    Motion Detection with RaspiCam, Non-Module version
    47 Posts 13 Posters 55.2k Views 17 Watching
      dam4 @bhepler
      @bhepler
      This is what I get when I type that in.
      pi@raspberrypi:~ $ ls -ah /home/pi/motion
      . CONTRIBUTING.md mask1.png netcam_ftp.h rotate.o
      … COPYING md5.c netcam_ftp.o stream.c
      aclocal.m4 copyright md5.h netcam.h stream.h
      alg.c CREDITS md5.o netcam_http.c stream.o
      alg.h .depend mmalcam.c netcam_http.h test_builds.sh
      alg.o draw.c mmalcam.h netcam_http.o track.c
      autom4te.cache draw.o mmalcam.o netcam_jpeg.c track.h
      camera1-dist.conf event.c mmx.h netcam_jpeg.o track.o
      camera1-dist.conf.in event.h motion netcam.o .travis.yml
      camera2-dist.conf event.o motion.1 netcam_rtsp.c version.sh
      camera2-dist.conf.in FAQ motion.c netcam_rtsp.h video_bktr.c
      camera3-dist.conf ffmpeg.c motion-dist.conf netcam_rtsp.o video_bktr.h
      camera3-dist.conf.in ffmpeg.h motion-dist.conf.in netcam_wget.c video_bktr.o
      camera4-dist.conf ffmpeg.o motion_guide.html netcam_wget.h video_common.c
      camera4-dist.conf.in .git motion.h netcam_wget.o video_common.h
      CHANGELOG .gitignore motion.init-Debian normal.jpg video_common.o
      CODE_STANDARD INSTALL motion.init-Debian.in outputmotion1.jpg video_loopback.c
      conf.c ISSUE_TEMPLATE.md motion.init-FreeBSD.sh outputnormal1.jpg video_loopback.h
      conf.h jpegutils.c motion.init-FreeBSD.sh.in picture.c video_loopback.o
      config.h jpegutils.h motion.o picture.h video_v4l2.c
      config.h.in jpegutils.o motion.service picture.o video_v4l2.h
      config.log logger.c motion.service.in pwc-ioctl.h video_v4l2.o
      config.status logger.h motion.spec raspicam webhttpd.c
      configure logger.o motion.spec.in README.md webhttpd.h
      configure.ac Makefile netcam.c rotate.c webhttpd.o
      conf.o Makefile.in netcam_ftp.c rotate.h
      pi@raspberrypi:~ $
        dam4 @bhepler
        @bhepler The motion works only when MagicMirror isn’t running. I have it starting with pm2. When MagicMirror is running the motion doesn’t work. Any suggestions?
          bhepler Module Developer @dam4
          @dam4 What the hell… ls is the “list” command. It should only show you the listing for the file, including dates and permissions. But it’s… executing.
          Just to be sure: pm2 shows two separate processes when you type pm2 status, correct?
            dam4 @bhepler
            @bhepler I copied and pasted exactly what you wrote for the command to make sure I didn’t mistype something.
            Yes there are two processes running when I type pm2 status. One is MagicMirror and the other is motion.
            • T Offline
              trividar
              Does anyone get it to work on stretch? I tried it but without success.
                AnduriI
                Hey there,
                I have this running for quite some time and it works in general. But after some hours it gets really slow and unresponsiv. A motion need a few seconds before it is detected. I already have enabled a daily reboot, but still these few hours are enough. I also tried only restarting motion via pm2, but this leads to problems. I checked it with pm2 monit and got this:
                motion > [0] [NTC] [ALL] main: Waiting for threads to finish, pid: 13536
                motion > [1] [NTC] [ALL] motion_init: Thread 1 started , motion detection Enabled
                motion > [1] [ALR] [VID] mmalcam_start: MMAL Camera thread starting... for camera (vc.ril.camera) of 640 x 480 at 4 fps
                motion > [1] [ALR] [VID] mmalcam_start: MMAL Camera using video capture
                motion > [0] [ERR] [ALL] main: Thread 1 - Watchdog timeout, trying to do a graceful restart
                motion > [0] [ERR] [ALL] main: Thread 1 - Watchdog timeout, did NOT restart graceful,killing it!
                motion > [0] [NTC] [STR] stream_stop: Closing motion-stream listen socket & active motion-stream sockets
                motion > [0] [NTC] [STR] stream_stop: Closed motion-stream listen socket & active motion-stream sockets
                motion > [0] [INF] [ALL] motion_cleanup: Calling vid_close() from motion_cleanup
                motion > [0] [INF] [VID] vid_close: calling video source cleanup
                motion > [0] [ALR] [VID] MMAL Camera cleanup
                motion > /home/pi/motion.sh: Zeile 2: 13536 Speicherzugriffsfehler  (Speicherabzug geschrieben) ./motion -c motion.conf
                PM2 > App [motion] with id [0] and pid [13532], exited with code [139] via signal [SIGINT]
                PM2 > Starting execution sequence in -fork mode- for app name:motion id:0
                PM2 > App name:motion id:0 online
                motion > [0] [NTC] [ALL] conf_load: Processing thread 0 - config file motion.conf
                motion > [0] [NTC] [ALL] motion_startup: Motion mmaltest Started
                motion > [0] [NTC] [ALL] motion_startup: Logging to syslog
                motion > [0] [NTC] [ALL] motion_startup: Using log type (ALL) log level (INF)
                motion > [0] [NTC] [ENC] ffmpeg_init: ffmpeg LIBAVCODEC_BUILD 3670272 LIBAVFORMAT_BUILD 3670272
                motion > [0] [NTC] [ALL] main: Thread 1 is from motion.conf
                motion > [0] [NTC] [ALL] main: Thread 1 is device: /dev/video0 input -1
                motion > [0] [NTC] [ALL] main: Stream port 8081
                motion > [0] [NTC] [ALL] main: Waiting for threads to finish, pid: 13583
                Can anyone suggest how to correctly restart motion?
                • F Offline
                  Freebond @trividar
                  @trividar I’m trying to install it right now. You posted 2 months ago. Did you get it running?
                  • 3 / 3
