    V2.5.0 problem.
    7 Posts 4 Posters 2.4k Views 3 Watching
    • 3 Offline
      3zq3mh
      i updated my MM that is running on RPI3 and this is what i get.
      i also am running a website server on my RPI that is working fine!
      every time i run “npm start” i get this!
      npm ERR! code ELIFECYCLE
      npm ERR! errno 1
      npm ERR! magicmirror@2.5.0 start: sh run-start.sh
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the magicmirror@2.5.0 start script.
      J S 2 Replies Last reply Reply Quote 0
        j.e.f.f Project Sponsor Module Developer @3zq3mh
        @3zq3mh what port is your web server running on? Magic Mirror runs on port 8080 by default. If you we server is also using that port, they both cannot run at the same time.
        • 3 Offline
          3zq3mh
          Web Server is on 8989
          MagicMirror is on 8889
          but i did not have any problems until i updated MM today to 2.5.0
            sdetweil @3zq3mh
            @3zq3mh just for a test, if u stop your webserver, does MM start?
            3 1 Reply Last reply Reply Quote 0
            • 3 Offline
              3zq3mh @sdetweil
              @sdetweil no
                AxLed Module Developer
                @3zq3mh
                What happens or what messages are shown if you start your mm with npm start dev
                AxLED
                  sdetweil @3zq3mh
                  @3zq3mh after you did the git pull, did u npm install again?
