    MM and Kalliope: make Kalliope speaking
    14 Posts 4 Posters 5.2k Views 4 Watching
    • N
      NPX78
      Hello everyone
      Sorry for my english.
      I hope my question is not already answered in another post
      I am working on module and interactions between Kalliope and MagicMirror.
      The module receives the order and takes it into account.
      Now, I would like to force Kalliope to say someting.
      For example:
      1. I say : “Kalliope … Display the calendar for John”
      2. Kalliope send a notification to modules
      3. My module catches this notification and display the calendar for John
      4. My module forces Kalliope to say “The calendera for John is displayed”
      The step 1, 2 a,d 3 are OK
      But I do not know if it is possible to do the step 4.
      Currently I display only the text.
      Thank you for your time and your help.
      Regards
      Nicolas
      • N
        NPX78
        Spoiler Text
        Hello
        So my solution.
        Kalliope Side :
        //-- settings.yml file
        # Rest API
        rest_api:
          active: True
          port: 5000
          password_protected: False
          login: admin
          password: secret
          allowed_cors_origin: "*"
        active:True allows using the Rest API
        password_protected: False allows anonymous connections
        allowed_cors_origin: allows connections from other sites. This option is mandatory because the MM site is localhost:8080 and kalliope 127.0.0.1:5000
        Concerning the brain.yml file
          - name: "repeat"
            signals:
              - order: "repeat after me {{sentence}}"
            neurons:
              - say:
                  message: "{{sentence}}"
        This synapse allows Kalliope repeat a sentence.
        Magic Mirror side :
        The following lines could be inserted in a module file
        //-- Create the Request object.
        const Http   = new XMLHttpRequest();
        //-- Url to call fo our synapse.
        const url    = 'http://localhost:5000/synapses/start/id/repeat';
        //-- Build our data to send as parameters of our request.
        var sent     = 'This is the text I want Kalliope repeat';    //-- You can modify it
        var data     = {"parameters" : {'sentence':sent}};
        var dataJson = JSON.stringify(data);
        //-- Launch the request.
        Http.open("POST",url);
        Http.setRequestHeader("Content-type","application/json");
        Http.send(dataJson);
        I hope to be clear :)
        I mark the post as Solved.
        Thank you a lot for your time and ideas.
        Regards
        Nicolas
          sdetweil @NPX78
          @npx78 maybe look at the MMM-TTS module (tts - Text To Speech) on github
          • N
            NPX78 @sdetweil
            @sdetweil Thank you for your answer.
            In a perfect world, I would like to have the Kalliope voice :smiling_face_with_open_mouth_smiling_eyes:
            Is it possible with MMM-TTS module ?
            Regards
            Nicolas
              sdetweil @NPX78
              @npx78 i do not know
                A Former User
                Consider MMM-GoogleTTS also.
                  sdetweil @Guest
                  @sean oops… didn’t see that one!
                  • strawberry 3.141S
                    @NPX78 MMM-TTS is an offline text to speech, where you can choose a few different voices, but I assume the voice of the Google module sounds better, but is online.
                    Here on the forum was once a member of the Kalliope team, you can reach out to him or on the kalliope project itself, if it needs to be that voice.
                      A Former User
                      @NPX78
                      After reading your question again, I have a little confusing.
                      As far as I know, Kalliope has its own TTS feature using pico2wave. And there be more options to use other TTS solution(including Google TTS). So I couldn’t understand why other MM TTS module is needed.
                      • N
                        NPX78 @Guest
                        @sean hello Sean.
                        Using the TTS of Kalliope could be the better solution.
                        But how can I call this fonctionnalité from a MM module
                        Thank you for your time and explanations
                        Regars
                        Nicolas
                          A Former User @NPX78
                          @npx78
                          I have no experience with Kalliope so I’m not sure…
                          I think this is showing what you needs - https://kalliope-project.github.io/kalliope/rest_api/#run-a-synapse-from-an-order
                          So, by just calling Kalliope API with curl to run your reply synapse from your module after it’s job, couldn’t be done?
                          • N
                            NPX78 @Guest
                            @sean Very good idea. Thank you.
                            I look for it this evening.
                            Currently : call the API REST with a synapse “repeat afer me …” : OK
                            I have some problem to call the curl into javascript module.
                            I use the XMLHttpRequest, but I have a beautiful: “400 (BAD REQUEST)” :)
                            After a night, my brain would be better :).
                            I will give you some news tomorrow.
                            • N
                              NPX78
                              Hello everybody
                              Good night for my brain :) .
                              I solved my problem.
                              I will put the solution this evening (and will turn this post to solve)
                              Thanh you a lot to everybody in particular Sean.
                              Regards
                              Nicolas
                              • N
                                NPX78
                                Spoiler Text
                                Hello
                                So my solution.
                                Kalliope Side :
                                # Rest API
                                rest_api:
                                  active: True
                                  port: 5000
                                  login: admin
                                  password: secret
                                  - name: "repeat"
                                    signals:
                                    neurons:
                                      - say:
                                Magic Mirror side :
                                Regards
                                Nicolas
                                  sdetweil @NPX78
                                  @npx78 very cool… thank you for sharing and helping others…
