Can't get MM to start, says it can't find electron, then electron won't start
When I try to install electron using sudo npm install electron@2.0.0, I get
pi@raspberrypi:~ $ sudo npm install electron@2.0.0 npm WARN registry Unexpected warning for https://registry.npmjs.org/: Miscellaneous Warning ENODATA: Cache input stream was empty npm WARN registry Using stale package data from https://registry.npmjs.org/ due to a request error during revalidation. npm ERR! code EINTEGRITY npm ERR! errno EINTEGRITY npm ERR! Invalid response body while trying to fetch https://registry.npmjs.org/electron: Integrity verification failed for sha512-MAYuYPYfeCgTfXMl3ioXQAncWDyol9bCAkDBgeNSFemdEJgyOkTSixehWJJTIC9Pc7Ebrgljxn1t3lwm9ae/Bw== (/root/.npm/_cacache/content-v2/sha512/30/06/2e60f61f7828137d7325de2a174009dc583ca897d6c20240c181e35215e99d1098323a44d28b17a1589253202f4f73b11bae0963c67d6dde5c26f5a7bf07) npm ERR! A complete log of this run can be found in: npm ERR! /root/.npm/_logs/2019-02-20T00_15_03_383Z-debug.logand when I try to start magic mirror I get
pi@raspberrypi:~ $ cd ~/MagicMirror pi@raspberrypi:~/MagicMirror $ DISPLAY=:0 npm start > magicmirror@2.6.0 start /home/pi/MagicMirror > sh run-start.sh run-start.sh: 4: run-start.sh: electron: not found npm ERR! file sh npm ERR! code ELIFECYCLE npm ERR! errno ENOENT npm ERR! syscall spawn npm ERR! magicmirror@2.6.0 start: `sh run-start.sh` npm ERR! spawn ENOENT npm ERR! npm ERR! Failed at the magicmirror@2.6.0 start script. npm ERR! This is probably not a problem with npm. There is likely additional logging output above. npm WARN Local package.json exists, but node_modules missing, did you mean to install? npm ERR! A complete log of this run can be found in: npm ERR! /home/pi/.npm/_logs/2019-02-20T00_18_40_335Z-debug.logI’m a complete noobie when it comes to this and I just can’t seem to get it to work, all help is appreciated!!
@jmartin1009 It sounds like your repository data is corrupted. Try this:
rm ./package-lock.json rm -r ./node_modules npm cache clear --forceand then attempt to reinstall electron.
@bhelper am I trying to install the correct version of electron is there another version I should be using, the guide I was trying said to use 1.7.6 but people on here say 2.0.0
@bhepler am I trying to install the correct version of electron or is there another version I should be using, the guide I was trying said to use 1.7.6 but people on here say 2.0.0
@bhepler I am given this error screen
pi@raspberrypi:~ $ sudo npm install -g electron@2.0.0 npm WARN registry Unexpected warning for https://registry.npmjs.org/: Miscellaneous Warning ENODATA: Cache input stream was empty npm WARN registry Using stale package data from https://registry.npmjs.org/ due to a request error during revalidation. npm ERR! code EINTEGRITY npm ERR! errno EINTEGRITY npm ERR! Invalid response body while trying to fetch https://registry.npmjs.org/electron: Integrity verification failed for sha512-MAYuYPYfeCgTfXMl3ioXQAncWDyol9bCAkDBgeNSFemdEJgyOkTSixehWJJTIC9Pc7Ebrgljxn1t3lwm9ae/Bw== (/root/.npm/_cacache/content-v2/sha512/30/06/2e60f61f7828137d7325de2a174009dc583ca897d6c20240c181e35215e99d1098323a44d28b17a1589253202f4f73b11bae0963c67d6dde5c26f5a7bf07) npm ERR! A complete log of this run can be found in: npm ERR! /root/.npm/_logs/2019-02-20T01_39_41_726Z-debug.log -
@jmartin1009 MM is trying to install 4.x by default… try 3.0.10
what version is npm?
npm -v
node -vnpm install electron@3.0.10
@sdetweil npm is 6.4.1 and node is 10.15.1. When I try to install electron now it just says that my cache input stream is empty. when I tried to get to node modules like @bhepler said, it said no such file or directory, and when I force cleared it gave me a warning message saying “I sure hope you know what you are doing.”
try
npm init -ymay have to erase the /home/pi/.npm folder
@sdetweil got this, now what?
pi@raspberrypi:~ $ npm init -y Wrote to /home/pi/package.json: { "name": "pi", "version": "1.0.0", "description": "", "main": "index.js", "dependencies": {}, "devDependencies": {}, "scripts": { "test": "echo \"Error: no test specified\" && exit 1" }, "keywords": [], "author": "", "license": "ISC" } -
now change to MagicMirror folder and try the install for electron@3.0.10
