    Can't get MM to start, says it can't find electron, then electron won't start
    49 Posts 5 Posters 39.2k Views 4 Watching
      jmartin1009
      When I try to install electron using sudo npm install electron@2.0.0, I get
      pi@raspberrypi:~ $ sudo npm install electron@2.0.0
      npm WARN registry Unexpected warning for https://registry.npmjs.org/: Miscellaneous Warning ENODATA: Cache input stream was empty
      npm WARN registry Using stale package data from https://registry.npmjs.org/ due to a request error during revalidation.
      npm ERR! code EINTEGRITY
      npm ERR! errno EINTEGRITY
      npm ERR! Invalid response body while trying to fetch https://registry.npmjs.org/electron: Integrity verification failed for sha512-MAYuYPYfeCgTfXMl3ioXQAncWDyol9bCAkDBgeNSFemdEJgyOkTSixehWJJTIC9Pc7Ebrgljxn1t3lwm9ae/Bw== (/root/.npm/_cacache/content-v2/sha512/30/06/2e60f61f7828137d7325de2a174009dc583ca897d6c20240c181e35215e99d1098323a44d28b17a1589253202f4f73b11bae0963c67d6dde5c26f5a7bf07)
      npm ERR!     /root/.npm/_logs/2019-02-20T00_15_03_383Z-debug.log
      and when I try to start magic mirror I get
      pi@raspberrypi:~/MagicMirror $ DISPLAY=:0 npm start
      > magicmirror@2.6.0 start /home/pi/MagicMirror
      > sh run-start.sh
      run-start.sh: 4: run-start.sh: electron: not found
      npm ERR! file sh
      npm ERR! code ELIFECYCLE
      npm ERR! errno ENOENT
      npm ERR! syscall spawn
      npm ERR! magicmirror@2.6.0 start: `sh run-start.sh`
      npm ERR! spawn ENOENT
      npm ERR!
      npm ERR! Failed at the magicmirror@2.6.0 start script.
      npm WARN Local package.json exists, but node_modules missing, did you mean to install?
      npm ERR!     /home/pi/.npm/_logs/2019-02-20T00_18_40_335Z-debug.log
      I’m a complete noobie when it comes to this and I just can’t seem to get it to work, all help is appreciated!!
      bheplerB 1 Reply Last reply
      • bheplerB
        bhepler Module Developer @jmartin1009
        @jmartin1009 It sounds like your repository data is corrupted. Try this:
        rm ./package-lock.json
        rm -r ./node_modules
        npm cache clear --force
        and then attempt to reinstall electron.
        J 1 Reply Last reply
          jmartin1009
          @bhelper am I trying to install the correct version of electron is there another version I should be using, the guide I was trying said to use 1.7.6 but people on here say 2.0.0
            jmartin1009
            @bhepler am I trying to install the correct version of electron or is there another version I should be using, the guide I was trying said to use 1.7.6 but people on here say 2.0.0
              jmartin1009 @bhepler
              @bhepler I am given this error screen
              pi@raspberrypi:~ $ sudo npm install -g electron@2.0.0
              npm ERR!     /root/.npm/_logs/2019-02-20T01_39_41_726Z-debug.log
                sdetweil @jmartin1009
                @jmartin1009 MM is trying to install 4.x by default… try 3.0.10
                what version is npm?
                npm -v
                node -v
                npm install electron@3.0.10
                  jmartin1009 @sdetweil
                  @sdetweil npm is 6.4.1 and node is 10.15.1. When I try to install electron now it just says that my cache input stream is empty. when I tried to get to node modules like @bhepler said, it said no such file or directory, and when I force cleared it gave me a warning message saying “I sure hope you know what you are doing.”
                    try
                    npm init -y
                    may have to erase the /home/pi/.npm folder
                      @sdetweil got this, now what?
                      pi@raspberrypi:~ $ npm init -y
                      Wrote to /home/pi/package.json:
                        "name": "pi",
                        "version": "1.0.0",
                        "description": "",
                        "main": "index.js",
                        "dependencies": {},
                        "devDependencies": {},
                        "scripts": {
                          "test": "echo \"Error: no test specified\" && exit 1"
                        "keywords": [],
                        "author": "",
                        "license": "ISC"
                        now change to MagicMirror folder and try the install for electron@3.0.10
                        J 2 Replies Last reply
                        Reply Quote -1
                          @sdetweil the pi reboots and then I change to magicmirror folder and try to start magic mirror and it still says it can’t find electron for some reason :/
                            @sdetweil it also says that “local package.json exists, but node_modules is missing, did you mean to install?”
                              @jmartin1009 yes
                              npm install
                              and if you still have electron missing, then try to
                                @sdetweil do I do npm install in pi or magic mirror?
                                  @jmartin1009 magigcmirror… u are installing the dependencies for that app
                                    @sdetweil still says
                                    electron: not found
                                    Could this be because it says that node_modules is missing? I did both npm install and npm install electron@3.0.10 in MagicMirror.
                                      @jmartin1009 npm install from inside the magicmirror folder should have created node_modules (thats its (npm) job)
                                      erase MagicMirror folder,
                                      download again
                                      and then cd MagicMirror and then npm install
                                        @sdetweil another error, it says
                                        npm ERR! file /home/pi/MagicMirror/package.json
                                        npm ERR! code EJSONPARSE
                                        npm ERR! JSON.parse Failed to parse json
                                        npm ERR! JSON.parse Unexpected end of JSON input while parsing near ' '
                                        npm ERR! JSON.parse Failed to parse package. json data.
                                        npm ERR! JSON.parse package.json must be actual JSON, not just JavaScript.
                                          @jmartin1009 did u download the MagicMirror folder over again?
                                            @sdetweil yes I deleted the contents of the old folder and changed the name and redownloaded MagicMirror
