    Can't get MM to start, says it can't find electron, then electron won't start
    49 Posts 5 Posters 39.2k Views 4 Watching
    • bheplerB
      bhepler Module Developer @jmartin1009
      @jmartin1009 It sounds like your repository data is corrupted. Try this:
      rm ./package-lock.json
      rm -r ./node_modules
      npm cache clear --force
      and then attempt to reinstall electron.
      J 1 Reply Last reply
        jmartin1009
        @bhelper am I trying to install the correct version of electron is there another version I should be using, the guide I was trying said to use 1.7.6 but people on here say 2.0.0
          jmartin1009
          @bhepler am I trying to install the correct version of electron or is there another version I should be using, the guide I was trying said to use 1.7.6 but people on here say 2.0.0
            jmartin1009 @bhepler
            @bhepler I am given this error screen
            pi@raspberrypi:~ $ sudo npm install -g electron@2.0.0
            npm WARN registry Unexpected warning for https://registry.npmjs.org/: Miscellaneous Warning ENODATA: Cache input stream was empty
            npm WARN registry Using stale package data from https://registry.npmjs.org/ due to a request error during revalidation.
            npm ERR! code EINTEGRITY
            npm ERR! errno EINTEGRITY
            npm ERR! Invalid response body while trying to fetch https://registry.npmjs.org/electron: Integrity verification failed for sha512-MAYuYPYfeCgTfXMl3ioXQAncWDyol9bCAkDBgeNSFemdEJgyOkTSixehWJJTIC9Pc7Ebrgljxn1t3lwm9ae/Bw== (/root/.npm/_cacache/content-v2/sha512/30/06/2e60f61f7828137d7325de2a174009dc583ca897d6c20240c181e35215e99d1098323a44d28b17a1589253202f4f73b11bae0963c67d6dde5c26f5a7bf07)
            npm ERR!     /root/.npm/_logs/2019-02-20T01_39_41_726Z-debug.log
              sdetweil @jmartin1009
              @jmartin1009 MM is trying to install 4.x by default… try 3.0.10
              what version is npm?
              npm -v
              node -v
              npm install electron@3.0.10
                jmartin1009 @sdetweil
                @sdetweil npm is 6.4.1 and node is 10.15.1. When I try to install electron now it just says that my cache input stream is empty. when I tried to get to node modules like @bhepler said, it said no such file or directory, and when I force cleared it gave me a warning message saying “I sure hope you know what you are doing.”
                  try
                  npm init -y
                  may have to erase the /home/pi/.npm folder
                    @sdetweil got this, now what?
                    pi@raspberrypi:~ $ npm init -y
                    Wrote to /home/pi/package.json:
                      "name": "pi",
                      "version": "1.0.0",
                      "description": "",
                      "main": "index.js",
                      "dependencies": {},
                      "devDependencies": {},
                      "scripts": {
                        "test": "echo \"Error: no test specified\" && exit 1"
                      "keywords": [],
                      "author": "",
                      "license": "ISC"
                      now change to MagicMirror folder and try the install for electron@3.0.10
                      J 2 Replies Last reply
                      Reply Quote -1
                        @sdetweil the pi reboots and then I change to magicmirror folder and try to start magic mirror and it still says it can’t find electron for some reason :/
                          @sdetweil it also says that “local package.json exists, but node_modules is missing, did you mean to install?”
                            @jmartin1009 yes
                            npm install
                            and if you still have electron missing, then try to
                              @sdetweil do I do npm install in pi or magic mirror?
                                @jmartin1009 magigcmirror… u are installing the dependencies for that app
                                  @sdetweil still says
                                  electron: not found
                                  Could this be because it says that node_modules is missing? I did both npm install and npm install electron@3.0.10 in MagicMirror.
                                    @jmartin1009 npm install from inside the magicmirror folder should have created node_modules (thats its (npm) job)
                                    erase MagicMirror folder,
                                    download again
                                    and then cd MagicMirror and then npm install
                                      @sdetweil another error, it says
                                      npm ERR! file /home/pi/MagicMirror/package.json
                                      npm ERR! code EJSONPARSE
                                      npm ERR! JSON.parse Failed to parse json
                                      npm ERR! JSON.parse Unexpected end of JSON input while parsing near ' '
                                      npm ERR! JSON.parse Failed to parse package. json data.
                                      npm ERR! JSON.parse package.json must be actual JSON, not just JavaScript.
                                        @jmartin1009 did u download the MagicMirror folder over again?
                                          @sdetweil yes I deleted the contents of the old folder and changed the name and redownloaded MagicMirror
                                            @jmartin1009 ok, from the /home/pi folder lets start again
                                            cd ~
                                            rm -rf whatever_the_old_folder_name_is
                                            rm -rf MagicMirror
                                            git clone https://github.com/MichMich/MagicMirror.git
                                            cd MagicMirror
                                            npm install
