    Can't get MM to start, says it can't find electron, then electron won't start
    49 Posts 5 Posters 39.2k Views 4 Watching
      now change to MagicMirror folder and try the install for electron@3.0.10
      J 2 Replies Last reply
      Reply Quote -1
        jmartin1009 @sdetweil
        @sdetweil the pi reboots and then I change to magicmirror folder and try to start magic mirror and it still says it can’t find electron for some reason :/
          @sdetweil it also says that “local package.json exists, but node_modules is missing, did you mean to install?”
            sdetweil @jmartin1009
            @jmartin1009 yes
            npm install
            and if you still have electron missing, then try to
            npm install electron@3.0.10
            J 1 Reply Last reply
              @sdetweil do I do npm install in pi or magic mirror?
                @jmartin1009 magigcmirror… u are installing the dependencies for that app
                  @sdetweil still says
                  electron: not found
                  Could this be because it says that node_modules is missing? I did both npm install and npm install electron@3.0.10 in MagicMirror.
                    @jmartin1009 npm install from inside the magicmirror folder should have created node_modules (thats its (npm) job)
                    erase MagicMirror folder,
                    download again
                    and then cd MagicMirror and then npm install
                      @sdetweil another error, it says
                      npm ERR! file /home/pi/MagicMirror/package.json
                      npm ERR! code EJSONPARSE
                      npm ERR! JSON.parse Failed to parse json
                      npm ERR! JSON.parse Unexpected end of JSON input while parsing near ' '
                      npm ERR! JSON.parse Failed to parse package. json data.
                      npm ERR! JSON.parse package.json must be actual JSON, not just JavaScript.
                        @jmartin1009 did u download the MagicMirror folder over again?
                          @sdetweil yes I deleted the contents of the old folder and changed the name and redownloaded MagicMirror
                            @jmartin1009 ok, from the /home/pi folder lets start again
                            cd ~
                            rm -rf whatever_the_old_folder_name_is
                            rm -rf MagicMirror
                            git clone https://github.com/MichMich/MagicMirror.git
                            cd MagicMirror
                            npm install
                              @sdetweil okay I did all of that and it said it cloned and everthing, and then it rebooted during the install, now what? lol
                                @jmartin1009 should not reboot
                                  @sdetweil oh it reboots everytime I install magicmirror, how do I prevent this? because it always reboots like 1/3 of the way through the progress bar and it always did it so I thought it was normal lol can I stop this? I have a pi 3+ btw
                                    jmartin1009 @jmartin1009
                                    @jmartin1009 it also does that everytime I try to install electron so maybe that’s why it isn’t working :confused: is there any fix for this?
                                      Sorry, I do not know. Mine never reboots.
                                      How big is your memory card?
                                        @sdetweil 32 gb
                                          @sdetweil I believe u figured out why it was restarting, a common cause of it is lack of power, and some person had problems with their keyboard drawing too much power so I unplugged it and it went all the way through without rebooting, but I still got some issues, im left with
                                          Installing dependencies ...
                                          npm WARN deprecated time-grunt@2.0.0: Deprecated because Grunt is practically unmaintained. Move on to something better. This package will continue to work with Grunt v1, but it will not receive any updates.
                                          npm WARN deprecated nomnom@1.8.1: Package no longer supported. Contact support@npmjs.com for more info.
                                          npm WARN tarball cached data for async@~1.5.2 (sha1-7GphrlZIDAw8skHJVhjiCJL5Zyo=) seems to be corrupted. Refreshing cache.
                                          npm WARN grunt-stylelint@0.10.1 requires a peer of stylelint@^9.0.0 but none is installed. You must install peer dependencies yourself.
                                          npm WARN acorn-jsx@5.0.1 requires a peer of acorn@^6.0.0 but none is installed. You must install peer dependencies yourself.
                                          npm ERR! path /home/pi/MagicMirror/node_modules/coffeescript/bin/coffee
                                          npm ERR! code ENOENT
                                          npm ERR! errno -2
                                          npm ERR! syscall chmod
                                          npm ERR! enoent ENOENT: no such file or directory, chmod '/home/pi/MagicMirror/node_modules/coffeescript/bin/coffee'
                                          npm ERR! enoent This is related to npm not being able to find a file.
                                          npm ERR! enoent
                                          npm ERR!     /home/pi/.npm/_logs/2019-02-20T04_31_21_244Z-debug.log
                                          Unable to install dependencies!
                                            @jmartin1009 I think u need to restart the install
                                            Erase the node_modules folder, and do it again
