@sdetweil Thank you for the reply. Does the climate monitoring module need to be positioned away from the mirror and frame or can you achieve an accurate reading if the mirror housing is designed to account for this?
P
Offline
RE: Room climate module
Room climate module
I am just starting with my magic mirror. I have made a start on the programming and simultaneously working on the design of the mirror itself.
I have found that a panel frame could hold the mirror itself while looking like a floating mirror. Here is my question, I plan on involving a climate monitor as part of the setup to display live data such as humidity, temperature and so forth. The module itself will be mounted on a acrylic backboard behind the mirror. Do I need to involve air circulation into the design? And if so is a frame going to cause the module to not correctly monitor the conditions in the room…
