw
                                  jmartin1009 @jmartin1009
                                  @jmartin1009 it also does that everytime I try to install electron so maybe that’s why it isn’t working :confused: is there any fix for this?
                                    Sorry, I do not know. Mine never reboots.
                                    How big is your memory card?
                                      @sdetweil 32 gb
                                        @sdetweil I believe u figured out why it was restarting, a common cause of it is lack of power, and some person had problems with their keyboard drawing too much power so I unplugged it and it went all the way through without rebooting, but I still got some issues, im left with
                                        Installing dependencies ...
                                        npm WARN deprecated time-grunt@2.0.0: Deprecated because Grunt is practically unmaintained. Move on to something better. This package will continue to work with Grunt v1, but it will not receive any updates.
                                        npm WARN deprecated nomnom@1.8.1: Package no longer supported. Contact support@npmjs.com for more info.
                                        npm WARN tarball cached data for async@~1.5.2 (sha1-7GphrlZIDAw8skHJVhjiCJL5Zyo=) seems to be corrupted. Refreshing cache.
                                        npm WARN grunt-stylelint@0.10.1 requires a peer of stylelint@^9.0.0 but none is installed. You must install peer dependencies yourself.
                                        npm WARN acorn-jsx@5.0.1 requires a peer of acorn@^6.0.0 but none is installed. You must install peer dependencies yourself.
                                        npm ERR! path /home/pi/MagicMirror/node_modules/coffeescript/bin/coffee
                                        npm ERR! code ENOENT
                                        npm ERR! errno -2
                                        npm ERR! syscall chmod
                                        npm ERR! enoent ENOENT: no such file or directory, chmod '/home/pi/MagicMirror/node_modules/coffeescript/bin/coffee'
                                        npm ERR! enoent This is related to npm not being able to find a file.
                                        npm ERR! enoent
                                        npm ERR!     /home/pi/.npm/_logs/2019-02-20T04_31_21_244Z-debug.log
                                        Unable to install dependencies!
                                          @jmartin1009 I think u need to restart the install
                                          Erase the node_modules folder, and do it again
                                            @sdetweil I erased node_modules and reinstalled magicmirror and got this
                                            Cloning MagicMirror Done!
                                            npm WARN registry Unexpected warning for https://registry.npmjs.org/: Miscellaneous Warning ENODATA: Cache input stream was empty
                                            npm WARN registry Using stale package data from https://registry.npmjs.org/ due to a request error during revalidation.
                                            npm ERR! code EINTEGRITY
                                            npm ERR! errno EINTEGRITY
                                            npm ERR! Invalid response body while trying to fetch https://registry.npmjs.org/feedme: Integrity verification failed for sha512-neorTWnU+xIGoFGw5xKt8oa6Zrp4OIAdLKdTJkmTvESrU1kHYWBEQbxKaFtPAPPX7OiREkBnp0E0/gPN4QnmQg== (/home/pi/.npm/_cacache/content-v2/sha512/9d/ea/2b4d69d4fb1206a051b0e712adf286ba66ba7838801d2ca753264993bc44ab53590761604441bc4a685b4f00f3d7ece891124067a74134fe03cde109e642)
                                            npm ERR!     /home/pi/.npm/_logs/2019-02-20T17_49_38_341Z-debug.log
                                            What do I do now?
