    MMM-AssistantMk2 and auth_and_test.js
    7 Posts 2 Posters 3.0k Views 2 Watching
      sonicgoose
      Reposting because I put this in the wrong forum the first time.
      I’ll try to make a long story short:
      Installed MMM-AssistantMk2 and MMM-Hotword. Added default config for both to config.js. Got nothing but a black screen. Narrowed the problem down to MMM-AssistantMk2 and grpc. So went through the troubleshooting tips to switch to grpc-js instead (same problem) and to downgrade to v1.13 of grpc. I’ve now (for the third time) created my credentials.json file and am trying to run
      node auth_and_test.js
      This is what shows up after a few seconds:
      /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/google-assistant/components/auth.js:27
        const oauthClient = new OAuth2(key.client_id, key.client_secret, key.redirect_uris[0]);
      TypeError: Cannot read property 'client_id' of undefined
          at new Auth (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/google-assistant/components/auth.js:27:38)
          at new GoogleAssistant (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/google-assistant/index.js:21:16)
          at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-AssistantMk2/auth_and_test.js:60:19)
          at Module._compile (internal/modules/cjs/loader.js:654:30)
          at Object.Module._extensions..js (internal/modules/cjs/loader.js:665:10)
          at Module.load (internal/modules/cjs/loader.js:566:32)
          at tryModuleLoad (internal/modules/cjs/loader.js:506:12)
          at Function.Module._load (internal/modules/cjs/loader.js:498:3)
          at Function.Module.runMain (internal/modules/cjs/loader.js:695:10)
          at startup (internal/bootstrap/node.js:201:19)
      And I’m stuck. Help?
      • ? Offline
        A Former User @sonicgoose
        @sonicgoose
        Your credentials.json is wrong. Especially you’ve missed or failed something on making credentials on google console
          sonicgoose @Guest
          @Sean I don’t think so. I got it to work twice. My browser launched, I logged in, I got a code back and paste that into the prompt presented by auth_and_test.js. Twice. Now the third time, after downgrading grpc to v1.13, it won’t work and I get the above error.
          • ? Offline
            @sonicgoose
            Weird, because it is not related grpc. error log says your credentials.json has been corrupted or missing something.
            Open your credentials.json and look into it.
            {"installed":{"client_id":"377258677000-2rv97u3b2....
            It should seems similar with above.
            Your file might have other text instead "installed". Isn’t it?
              sonicgoose @Guest
              @sean My file starts with
              {"web":{"client_id":"10236352...
                sonicgoose @sonicgoose
                @Sean This is weird. I just downloaded my credentials again and this time got
                {"installed":{"client_id":"1023635200...
                I’ll try this again when I get home. No idea how it could have changed.
                  sonicgoose
                  SUCCESS!!
