    Can't get MM to start, says it can't find electron, then electron won't start
    49 Posts 5 Posters 37.1k Views 4 Watching
      jmartin1009
      @bhelper am I trying to install the correct version of electron is there another version I should be using, the guide I was trying said to use 1.7.6 but people on here say 2.0.0
        jmartin1009
        @bhepler am I trying to install the correct version of electron or is there another version I should be using, the guide I was trying said to use 1.7.6 but people on here say 2.0.0
          jmartin1009 @bhepler
          @bhepler I am given this error screen
          pi@raspberrypi:~ $ sudo npm install -g electron@2.0.0
          npm WARN registry Unexpected warning for https://registry.npmjs.org/: Miscellaneous Warning ENODATA: Cache input stream was empty
          npm WARN registry Using stale package data from https://registry.npmjs.org/ due to a request error during revalidation.
          npm ERR! code EINTEGRITY
          npm ERR! errno EINTEGRITY
          npm ERR! Invalid response body while trying to fetch https://registry.npmjs.org/electron: Integrity verification failed for sha512-MAYuYPYfeCgTfXMl3ioXQAncWDyol9bCAkDBgeNSFemdEJgyOkTSixehWJJTIC9Pc7Ebrgljxn1t3lwm9ae/Bw== (/root/.npm/_cacache/content-v2/sha512/30/06/2e60f61f7828137d7325de2a174009dc583ca897d6c20240c181e35215e99d1098323a44d28b17a1589253202f4f73b11bae0963c67d6dde5c26f5a7bf07)
          npm ERR!     /root/.npm/_logs/2019-02-20T01_39_41_726Z-debug.log
            sdetweil @jmartin1009
            @jmartin1009 MM is trying to install 4.x by default… try 3.0.10
            what version is npm?
            npm -v
            node -v
            npm install electron@3.0.10
              jmartin1009 @sdetweil
              @sdetweil npm is 6.4.1 and node is 10.15.1. When I try to install electron now it just says that my cache input stream is empty. when I tried to get to node modules like @bhepler said, it said no such file or directory, and when I force cleared it gave me a warning message saying “I sure hope you know what you are doing.”
                try
                npm init -y
                may have to erase the /home/pi/.npm folder
                  @sdetweil got this, now what?
                  pi@raspberrypi:~ $ npm init -y
                  Wrote to /home/pi/package.json:
                    "name": "pi",
                    "version": "1.0.0",
                    "description": "",
                    "main": "index.js",
                    "dependencies": {},
                    "devDependencies": {},
                    "scripts": {
                      "test": "echo \"Error: no test specified\" && exit 1"
                    "keywords": [],
                    "author": "",
                    "license": "ISC"
                    now change to MagicMirror folder and try the install for electron@3.0.10
                    J 2 Replies Last reply Reply Quote -1
                      @sdetweil the pi reboots and then I change to magicmirror folder and try to start magic mirror and it still says it can’t find electron for some reason :/
                        @sdetweil it also says that “local package.json exists, but node_modules is missing, did you mean to install?”
                          @jmartin1009 yes
                          npm install
                          and if you still have electron missing, then try to
                            @sdetweil do I do npm install in pi or magic mirror?
                              @jmartin1009 magigcmirror… u are installing the dependencies for that app
                                @sdetweil still says
                                electron: not found
                                Could this be because it says that node_modules is missing? I did both npm install and npm install electron@3.0.10 in MagicMirror.
                                  @jmartin1009 npm install from inside the magicmirror folder should have created node_modules (thats its (npm) job)
                                  erase MagicMirror folder,
                                  download again
                                  and then cd MagicMirror and then npm install
                                    @sdetweil another error, it says
                                    npm ERR! file /home/pi/MagicMirror/package.json
                                    npm ERR! code EJSONPARSE
                                    npm ERR! JSON.parse Failed to parse json
                                    npm ERR! JSON.parse Unexpected end of JSON input while parsing near ' '
                                    npm ERR! JSON.parse Failed to parse package. json data.
                                    npm ERR! JSON.parse package.json must be actual JSON, not just JavaScript.
                                      @jmartin1009 did u download the MagicMirror folder over again?
                                        @sdetweil yes I deleted the contents of the old folder and changed the name and redownloaded MagicMirror
                                          @jmartin1009 ok, from the /home/pi folder lets start again
                                          cd ~
                                          rm -rf whatever_the_old_folder_name_is
                                          rm -rf MagicMirror
                                          git clone https://github.com/MichMich/MagicMirror.git
                                          cd MagicMirror
                                          npm install
                                            @sdetweil okay I did all of that and it said it cloned and everthing, and then it rebooted during the install, now what? lol
