MMM-GoogleAssistant, segmentation fault!
Hello friends, i m installing GA module as given in its readme file at MMM-GoogleAssistant
i am installing this GA Module and i am stuck at “Run the Sample Code” … i followed the readme file and when i enter the command “googlesamples-assistant-hotword --project-id my-dev-project --device-model-id my-model” in the terminal, it says “Segmentation fault”
i tried different id’s and stuff, searched but i got no luck… more over its bit confusing with model id, device model id, project id, etc … i have Magic Mirror running fine with default modules… Please help me out with this! Thanks.
still no success, do i need to install MMM-Hotword…?? i havent came across anything in its readme like that… just asking…
use MMM-AssistantMk2. It is a newer version, maybe this is not supported.
From the Github page: “(Deprecated) This project is not supported any more from original owner. Use alternative MMM-AssistantMk2”
@radokristof said in MMM-GoogleAssistant, segmentation fault!:
Thanks, will try this mk2 module…
@roxx
MMM-GoogleAssistant
is not mine.it is nothing related with
MMM-Hotword
orMMM-AssistantMk2
(or even deprecatedMMM-Assistant
Anyway if you have a problem on installation or usage, leave an issue on github. I’ll support.
@sean said in MMM-GoogleAssistant, segmentation fault!:
@roxx
MMM-GoogleAssistant
MMM-Hotword
orMMM-AssistantMk2
Anyway if you have a problem on installation or usage, leave an issue on github. I’ll support.yep, i have submitted an issue, issue #56. thanks.
