    MM and Kalliope: make Kalliope speaking
    14 Posts 4 Posters 4.5k Views 4 Watching
      sdetweil @NPX78
      @npx78 maybe look at the MMM-TTS module (tts - Text To Speech) on github
      • N Offline
        NPX78 @sdetweil
        @sdetweil Thank you for your answer.
        In a perfect world, I would like to have the Kalliope voice :smiling_face_with_open_mouth_smiling_eyes:
        Is it possible with MMM-TTS module ?
        Regards
        Nicolas
          sdetweil @NPX78
          @npx78 i do not know
            A Former User
            Consider MMM-GoogleTTS also.
              sdetweil @Guest
              @sean oops… didn’t see that one!
              • strawberry 3.141S Offline
                @NPX78 MMM-TTS is an offline text to speech, where you can choose a few different voices, but I assume the voice of the Google module sounds better, but is online.
                Here on the forum was once a member of the Kalliope team, you can reach out to him or on the kalliope project itself, if it needs to be that voice.
                  A Former User
                  @NPX78
                  After reading your question again, I have a little confusing.
                  As far as I know, Kalliope has its own TTS feature using pico2wave. And there be more options to use other TTS solution(including Google TTS). So I couldn’t understand why other MM TTS module is needed.
                  • N Offline
                    NPX78 @Guest
                    @sean hello Sean.
                    Using the TTS of Kalliope could be the better solution.
                    But how can I call this fonctionnalité from a MM module
                    Thank you for your time and explanations
                    Regars
                    Nicolas
                      A Former User @NPX78
                      @npx78
                      I have no experience with Kalliope so I’m not sure…
                      I think this is showing what you needs - https://kalliope-project.github.io/kalliope/rest_api/#run-a-synapse-from-an-order
                      So, by just calling Kalliope API with curl to run your reply synapse from your module after it’s job, couldn’t be done?
                      • N Offline
                        NPX78 @Guest
                        @sean Very good idea. Thank you.
                        I look for it this evening.
                        Currently : call the API REST with a synapse “repeat afer me …” : OK
                        I have some problem to call the curl into javascript module.
                        I use the XMLHttpRequest, but I have a beautiful: “400 (BAD REQUEST)” :)
                        After a night, my brain would be better :).
                        I will give you some news tomorrow.
