    Can't get MM to start, says it can't find electron, then electron won't start
    49 Posts 5 Posters 39.2k Views 4 Watching
      jmartin1009 @sdetweil
      @sdetweil npm is 6.4.1 and node is 10.15.1. When I try to install electron now it just says that my cache input stream is empty. when I tried to get to node modules like @bhepler said, it said no such file or directory, and when I force cleared it gave me a warning message saying “I sure hope you know what you are doing.”
        try
        npm init -y
        may have to erase the /home/pi/.npm folder
        J 1 Reply Last reply
          @sdetweil got this, now what?
          pi@raspberrypi:~ $ npm init -y
          Wrote to /home/pi/package.json:
            "name": "pi",
            "version": "1.0.0",
            "description": "",
            "main": "index.js",
            "dependencies": {},
            "devDependencies": {},
            "scripts": {
              "test": "echo \"Error: no test specified\" && exit 1"
            "keywords": [],
            "author": "",
            "license": "ISC"
            now change to MagicMirror folder and try the install for electron@3.0.10
            J 2 Replies Last reply
            Reply Quote -1
              @sdetweil the pi reboots and then I change to magicmirror folder and try to start magic mirror and it still says it can’t find electron for some reason :/
                @sdetweil it also says that “local package.json exists, but node_modules is missing, did you mean to install?”
                  sdetweil @jmartin1009
                  @jmartin1009 yes
                  npm install
                  and if you still have electron missing, then try to
                  npm install electron@3.0.10
                    @sdetweil do I do npm install in pi or magic mirror?
                      @jmartin1009 magigcmirror… u are installing the dependencies for that app
                        @sdetweil still says
                        electron: not found
                        Could this be because it says that node_modules is missing? I did both npm install and npm install electron@3.0.10 in MagicMirror.
                          @jmartin1009 npm install from inside the magicmirror folder should have created node_modules (thats its (npm) job)
                          erase MagicMirror folder,
                          download again
                          and then cd MagicMirror and then npm install
                            @sdetweil another error, it says
                            npm ERR! file /home/pi/MagicMirror/package.json
                            npm ERR! code EJSONPARSE
                            npm ERR! JSON.parse Failed to parse json
                            npm ERR! JSON.parse Unexpected end of JSON input while parsing near ' '
                            npm ERR! JSON.parse Failed to parse package. json data.
                            npm ERR! JSON.parse package.json must be actual JSON, not just JavaScript.
                              @jmartin1009 did u download the MagicMirror folder over again?
                                @sdetweil yes I deleted the contents of the old folder and changed the name and redownloaded MagicMirror
                                  @jmartin1009 ok, from the /home/pi folder lets start again
                                  cd ~
                                  rm -rf whatever_the_old_folder_name_is
                                  rm -rf MagicMirror
                                  git clone https://github.com/MichMich/MagicMirror.git
                                  cd MagicMirror
                                  npm install
                                    @sdetweil okay I did all of that and it said it cloned and everthing, and then it rebooted during the install, now what? lol
                                      @jmartin1009 should not reboot
                                        @sdetweil oh it reboots everytime I install magicmirror, how do I prevent this? because it always reboots like 1/3 of the way through the progress bar and it always did it so I thought it was normal lol can I stop this? I have a pi 3+ btw
                                          jmartin1009 @jmartin1009
                                          @jmartin1009 it also does that everytime I try to install electron so maybe that’s why it isn’t working :confused: is there any fix for this?
                                            Sorry, I do not know. Mine never reboots.
                                            How big is your memory card?
